Question about GE Profile JS998 Kitchen Range
GE JS998 Display Dead - No Oven Light
I have the exact same problem with my stove - over night the display went dead - no oven light either when the door is opened. What is the part number of the power board that is mentioned. Any tips on how to replace it? Thank you!
  • 2 more comments
  • Brian Manke Sep 12, 2009
    The main power board is the problem. The power board is part number WB27T10551. It is located on the RH side under the glass top. It is kind of a pain as there are a million wires and these plastic retainers that hold the board in that need to be replaced. The part that fails on the board is transistor TOP247Y. It's the one with the big aluminum heat sink. I know because half of mine was missing. Just take alot of screws out and be careful - it is not to hard of a repair.
    Brian
    It is the power board - part number WB27T10551 located under the glass cook top on the right hand side. The part that fails is transistor TOP247Y located on the big aluminum heat sink. Mine was cracked in half. Lots of screws to take out - take your time it's tough to work on as you cannot lift the top off without disconnecting a million wires - just prop it up with a board and you'll be fine.
    Brian
    Brian
    just prop it up with a board and you'll be fine. The board is tough to get out with all the one way plastic clips just take your time releasing them one by one while pulling up.
    Brian
fridgetech
  • 473 Answers
SOURCE: Oven goes into Hyper Hot Immediateley?
It's either a problem in the board or one of the elements is shorted to ground.  Most likely one of the relays on the board is bad so the board would have to be replaced.  If you have a multimeter you can check this.  Unplug the range and take the back panel off to get to the elements.  Take one wire off of each of the elements. Set meter to ohms to check resistance.  Put one meter lead on one end of the element (where you disconnected the wire) and the other lead to ground.  If that shows resistance then the element is shorted to ground.  Do this with both elements.  If neither element is grounded then replace the oven control board.
Posted on Oct 10, 2007
  • 1314 Answers
SOURCE: Wall Oven No Power
yes the oven thermal fuse blew when the fan went off its also called a tco switch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
Posted on Jan 30, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE microwave/convection oven JVM1790SK.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos of your interior if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's likely a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Sep 27, 2008
MNTECH
  • 1543 Answers
SOURCE: Burners, oven will not heat, all lights work
Sounds like you are only getting 120 volts. All heating elements require 240 volts to operate. Start by taking the covers off the back of the range and looking for loose or burnt off wires. Look first at were the range cord connects onto the range. If all OK with range wires, check wires inside range receptacle (where the range cord plugs in) and also the connections on the household circuit breaker or fuses. If you use a meter to test for 240, you may see it, but if a connection is poor, it may not be good enough to supply the required power.
Posted on Oct 02, 2008
  • 111 Answers
SOURCE: Lost power, now oven won't work and display shows "FFF"
I didn't catch the first line in my first response "Lost power, now oven won't work and display shows..." I am 99.999% sure when the power company restored your power they hit you with a surge that wiped out the low voltage transformer on your ERC (main oven control board). Call your power company and report it. I doubt they will cover the cost to repair but they should! Can't hurt to ask and have them file a claim
Posted on Dec 18, 2008
The power went out and when it came back on our stove is not working. No lights on the display. The stove is dead. Is there a way to reset the oven???
Did you trip a breaker. Try to flip the breaker switch that goes to the oven. You may have to flip all the switches and flip them back on to get the correct breaker switch.
Jun 14, 2017 | Kitchen Ranges
The display and buttons are dead, no display or oven lights but electric starter still works on stove top
find the breaker for the stove and turn it off for 2 minutes then back on, if that does not work look on back of stove in area of controles for a small reset button, some time they are hidden just inside a small hole
Jan 09, 2014 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Unit went dead. No fan, display, light, oven. Is there an internal fuse or reset?
There is an internal fuse. Be careful high voltages present even if the microwave is unpluged.
Good luck
Jan 03, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Reset clock and oven light came on flashing
THERE IS A PROBLE WITH THE ERC (CLOCK) NOT TO SURE IF I WOULD USE IT EITHER. THE PART IS EASY TO CHANGE JUST TURN POWER OFF AT THE BREAKER FIRST. YOU CAN FIND THIS PART HERE.
http://www.searspartsdirect.com/partsdirec
Apr 22, 2010 | GE Profile JTP18 Electric Single Oven
Wall Oven No Power
Jan 30, 2008 | GE JKP30WMWW 27" Built-in Single Electric...
The touch pad panel on stove is blank
on the ge range, you need an ERC its the main control for the oven. yes its costly. comes in a kit with a new wire harness
Nov 16, 2007 | GE Profile JGSP48 Gas Kitchen Range
GE Profile JS998 Kitchen Range Logo
121 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
