Question about Garden
High pressure Jet sprayer Mh 1300 Need part inside. Is there a parts list?
  • 855 Answers
You can get parts at tmeinc.biz/xjetspray.htm
Good luck you should be able to get what you need there.
Posted on Sep 08, 2009
  • Ronald Park
    Ronald Park Sep 08, 2009
Need a pressure regulator valve for my old hidromac 1300 pressure washer Brass - complete and fits under the black knob.
I found a parts list online in a few seconds. If its a McCulloch item then try a dealer with the part numbers. I just stuck in Hidromac 1300 on Bing and up it popped a few lines down, an exploded parts 2 page doc.
May 20, 2015 | Garden
Operating manual for campbell hausfeed paint sprayer # DH -3000
I found manuals/parts lists for your model sprayer at www.chpower.com, a Champbell-Hausfeld website. Under the 'service & support' tab, select 'manuals/parts lists' and do a search on your model.
Apr 17, 2014 | Campbell Hausfeld Air Tools & Compressors
I have a SOLO 461 sprayer. After months of good service, the pressure from the spray jet drops after a few seconds of spraying. If I close the trigger, then re-open it, the spray again lasts just a few...
if it is a diaphram style replace diaphram if it is a piston style replace piston how to's are easy on both just take ur time and pay attention to removal process
Jan 15, 2011 | Solo Sprayer Parts Shutoff Valve Assembly
Sprayer will not stop pumping when switched to pump mode after primed it will not shut down it just keeps pumping. .
Paint sprayer.
Flip lever down to prime > paint comes out small plastic hose.
Flip lever up to put pressure on spray line.
Problem: prime keeps running and spray line never gets pressure.
Future solution:
You did not clean sprayer very well last time, or it is rusted. When cleaning, run full 5 gallons of cleaner through machine twice.
You should fill spray line and pump with kerosene if machine sits idle more than few days.
We all forget.
Good news: you have prime. If machine doesn't prime, you probably have to disassemble.
More good news: There are two steel balls inside pump. Tap top one with hammer to loosen. Keep machine running. Keep lever up. Start tapping top one. Tap a little harder... keep tapping ... sometimes it will not free up ... take apart pipe and see if you can nudge ball loose >> be careful not to scratch anything... the sprayer is high pressure and all parts have to fit
Oct 07, 2010 | Garden
How do you get pressure into the sprayer. I have pumped and pumped nothing seems to happen
IT'S AN INTRINSIC FAULT WITH THIS PIECE OF JUNK. THE DIAPHRAM INSIDE THE PUMP TUBE IS ABSOLUTE GARBAGE, THEY DON'T EVEN WORK PROPERLY WHEN BRAND NEW, BUT AFTER A FEW MONTHS THEY WON'T PRESSURISE AT ALL. BUY A QUALITY SPRAYER, THAT REPLACEMENT PARTS ARE AVAILABLE FOR.
Jul 23, 2009 | H.D. Hudson 1 Gal Poly Deck Sprayer
Sprayer leaking from inside handle mechanism
although it is possible that the spray head has gone bad, it is more likely that the diverter mechanism inside the kitchen faucet needs replaced. When this part is defective, it allows full pressure from the faucet to go to sprayer head even though the sprayer is not triggered. The sprayer is not designed to handle full pressure when it is not spraying.
Jun 05, 2009 | Price Pfister Marielle Kitchen Faucet with...
Printer printed paper with crushing sounds, but
You need to continually press the paper feed button (next to power) while applying gentle pulling pressure to manually feed the paper all the way through the printer. Hope this helped
May 09, 2009 | HP LaserJet 1300 Printer
Windshield Water Spray
pull hose off sprayer and check for water pressure if pump is pumping water then jet is blocked use a small sowing needle in the jet to unblock jet dirty water blockes them get someone to hold the swich down while u do this wear saftey glasses when u do this u dont want dirt in your eyes
PLEASE RATE THIS HELP
Dec 16, 2008 | 2004 Acura MDX
Free HP LaserJet 1300 Printer Driver
i don't have priter driver for HP Laser Jet 1300 printer, can i download it, how to download it?
Dec 24, 2007 | HP LaserJet 1300 Printer
Maytag jet clean model#dwc7400aaw
Check to see in you have enough water in tank. The dishwasher fills then recirculates this water under pressure. If you have water in tank, listen to see if motor is running or not. If it is, you may have clogged jet holes in the wash arms.
Jul 31, 2007 | Maytag MDB9600A Jetclean II Built-in...
Garden Logo
195 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
