Question about Samsung SyncMaster 2233BW 22" LCD Monitor
No sound on my samsung Syncmaster 2233 monitor
    Sergeant:
    Champion:
  • 255 Answers
Check output from computer with another set of speakers.
Posted on Sep 08, 2009
3 Suggested Answers
mace1mace
  • 1138 Answers
SOURCE: I have two monitors. One Samsung SyncMaster 2233
hello Gabriel
Could you check your SyncMaster 2233 for me and tell me your findings. If this monitor is connected from your computer and when both switch on, did the led indication lamp from your monitor lit steady green? or this lead indication lamp lit green then turns red?
1. If the led indication lamp lit steady green then there is nothing wrong with the settings, configurations, driver or hardware on your computer. The problem would be the backlight inverter lamp in your monitor is busted. Or it could be the inverter board that supplies high voltage for the backlight inverter lamp that is bad. You can replace the backlight inverter lamp located at the upper and lower part of the monitor with a replacement part you can purchase at shoppejimmy.com. Inverter board repair can be risky if you don't have the skill. Even opening the back cover of your monitor and replace by yourself the inverter lamp is risky too, could inflict more damage. you can bring it to a local professional service man.
2. If the led indication lamp lit green then turns red, then if not the video card the power supply section from your monitor is bad, you can replace polarized capacitor with same value. Just inspect and those with blown or leaking capacitor. You can also check the terminals and solder joints for the 15-pin vga terminal connector where vga cable is connected on your monitor. Resolder the terminals.
3. If the red indication lamp did not lit at all. Power supply section in the monitor is bad. You can check the output voltage from the power supply section. +5VDC is supplied for the main board and +24VDC is for the inverter board. Replace leaking or blown capacitor with same value.
Just remember, this should be done when computer and monitor is turn off
Post back if you have more questions. I am willing to give you assistance.
Posted on Feb 10, 2011
budmrtn
  • 11361 Answers
SOURCE: how to see the optimum
Native resolution: 1680 x 1050 @60Hz
Resolution adjustment:
From Microsoft: http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_screen_resolution.mspx?mfr=true
and here:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
and here:
http://www.videojug.com/film/how-to-change-screen-resolution-in-windows-xp-and-windoiws-7
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Apr 10, 2011
How do I clean my monitor screen Samsung SyncMaster 2233?
There are solutions available that you can use to clean your monitor.
What I do is using a clean cotton cloth I dip it into small amount of water and wipe the monitor screen with it.
Hope this helps!
Sep 10, 2011 | Samsung Computers & Internet
How to connect television cable and samsung sync 2233
Samsung SyncMaster 2233BW does not support TV / Cable input (RF Connector).
If you wish to connect Cable to the LCD, you have to buy a TV Box and connect Cable with your LCD through TV Box. (Cable TV to TV BOX and from TV BOX to LCD)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
I have a samsung SyncMaster 2233 monitor.. the black colour on the monitor doesnt seem sharp enough.. i mean black is not exactly deep black everywhere, there are some places on the monitor that show some...
I see this monitor was produced in 2008. I guess you purchased it used. As used monitors cost any where from $10 and up I'd just replace it. It just isn't worth saving.
Dec 03, 2017 | Samsung SyncMaster 2233BW 22" LCD Monitor
I have two monitors. One Samsung SyncMaster 2233 an one Samsung SyncMaster 2243. My problem is that the SyncMaster 2233 for some reason is totally black. I'm usually not terrible with these things, but my...
You're using dual monitors and one is black? If so-- when you switch the cables on the monitors.. the same monitor stays black? This sounds like bad monitor. If I understand you right.
Feb 10, 2011 | Computers & Internet
I lost the manual to my Samsung 2233 Monitor. What does each button do.
http://downloadcenter.samsung.com/content/UM/200810/20081022090131859/BN59-00767A-Eng.pdf
Aug 24, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Do I need speakers with my syncmaster 2233 for sound, if so WHERE do I plug them in on the computer?
Yes you do! Simple speakers with one jack plug into the green jack plug connector either on the front or at the rear of your computer.
Nov 04, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
How to hook up speakders?
The monitor does not have output sound since it is only an input device. You will have to hookup the speakers to your device (laptop, computer, gaming console) that you are connecting to the monitor. The speakers in the monitor are ready to receive a signal so that it can amplify it and let you hear it. If you hookup your speakers to the monitor it is the same as if you were trying to hookup two sets of speakers to each other.
If you need further help, reach me via phone at https://www.6ya.com/expert/hugo_f827544e52871d36
Hi, I just purchased a 22inch 2233BW samsung monitor, the label on top "Syncmaster 2233" and right side "50000:1" is a little faded out, is this normal or it means it was used and repackaged? also the top...
I would return it for a New Model.
Ask to see a display model.
The unit should also have a build date on the tag as well.
Its your money. spend it your way. !
Sep 30, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor to black, power LED blinks, hard re-boot and it works
Take a look at your power saving settings. It sounds like the monitor is set to sleep after 20 or 30 minutes. You may want to change your setting to "never". The settings are under Control Panel - Power management
Aug 15, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung 2233 stuck in analog
in your mon there will be small left arror image in box called enter button,,,,if u press that button its shows analog and digital in that have to choose digital.....
Apr 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung SyncMaster 2233BW 22" LCD Monitor Logo
1,238 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
