Did you ever figure out what to fix on the tv.. to clear up the darkness?
Same issue stated above, I opened it.. i dusted it ... cleaned the lens... lined up crosshairs and convergence.. tried every setting, but it just doesn't help with dark scenes.. they are very dark... Dark Night, was painful to watch, and Serenity too.
Comments:
Sep 08, 2009
- G2/focus splitter.. can you tell me appoximate location... I have my tv opened up right now
Sep 08, 2009
- Heres a link to what one of the boards look like http://www.parts-link.com/modules/Wanted/uploads/TNP2AH035.jpg
Sep 08, 2009
Sep 08, 2009
- If it is suppose to look like this
http://www.parts-link.com/modules/Wanted/uploads/220709-1.jpg
I don't see one at all in there
Sep 08, 2009
- So I called panasonic up today, and they confirmed my model doesn't have a g2 / focus splitter, they had me return it to factory settings... and well it still dark, so they had me call a service place, and they said need $90 to come visit and problably need to adjust the grayscale for another $90... can anyone out there save me $200 and educate me on this... Panasonic said all color controls on my model are done via the tv.. I have 1 screen where I have 9 + to align both red and blue too and also one screen for green convergence and red and blue line ups.
THanks..
do you know what a g2/focus splitter looks like? if so and you can get to it, adjust the g2 controls ever so slightly.
Comments:
Sep 08, 2009
- it is usually behind the front speaker/support cover.about 8" x 6" with about wires going in and out. it has 6 adjusting screw slots. 2 for each tube
Sep 08, 2009
- the screen before you get to the convergence should have controls picture, brightness,hue or tint & contrast. A new thought ; does your have a color temp adjust, if so select the cool setting.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Panasonic PT-51HX42 51 in.
Panasonic PT-51HX42 51 in. Rear Projection Television
i was attemptin to remove the main board from the tv to replace the convergence chips, and pulled on...
(More)
i was attemptin to remove the main board from the tv to replace the convergence chips, and pulled on a red wire that appears to be connected to a "distributor cap looking thing" that then broke. it appears that it was soldered deep incide the part. What is this and is it bad that that i did this, will it work by just re-securing it in the "distributor cap thingy" or did I just ruin the tv to the point its not salavageable, or is this part i broke replaceable and what is it called?
i have a panasonic pt-51hx42 and when you turn it on after about 3 seconds it turns itself back off...
(More)
I HAVE A PANASONIC PT-51HX42 AND WHEN YOU TURN IT ON AFTER ABOUT 3 SECONDS IT TURNS ITSELF BACK OFF AND YOU HAVE TO UNPLUG IT AND PLUG IT BACK IN TO GET IT TO TURN ON AGAIN
I have a panisonic pt4743g when I turned it on it sounded like it was comming on, but then just when...
(More)
I have a panisonic pt4743g when I turned it on it sounded like it was comming on, but then just when black. No sound no picture. The power light flashes three times then stops for about 10 second then flashes again three times the stops fpr 10 seconds. Any Ideas?
wavy lines appear across my panasonic 51hx42f screen when i first turn my tv on. picture is...
(More)
wavy lines appear across my panasonic 51hx42f screen when i first turn my tv on. picture is distorted and makes viewing difficult.
