Question about AT&T Palm Centro Cell Phone - White
My centro will call out & recieve but no voice can be heard comin
For no reason either, one second it was fine the other not so much
2007 Mercury Milan won't shift out of second gear for some reason. It shifts into second fine but that's it. What could be the problem?
Have you had the control module scanned for fault codes? If not do that first. Also I bet you have a check engine light on.
Jun 25, 2016 | Mercury Cars & Trucks
What's a fair price to repair a light bulb on 440QE?
Linda, The light bulb can fail for a number of reasons. If the power board has had the output transistor for the lighting circuit fail the 600.00 is reasonable. I would get a second opinion. Impossible to diagnose by email.
Oct 09, 2014 | Sewing Machines
My 2002 Chevy venture van will not shift from second gear. It goes in first second and reverse fine. What could it be???
Time to rebuild the transmission,for any number of reasons
Usually people never change trans fluid at all or every 3 years
as required
Then you have a tran that is 12 years or older,so it's worn out
May 22, 2014 | Cars & Trucks
Unable to be heard when I answer or try to talk
the mic connection with the main board is liose contact just hit the mic portion and you will see that ur voice is audible and best would be to get the mic fixed or changed
Apr 16, 2010 | Helio HERO Cellular Phone
My palm Centro is having problems sending/recieving texts, and takes a long time to do it. i have full service...
Make sure that the memory isn't very full and that there aren't many programs running. Try a soft reset, I've never done it on a Centro, but Google will tell you.
Feb 17, 2010 | Palm AT&T C/PHONE PALM CENTRO S64801
Centro will not send or recieve calls or emails, shows no incoming signal (at&t)phone comes on all apps seem to work just will not send or recieve
if you don't card what you have in your phone, just try to hard reset your phone (everything will gone, and setting will be taken)..........
unless your phone has problem, then you should be fine.
make sure that you are using a AT&T SIM card (or you can ask anyone who using ATT service, then try their sim card)
Dec 29, 2009 | Palm Treo 500 Centro
Car will not shift out of second gear. while driving it shifts fine to second gear from first gear but it stays in second gear the entire time driven
it is going in limp mode,
if your speedometer is not working will cause this,that would be a speed sensor,or the other two reasons would be the input or output sensors on the tranny
Nov 29, 2009 | 1994 Chrysler Concorde
AT&T Palm Centro Cell Phone - White Logo
61 people viewed this question
Top AT&T Cell Phones Experts
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
