Question about Frigidaire Affinity ATF7000E Front Load Washer
Front load washer, will not do final rinse
Even though the washer will rinse, sudse and agitiate, it will not do a final rinse or spin/drain. To get the detergent out we have to put it on Rinse/Spin after Normal wash mode. While that gets the detergent rinsed out, the clothes are still water-logged. There isn't visible standing water in the drum, but it is right below the drum at the end of the cycle. This is a new onset problem and have confirmed that the hose is not kinked or clogged. We did, however, get told that the drain was actually 60" off the ground rather than 42". Even though this has been fixed the rinse and drain problem is still there.
    Problem Solver:
  • 14 Answers
A lot of times it is the strainer clogged at the pump. Hope that helps.
Posted on Sep 11, 2009
    Sergeant:
  • 389 Answers
There might be a blockage in the pump or filter take the filter out have a look first if ok then the blockage might be in the pump or hose could allso be a sock stuck in the drum drain outlet dont forget to disconnect power before checking
Posted on Oct 16, 2011
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
How do I repair my Whirlpool Ultimate Care 2 LSQ9549L Top Loader Washer?
check the motor coupling,if the coupling is broken you'll hear the motor run but the agitiator won't move and no spin,the coupling connects the motor to the transmission.watch this video
http://www.youtube.com/watch?v=9K1KHEogf3c
May 30, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
What does LE mean?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Nov 28, 2010 | LG WM-2277HW Front Load Washer
We keep getting an f35 error on our Kenmore Elite front load washer. Even when we try to restart the load (no soap to rinse it) the SUDS and f35 errors come up. Any suggestions? I don't see f35 in the...
First of all, be sure you are using only HE detergant. Your drain filter is likely clogged and needs cleaned. On the front lower panel of the washer, remove the screws and panel. You will see a drain filter (about the size of a tennis ball). Before removing the drain filter you are going to need to hand bail the water out of your drum or all the water will run out when you remove the drain filter. Slid a plastic trash back up under the drain filter to help contain whatever water you could not bail out by hand. Remove the drain filter and clean it thoroughly. Replace the drain filter, replace the lower front panel and run a rinse and spin cycle. If sudsing error continues and you are using HE detergant, you may need to lower the amount of detergant you are using. However, 9 times out of 10, it is just the clogged drain filter.
Nov 26, 2010 | Kenmore Elite 45986 Front Load Washer
I keep getting a code le why?
this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Has a large load size been used with a gentle wash setting
Has the washer been overloaded?
Thank You
Sep 10, 2010 | LG WM-2277HW Front Load Washer
How do I drain the suds from my washer mid cycle
Try canceling the cycle and let drain. If the machine is locked out and will not allow you to start a drain try unplugging the machine for 30 seconds then plug it back in. Turn the power on and push cancel/drain. This should let you take the clothes out and start the rinse/spin clean out.
This machine is designed to use HE detergent which is low sudsing if used in the right amount. If the wrong detergent or too much is used sudsing and possibly an error code of SUDS may occur.
Once you have removed all the suds I would recommend running a cleaner such as Affresh or Smelly Washer to remove any suds residue.
Apr 20, 2010 | Maytag EPIC MFW9700S Front Load Washer
Suds will not spin out. What can I do?
You can run a rinse/spin cycle to help clear the suds, you might have to run this cycle several times until the suds are gone.
If the machine is locked out and will not allow you to start a cycle, try unplugging the machine for 30 seconds then plugging back in. Turn the power on and push cancel/drain. This should let you take the clothes out and start the rinse/spin clean out.
Once you have removed all the suds I would recommend running a cleaner such as smelly washer or Affresh through the machine to remove any hidden residue from the excess soap.
Always use HE detergent in a front loader
Apr 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Have samsung silvercare front loading washer....received and error code of ND what do I do?
"ND" means "Not Draining". I have the same washer, and when I get this problem, it's usually because I've tried to wash something that is causing over-sudsing (like a bath robe that was previously washed in an inefficient washing machine which left a lot of soap behind).
I find that turning the machine off, then selecting "Rinse and Spin" works. I suppose if it's a serious Not Draining problem, it could be that the drain hose is clogged somehow -- start by making sure they're not kinked.
Jul 20, 2009 | Samsung WF337AA Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
274 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
