Question about Kodak EasyShare P850 Digital Camera
Is it possible for the slot for the sd memory card to burn out? I was using my camera and I smelled something burnt and my pictures would no longer save to the sd card. I have tried several cards and it appears to be a problem with the camera. Any suggestions on how to fix it.
    Problem Solver:
  • 17 Answers
Its very uncommon but it can happen. Sounds like the slot is fried. Its more expensive to fix than to replace.
Posted on Sep 08, 2009
Memory card error
Card errors can occur from time to time. Special, when you remove the card while the camera is still switched on. If you have (or think to have) important pictures on the card, please first try to save them. There are special recovery programmes. Several memory card manufacturers do have them. Some other firms also promote them online. To be sure you still have pictures on the card, you could save, find a recover program and most of the time you can use it to recover a few pictures for free. If the program can't find any recoverable picture, you also don't need to buy the program. If there are no pictures on the card, toy can format the card in the camera. If that is also not possible, check if the card is locked. SD cards do have a lock switch. Also you should check if all the contacts of the memory card and in the cameras memory slot are clean and there is no dust or debris in the memory slot.
Nov 26, 2013 | Panasonic Lumix DMC-FX9 Digital Camera
How can i transfer pictures from acer iconia to memory card
This Tablet Personal Computer [PC] takes Micro Secure Digital [SD] Cards. To transfer pictures from a Digital Camera to this PC, if the Camera also takes Micro SD cards, is simply a matter of removing the Micro SD card from the Camera and installing it in the PC's Micro SD Card Slot and then waiting for the PC's AutoPlay function to serve up the photo files stored on the card, which can then be Dragged and Dropped into a photo folder on the PC.
If the Camera takes SD Cards, then a Micro SD to SD Card Adapter is required so that the PC's Micro SD Card can fit in the camera before pictures are taken and then disconnected from the adapter afterwards, for re-insertion in the PC.
If the Camera takes a different type of Memory Card, then a Multi Card Reader might be required, which would be connected to the computer's USB Port and the Memory Card slotted into its matching slot in the Card Reader.
See Acer Iconia Tablet PC Specifications here (or on similar specification pages):
http://www.amazon.com/Acer-A500-10S16u-10-1-Inch-Computer-Aluminum/dp/B004XZL980
USB MULTI CARD READER
MICRO SD CARD TO SD CARD ADAPTER
Nov 29, 2011 | Acer Iconia A50010S16u Tablet Computer
Hello, My digital camera is Pentax Optio E30. After taking photos I tried to download them to my netbook using the SD card slot. I inserted the memory card into the slot but no files appeared but when I...
Pretty cool that the newer computers are coming with an SD card slot. However the computer looks at this as an external hard drive and I don't think the pictures are just going to automatically pop up on the screen. You will need to go find the "drive" click on the folder and open, once you have the pictures open you can select all copy and then create a folder on your computer hard drive and paste the pictures in that. Once the pictures have transferred do a safe eject of the SD "drive" and remove the SD card. Don't forget to do a format to the card once back into the camera.
Apr 05, 2011 | Cameras
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and...
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
Jan 27, 2011 | Kodak Cameras
Have an HP L7680 all-in-one Just received a Panasonic Limuix camera and cannot read the SDHC memory cards in the SD slot - Printer posts an error
No, it's not possible, it'll never read SDHC in the SD slot. SD slot will only read SD, Mini SD (with adaptor) and Micro SD (with Adaptor). If there's no SDHC card slot, then it doesn't support SDHC Card. The lists of supported memory card are listed below:
CompactFlash™ Type I and II,
Secure Digital/MultiMediaCard/Secure MultiMediaCard (SD),
xD-Picture Card,
Sony Memory Stick®,
MagicGate Memory Stick,
Memory Stick Duo,
Memory Stick Pro
I hope this clears your doubt.
Note: SDHC and SD are different Memory Card types.
Good luck.
Thanks for using FixYa.
Sep 21, 2010 | HP Officejet Pro L7680 All-In-One Printer
How to import pitcures using an sd card on acer laptop
you should be able to use windows explorer to find the memory card - it will be listed as another drive on the PC - most cameras will save the images into sub directories on the memory card - depending on how many images are save you may have multiple sub-directories. you should then be able to copy the images off the card onto the PC. goto Start>computer and see if you have the card listed - even without a card inserted, you should see the drives - possible called - SD/MMC and or memory stick - depending on what memory slots you have
Apr 10, 2010 | Acer Aspire 3618AWLMi Notebook
Wot is the memory card slot for
HI,
The memory slot is an expansion slot that you can put a camera card (SD card) into so you save all you photo's to that instead of the internal memory.
This is because your camera only has a limited amount of internal memory limiting you to the amount of pictures you can save on the camera.
Purchasing a memory (SD card) is certainly an advantage and they can be used in card readers, MP3 players and computers etc.
Regards.
Sep 14, 2009 | IT Works Cameras
My computer does not recognize my SD 2GB SD Flash Card which I insert into my camera and take pictures. I have a slot on my computer for SD cards. Can I just put the card in the slot and access the...
yes you can directly use the SD card slot, make sure you unlock the write protection before inserting it into the slot if you wish to modify or copy the contents from or to the card.
Jun 24, 2009 | SanDisk 2GB microSD Memory Card
Problem in reading memory cards of NIKON D80
Some notebooks cannot read SD capacities of 4GB and above. The workaround is to use an external SD card reader.
NOTE: Please rate our help to keep this free service online
Apr 22, 2009 | Nikon Coolpix 5700 Digital Camera
Camera will not longer download pics
It might be worth it to simply buy a SD memory card if you have a SD card slot in your computer. You can download pictures taken from any camera if using a SC card since you actually download from the card. You can also take the card to any WalMart, Walgreens, CVS, etc that has the photo machine.
Mar 10, 2008 | VistaQuest VQ-5015 Digital Camera
Kodak EasyShare P850 Digital Camera Logo
49 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
