Question about Polaris Pb460 Polaris Booster Pump Replacement O - Ring
How do I take a booster pump apart to replace the motor?
    President:
  • 1,378 Answers
Pull the back cap off the motor and hold the shaft as you spin off the impeller. The rest is straight forward enough.
Posted on Sep 08, 2009
My polaris booster pump just gets hot and wont run
the motor is bad overheating need a new booster pump
Sep 08, 2014 | Polaris Pb460 Polaris Booster Pump...
Pump overheating
check wiring if wired 120 volt see side of motor
Jul 07, 2013 | Polaris Pb460 Polaris Booster Pump...
New polaris pb4-60 booster pump shuts off when polaris recycles, why?
sounds like weak motor the back pressure is overheating the motor replace
Jul 14, 2012 | Polaris Pb460 Polaris Booster Pump...
My polaris booster pump noise
bad motor due to bad seals leaking on motor better to replace whole pump next time
Jun 03, 2012 | Polaris Pb4 - 60 Booster Pump
My booster pump is much louder than last year. Can you oil it somehow
PLEASE DO NOT TRY TO OIL THIS, IT HAS A START SWITCH INSIDE THE MOTOR, IF IT GETS OIL ON IT IT WILL NOT ALLOW THE MOTOR TO START. AND CAN CAUSE THE MOTOR TO FAIL.
SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP REPAIR GUY, COST AROUND 125.00 TO REBUILD ONE OF THESE MOTORS. USE UTMOST CARE WHEN REMOVING WIRES FROM THE BACK OF THE MOTOR !
POOL PUMP MOTOR HAVE SEALED BEARINGS, THERE IS NO WAY TO OIL THEM, THEY NEED TO BE REPLACED. I DON'T RECOMMEND WORKING ON A BOOSTER PUMP, THERE A HARD ONE TO FIX .. SORRY .. JAY .. THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FL
Jun 04, 2011 | Polaris 280 In - Ground Pool Cleaner with...
During cold weather spell pool pump was pretty much staying on, as much as 24 hours a day, for 3 -4 days, and during that time the booster pump was set to turn on for 3 hours. Apparently one of the hoses...
what may have happened is the pump seal has run hot a welded together preventing the motor from running
that would hav tripped the thermal overload if it has one or the start run capacitor may have failed
pull the pump apart and if it is just a seal it is around $30.00 to replace
if you do not have the knowledge to fix it , take it to a pump shop and get a proper diagnosis and quote before replacing the unit
May 21, 2017 | Hayward 6060 Pool Cleaner 34 HP Booster...
Hello I am replacing switches for my pool. there are two pumps,one is basic recirculation and the other is a booster. The origional switches disintegrated when I removed to cover so no history of how it...
Well, motor starters are usually used in that scenario. I suspect that is the reason the switches fell apart (too many amps). As long as the pump motors aren't over 1 HP each and you are using DPST 20 amp switches rated for 2 HP,(still not best practice) here's how to wire them:
Connect the 2 incoming 240 volt wires from the circuit breaker to a screw on each side of the _top_ of switch #1 (main pump). Connect a pigtail to one screw on the bottom of switch #1, then twist that pigtail together with another pigtail and one of the outgoing wires to the main pump. Connect the other pigtail to the top of switch #2. Repeat for the other bottom screw on switch #1.
The outgoing wires to the booster pump then go to the bottom of switch #2.
Dec 30, 2009 | Dynamo ABOVEGROUND POOL PUMP - 3/4HP -
I have an Intermatic pool pump timer. The motor for the clock is running, but the on of switch will not trip. I made sure the stop/start pins are properly on. I did recently replace the switch below for...
If the motor doesnt have enough power to trip the switch you will have to replace it. The motor assembly is replacable without having to replace the whole box. I know you can get them at Lowes and Home Depot.
Sep 25, 2009 | Intermatic T104 24h 208-277v Mechanical...
Polaris Pb460 Polaris Booster Pump Replacement O - Ring Logo
138 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
