Question about JVC KD-G210 CD Player
Need a wiring diagram for a radio on a 93 Explorer. The speaker wires in my truck are Green, Purple with white stripe, yellow, blue w/white stripe, Lt. Blue , Orange w/white strip, brown, and red w/white strip. what colors do i hook up to my jvc cd receiver and there speaker wire are Right Front speaker positive is Gray the negitive is gray w/white strip. Left Front positive is White and negetive is White w/black line. Rear speakers- Right rear positive is purple and negtive is purple w/black line and Left rear speaker is Green for positive and negetive is green w/black line. I'm confused can any one help
  • 15,935 Answers
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black
Illumination Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Green
Left Front (-) Blue/White
Right Front (+) White/Green
Right Front (-) Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Pink/Green
Left Rear (-) Brown/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Black/White
THanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 08, 2009
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
Audio diagram for Jvc radio to 1999 ford explorer
Black-ground, Yellow-battery, Red-switched (ignition), blue-pwr antenna, amplifier remote power, white-left front, grey-right front, green-left rear, purple-right rear. On the speaker wires, the one with the black stripe is ground. Also, I may have got the rear speakers backward, check before permanant mounting.
Mar 13, 2010 | 1999 Ford Explorer
I need the radio wiring diagram for a 1992 cadillac eldorado. the wires i have are: black w/ white stripe, yellow, green w/white stripe, green, brown, 2 brown w/ white stripe,black on one plug the other...
white is front left. greay is front right. green is rear left . purple is rear right. black is ground .yellow is power. red is ignition. or do u need factory wiring? the12volt.com try this website it is very helpfull
Feb 10, 2010 | 1992 Cadillac Eldorado
Dont know if you can help but....I just bought an older model pick up(1989 toyota)it had no radio in the dash, I have a Kenwood CD player i want to install but I dont know the color codes of the wires in...
Nice radio installer link HERE
Check out the lower wiring guide.
A Right Front Speaker (+) Green Gray
B Left Front Speaker (+) Pink White
C +12 Volt Ignition Wire Gray Red
D +12 Volt Battery Wire Blue w/ Yellow Stripe Yellow
E Right Front Speaker (-) Blue Gray w/ Black Stripe
F Left Front Speaker (-) Purple White w/ Black Stripe
G Ground Wire Black Black
H Power Antenna Wire 1 Blue (join wires 1 & 2
I Power Antenna Wire 2 together to this blue wire)
J Do Not Use
K Right Rear Speaker (+) Red Purple
L Left Rear Speaker (+) Black Green
M Right Rear Speaker (-) White Purple w/ Black Stripe
N Do Not Use
O Do Not Use
P Left Rear Speaker (-) Yellow Green w/ Black Stripe
Dec 14, 2009 | Car Audio & Video
Im lookin fer the radio wiring diagram for my 1996 geo prizm because someone cut the standard clip for the stock radio out
Under the center console/dash you should has two connectors.
LARGER CONNECTOR
C Right Front Speaker (-) Blue Gray w/ Black Stripe
D Left Front Speaker (-) Purple White w/ Black Stripe
E Ground Wire Black Black
F +12 Volt Ignition Wire Gray Red
G Power Antenna Wire 1 Blue (join wires 1 & 2
H Power Antenna Wire 2 together to this blue wire)
I Do Not Use
SMALLER CONNECTOR
J Right Rear Speaker (+) Red Purple
K Right Rear Speaker (-) White Purple w/ Black Stripe
L +12 Volt Battery Wire Blue w/ Yellow Stripe Yellow
M Left Rear Speaker (+) Black Green
N Left Rear Speaker (-) Yellow Green w/ Black Stripe
Dec 02, 2009 | 1996 Geo Prizm
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
Audio wirig diagram
Car Radio Constant 12V+ Wire: Blue/Yellow
Car Radio Ignition Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Stereo Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Aug 09, 2009 | 1993 Toyota Camry V6
Need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
May 31, 2009 | 1995 Mercury Villager
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
Wiring a new radio in 1991 ford explorer
Right Front:
Right Rear:
Left Front:
Left Rear:
Right Front:
Right Rear:
Left Front:
Left Rear:
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
JVC KD-G210 CD Player Logo
274 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
