Question about Maytag Dishwashers
Our glasses are really cloudy. How do we clean the inside of the dishwasher?
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Never let this problem happen again with the dishwasher filter system. it will also help clean out your dishwasher. it removes the hard minerals that cause cloudy dishes and clogged dishwashers. very affordable and guarnateed to work. go to www.dishwasherfilter.com
Posted on Nov 19, 2009
    Scholar:
  • 44 Answers
This may be a hard water issue, but assuming it's not:
Pour 1 liter of white vinager into your dishwasher and run through a full cycle.
If this fails:
Pout 1/2 liter of CLR into you dishwasher and run through 3 full cycles.
N.B. Vinager is preffered as it's non-toxic.
Other possible issues:
hard water, lime/sediment buildup in hot water tank, not using rinse-aids like "jet-dry"
Posted on Sep 08, 2009
There is a white film on the inside of the door plus glasses and utensils.This problem just started a few weeks ago.(the dishwasher is just about two years old). We use cascade and jet dry rinse agent,
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Feb 09, 2011 | KitchenAid KUDS03FTBL Dishwasher
How can I clean my cloudy glasses? How can I stop my glasses getting cloudy?My Bosh model is "Bosh Classixx"
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
Jan 04, 2011 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Glasses in top rack are covered by an opaque film. Seems like the insides are collecting the most. I've tried the white vinegar wash and it worked the next time but the following load was worse.
Dec 18, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
My glassware is coming out cloudy! the dishes are clean but the glasses and some of the stainless steel has a cloudy film Please Help! I am currentyl using a rinse aid and cascade powder detergent It...
Dec 15, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Ditches come out looking very dull, glasses look gray and dull, inside of machine gets a light white film on it, I have been using Cascade in the box for as long as I have had the machine.
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
Dec 08, 2010 | KitchenAid KUDR01TJ Dishwasher
Cloudy glasses
Depends on whether it was scratched or gone cloudy with the steam mist inside.
Use a good bufffer to clean if the glass is scratched.
If you meant the glasses put inside were cloudy and not clean thenit is possible that the jet pump spray does not have pressure and must be taken out and cleaned.
Sep 14, 2010 | Dishwashers
Why do my glasses go cloudy
All glasses eventually go cloudy in dishwashers, the problem is far quicker and more noticeable with lead crystal which specifically should never be washed in this way.
The cloudiness cannot be reversed: it's caused by millions of tiny cracks in the glass surface as a result of both the chemical and physical processes inside a dishwasher. Some products claim to include a "glass protect" function, but it just slows down the damage instead of stopping it. Commercial glass-washers used in bars and restaurants also cause this damage, but as the wash cycles are far quicker and the cleaning agent is specifically for glass the damage occurs more slowly. In any case, glasses don't usually last long enough in commercial use to show this damage as they usually scratch, chip, or break before it shows.
All you can do to totally avoid the damage is to wash glasses manually and to never put lead crystal in the dishwasher. If that's not an option, then you can slow the damage by washing glasses at the lowest possible temperature: you'll find that some cleaning products are better than others at low temperature and it's not always the expensive brands.
Sorry there's no fix for your cloudy glasses, but I hope that I've helped to to avoid further damage. Please take a moment to rate my reply.
Sep 08, 2010 | Miele 24 in. G643Vi Plus Built-In...
My bosch dishwasher has suddenly started leaving everything cloudy, particularly the glasses. The salt is topped up, the rinse aid full, filters cleaned out.
You can experiment with different tablets/powders and check that the salt and rinse aid dispensers are correctly adjusted, but all dishwashers eventually cause glass to go cloudy and although it's a gradual process there's a point at which it suddenly seems to become noticeable. Any lead crystal glass will cloud very quickly indeed so must be handwashed if you want to avoid this. The cloudiness in glass is irreversible as it's caused by millions of microscopic cracks in the glass surface. Some crockery items are glazed with a process which can also turn cloudy over time in a dishwasher, white plates won't really show it but coloured ones do (especially blue and red). There are some tablets/powders which claim to have a glass protection additive, but this just slows down the process. The best way to slow the process is to wash at the lowest temperature you can.
Aug 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
I get a film on the inside of dishwasher as well as dishes at the end of a cycle. You can really see the cloudy film on glasses. Dishwasher is only 18 months old.
Cloudy film is usually from hard water. Or it means the dishes arn't drying properly. you wanna make sure your using jet dry and that your not using liquid soap. Liquid soap is a killer of dishwashers and creates mineral deposits. If you have hard water getting a water softener helps too. Theres a cleaning agent called dishwasher magic that works to clean the dishwasher . You wanna make sure your heater is coming on too.
Jun 15, 2010 | Kenmore Dishwashers
Cloudy glasses!! Drains fine, runs normal, but glass wear never clear any more.
try using affresh youcan buy it at home depot cleans the inside of your dishwasher and they also make another type for your washer machines
Apr 30, 2010 | Dishwashers
Dishwashers Logo
121 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
