What you might be experiencing based on your symptom sounds like a damaged convergence IC. With any Projection Television that has a damaged convergence IC, you do not want to continue the use of the set. If the IC’s continue to fail they will cause a short in the power supply and cause your television to not power up, and possibly damage the CRT’s in the set. With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you. While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and heat sink compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need. Their site is http://www.andrewselectronics.com/welcome.aspx And their phone number is a 24-Hour Order Desk: (800) 274-4666 I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue. If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed. If you need further assistance please comment to this post and I will try to help you further. Thanks for using FixYa asnowman I have attached some photos of really bad convergence problems; your picture may not be exactly as bad as these.
Hitachi 32fx49b, was watching tv when picture went out, still has sound and some picture. part of...
(More)
Hitachi 32fx49b, was watching tv when picture went out, still has sound and some picture. part of picture is in middle of tv
My Hitachi dinosaur television picture goes off and on for no reason. It goes to a complete black...
(More)
My Hitachi dinosaur television picture goes off and on for no reason. It goes to a complete black screen and then comes back on. It does this periodically. Do you have any ideas? Is this major? Should we just buy a new one. We love this one the picture is beautiful.. We thought it was our satellite system until we hooked up another television to the system.. So now we know it is our television. Oh, and the television shows it is on when the picture disappears. Their is no sound either..just a black screen. No error messages or anything like that. At times it does it when a commercial comes on, then comes back on after the commercial is over.
intermittent sound loss on both internal and external channels. The sound works for a while and then...
(More)
intermittent sound loss on both internal and external channels. The sound works for a while and then just cuts out. Sometimes it comes back when changing between sources; sometimes it does not return until the TV is shut down for an hour or so. Sound usually comes on when TV is first turned on - but not every time. The time before it disappears is random, but it always occurs eventually.
i have a hitachi dlp television model/serial 61swx10b The sound has slowly began to come and go at...
(More)
i have a hitachi dlp television model/serial 61swx10b The sound has slowly began to come and go at random, and at this point will not come back on at all. I only have a dvd player hooked up right now (no cable yet just moved into house) so cannot tell if it is dvd player, however, used to work just fine. only thing i have tried is switching audio inputs (with no luck) and also the sound from my dvd player works fine on my older tube television. If the speakers are blown out (if that is the problem), will a surround sound restore sound. Some insight would be fantastic, Thank you
