Question about Roper Dryers
No heat coil not heating my dryer is electric
  • Controlfrk
    Controlfrk May 11, 2010
    Model number needed-Located inside door.
  • 304 Answers
Unplug unit and turn off gas if gas model. Check to be sure you have 240 Volts at wall outlet.
Most parts likely to fail on Roper electric dryers are inside the rear cover. Heater is on right inside can, safety thermostat on lower left of can, High limit thermostat (non-resettable) higher left of can. On the blower housing to the left are the operating thermostat and, in some models, a thermal fuse (white plastic). ALL can be continuity checked easily. Always disconnect wire on one side of what you are testing. One will likely be open. Replace the component that fails the continuity test.
Posted on Sep 08, 2009
I have a beko dcu9330 dryer givin n heat. changed blown sensor and tested both sesors, still no heat, no power getting up to heater. whats next step?
Electric dryers have a heating coil over which air is drawn to heat it up. Unplug your dryer and use a continuity tester to check the heating coil for breaks. Attach one lead to one coil terminal and the other lead to the opposing terminal. No reading indicates a burned out coil (very common). All coils are replaceable.
Oct 22, 2014 | Dryers
Electric dryer not heating. I checked the thermostats and heating coil. Coil reads 9-10 ohms and thermostats read 0 ohms.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 02, 2011 | Dryers
My dryer stopped heating but still goes through the cycles.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 11, 2010 | Whirlpool LER5636P Electric Dryer
Trying to check if the heater coil is bad. Is there a resistance across the coils?
Yes you should get resistance across the coil...it will vary from coil to coil....
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My kenmore elite electric dryer inconsistantly starts to heat and
heatman101
Jul 27, 2010 | Kenmore 63942 Dryer
WONT HEAT, DRYER WILL TURN BUT WONT HEAT UP.
Sounds like your problem may be with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Oct 13, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore electric dryer heat stays on when door open
Sounds like your thermistor/thermostats could be your problem.
They control the heat coming from the heating coil.
Unplug the dryer.
If you remove the back of the dryer, look for the air tube coming from the blower to the drum, normally inside the air tube you will find the heating coil and the thermistor/thermostats. Replace as needed.
Good luck,
Hope this helps
Oct 05, 2009 | Kenmore Dryers
Won't heat
You did not say if you had an Electric or Gas dryer.
My expertise is with Electric Dryers.
If you have an Electric Dryer then you problem is probably the heating coil or thermostats.
Unplug the dryer.
To check them remove the back of the dryer, locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and thermostats.
Remove the wires from the heating coil. Use a continuity meter on the two terminals to check for continuity...if you do not show continuity, then the heater coil is probably faulty.
Good luck,
I hope this helps
Electric dryer heat coil off mid cycle
You have 3 thermostats. By the description of the problem it sounds like it needs a new high limit thermostat. All 3 thermostats and the heating coil can be checked with an ohm meter. Also check the ground on the heating coil. It could be grounding it's self out.
Jan 16, 2009 | Kenmore 62602 Electric Dryer
No heat
The dryer complaint of "No Heat At All" can be a couple things for a given gas or electric dryer. (Keeping in mind; Insufficient "too long" to heat is a different type of complaint)
Defective Ignition Systems
For Gas Dryers; Thermal fuses (white - very likely), Gas valve coils (black; battery size; likely), Thermal Sensors (black, square; rare, but likely) and also Electric Ignitors (Glows red; likely) are very common for "no heat" complaints.
For Electric Dryers: Hi/low limit cut-off switches (Very likely) and electric heating element/coils (Likely) are very common. Also, tripped breakers for electric dryers (Very likely; may only be receiving 110v instead of the 240v needed)
With respect to your dryer vent-line; the line may be clamped down too tight. You may need a 1/4 screwdriver to loosen and remove (assuming it is not taped down)
-C
Jan 14, 2009 | Kenmore 659 Electric Dryer
Dryers Logo
66 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
