Question about Maytag Washing Machines
Where is the lint filter so I can remove the lint?
  • gillville482 May 11, 2010
    It is in the dryer.
  • 22 Answers
Lint filter not accessible
Posted on Sep 08, 2009
Lint buildup on clothes also in front of lint filter
Remove the filter and see if lint is building up below it. If so, make sure to thoroughly remove all you can. Make sure the filter itself is also clean and empty after every single load. This can ruin the machine if it gets too bad.
Sep 23, 2013 | Crosley CDE6000 Electric Dryer
How do you change lint filter
Hello ccparish8 - Base on the model listed above on the post, washer GLWS1339EC does not have a lint filter or any of Frigidaire washing machines. However, if you are referring to replacing the lint filter on a dryer, simply remove the lint filter from the housing and reinstall in the same manner.
Feb 24, 2013 | Frigidaire Gallery GLWS1339EC Top Load...
How many lint filters does an estae dryer have? I know one on top is there another one?
There is only one lint filter on this model dryer. there is however the lint filer housing hat the lint filter goes into that is accessible by removing the back cover and then removing the screws at the lint screen opening as well as the screws at the lower section of the round part of the housing. if something fell into it you may have a chance of removing it from the lower housing area before the blower assembly by removing the back and the lint filter housing.
Good luck with this and let me know if you have any further questions!
Jul 25, 2010 | Estate TEDX640JQ Electric Dryer
No lint in the lint filter
no lint in the filter,,the brand of unit will help thoe, maytag check for obstuctions at the filter like a sock,,whirlpool check thevent to see if it is crused,,,on all dryers you can try this,,remove vent hose and turn unit on at the base war hose was removed you must have a good stream of air flow,,,if you do then check the vent hose in the wall and out doors at the exit point as well, if you do not have a blockage you may need a repair tec www.myabcspace.com/washerwizzards
May 15, 2010 | Whirlpool LER5636P Electric Dryer
A PEN WENT DOWN THE LINT TRAP AND NOW THE DRYER WONT TURN ON. KENMORE GAS DRYER
can you move the drum by hand?if not the pen is jammed in the blower wheel stopping the motor from turning,if the filter is on top you'll need to remove the filter,take out the 2 screws in front of the filter now make sure the dryer is on a flex line so you can pull it forward to remove the lint filter and then remove the back panel,now you need to remove the 4 screws holding the duct on that the filter slides into and remove the pen and any lint that's in the duct,if the filter is inside remove the bottom panel,remove the filter and take off the duct and clean it out,next time send model number
Feb 15, 2010 | Kenmore 73952 Gas Dryer
Want to remove the lint basket that the filter
your best bet is to remove the front panel of the dryer and pull the front drum/blower duct assembly off the machine. You can then fully access all areas of the duct and also clean all the lint build up inside your dryer.
Nov 27, 2009 | Cars & Trucks
Remove lint holder on ge front loader dryer
I have the exact same problem. I am amazed at had been the engineering is for such a simple process. The user guide just says to clean the lint filter. Even when doing so, there is still an excessive build up of lint beyond reach. There are no instructions that mention how to clean this part. It is obvious that GE did not test this part of the machine.
Jan 30, 2009 | Zanussi ZWF1440 Front Load Washer
Hi, I have a Maytag gas Dryer, Legacy series, heavyduty. I clean the lint filter each time used but there is still a build up which I cannot get out unless I remove the filter housing. How do I do this?
you do not have to remove the lint housing all you have to do is go to an applaince store and ask for a lint brush you then take the lint brush and shove it down where the filter goes to loosen the lint turn on your dryer and it will blow it outside
Dec 26, 2008 | Dryers
I own a whirlpool gold dryer about 4 years old. I empty the lint catcher frequently. I noticed however, that sand has accumulated inside the dryer, I hear the sound when the dryer starts tumbling. How...
not as hard as it will sound here we go
remove the 2 phillips screws at the filter housing top you will see these screws after you have pulled out the lint filter
unplug the dryer
on the left side is the lint filter housing it is held in place with 4 1/4 inch screws remove them
lift up on the filter housing and pull forward you will find the sand inside the filter housing use a vac to **** it out and reassemble the dryer, no more sand
Apr 26, 2008 | Dryers
Washing Machines Logo
164 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
