The screen is too bright for me, and I can't read the words above the tabs that are on the rim. How do I make it dimmer?
  • 530 Answers
I'm not sure what monitor you have but most monitors have buttons along the front or front bottom that give you access to the adjustments for things like brightness and contrast. It also allows you to shrink or enlarge the screen so you can see the entire image. If you can't located anything on the monitor re-post here with the brand and model of monitor you are using.
Hope this helps.
Posted on Sep 08, 2009
Re Clarion radio screen brightness, I have retro fitted the radio to another vehicle but the wiring diagram doesn't mention a dimmer. Do I need to hook one of the wires into the headlights?
One of the wires on the radio is for the brightness. Connect this wire to one of the dash lights that dim with the dimmer control or the headlight switch dimmer if your vehicle is equipped that way.
Sep 12, 2016 | Cars & Trucks
Screen keeps getting darker
Click on Settings>Display>General:
1) Brightness>Uncheck Automatic brightness, set the brightness you desire and tap OK.
2) Back to General> Screen timeout>Select a time greater than 15, 30, 60+ second/minutes. Personal preference is 30 minutes when watching movies, videos, or reading.
Sep 23, 2014 | Samsung Galaxy Tab 101 Tablet...
How do I adjust brightness level on reading page of my kindle app
Fixing the brightness of your screen is easy on the Kindle Fire, Kindle Fire HD and Kindle Paperwhite, all of which provide screen brightness controls. This feature is not available on the original Kindle, however, as the screen is not backlit.
Kindle Fire Step 1 Tap the "Quick Settings" icon in the upper right corner of your Kindle screen. The icon looks like a gear.
step 2
Select "Brightness" from the Settings menu. If you don't see it immediately, tap the "More" icon to access all of your settings options.
step 3
Use your finger to toggle the slider from left to right to increase or decrease the brightness of your screen.
Kindle Fire HD and HDX Step 1 Slide your finger downwards from the top of the screen to display the Quick Settings menu.
step 2
step 3
Toggle the slider to the left or the right to fix the screen brightness.
Kindle Paperwhite Step 1 Select the lightbulb icon on your Kindle screen. This icon is present when you're reading a book.
step 2
Move the vertical slider with your finger to achieve the ideal screen brightness.
step 3
Tap and hold the "+" sign to achieve maximum brightness. To achieve the lowest brightness possible, tap and hold the "-" sign.
Jan 05, 2014 | Samsung Galaxy Tab 8.9 WiFi 16GB Tablet
How do i turn the brightness down
Right click anywhere in the blank area of the screen then click on properties the following screen should come upcomputer254_5.jpg
then click settings tab should then see a screen similar to this
Then look for your Graphic card properties for example after clicking Graphics Properties tab the following screen should give then the opportunity to change your settings
The above are some examples taken from my aspire desktop but should help you further resolving your problem with brightness
Hope this solves your problem
Mar 02, 2011 | Acer Aspire One Netbook 8.9" Notebook
Dimmer switch not working,only have low beams and when i hit the bright side they go completely out.
need to replace dimmer switch located above the brake pedal ,left side of steering collum. move dimmer lever to see actuator rod move .you can test switch there
Feb 16, 2011 | 1996 Chevrolet Cavalier
Toshiba M35 S359 Laptop screen brightness
you can try windows up date, or check the control panel, locate display and check the Brightness settings.
It is also possible that part of your screen bulb is dead, that's why one part is dimmer.
But there is no drivers that will make your screen bright.
Take care.
May 28, 2010 | Toshiba Satellite M35-S359 Notebook
Laptop Screen goes dim when plugged in!!!!
Hold down the Fn key then press arrow key up or down.
Aug 10, 2009 | Gateway 450ROG Notebook
Dim light in instument panel at night on my 1989 corvette.
there could be a bad connection between your dimmer switch and the lights themselves. often times through vibration and wear and tear the connectors degrade. check this first. also the dimmer switch itself could be the cause.check all the connections associated with the panel lights, look for loose wires and/or bad connections if there are none replace the dimmer switch
Apr 17, 2009 | 1989 Chevrolet Corvette
Instrument lights too dim on 2008 Saturn Outlook
not sure but you have automatic lights the sensor is on dash on passenger side litttle black button looking thing. It might be covered.. if not just turn on your lights. the insterment dimmer is above radio too...
Dec 23, 2008 | 2004 Saturn VUE
Compaq Presario R3000 dimmed LCD screen
If your inverter is good I,de say your backlight is going bad, I just replaced mine in a sony vaio and now it seams to bright.
Oct 20, 2008 | Compaq Presario Notebook
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
