Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet fills when off
Can I fix the water inlet valve and the pressure switch be fixed easily by the owner?
  • 10,515 Answers
It's Quite easy.
To test Inlet valve, follow the below guide :-
http://www.acmehowto.com/howto/appliance/washer/check/inletvalve.php
To test the Water level switch/Pressure switch, follow the below guide :-
http://www.acmehowto.com/howto/appliance/washer/check/waterlevel.php
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 08, 2009
Code f 20 what does that mean and how can I fix it.
A possible solution to an f 20 fill error for a whirlpool duet washing machine. Blow out the pressure hose that connects to the pressure switch.
Before doing any of these fixes first ask yourself if you have over loaded the machine. Too many Bulky - heavy items will cause this same message.
How to fix Whirlpool Duet F20 Error:
Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the F20 error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
If water pressure is good, check the water valve inlet screens. Most residential washing machines have inlet screens. The screens prevent minerals from clogging the solenoid. With the hoses removed, you can visually inspect the water inlet screens. If the water valve screens are clear the inlet valve with the screens itself will need to be replaced. To replace the water valve, remove the top of the washing machine. Three screws hold the top down. The screws that hold the top down are on the back of the top panel. Once removed the top will slide back and off. Now remove the wire harness that connects to the valve. One screw holds the valve to the washers cabinet. Removing the screw and sliding the valve over will release the valve from the back panel enabling you to complete your repair.
One last thing to check is the fill hoses. These front load duet washers call for a lot of water quickly. So if you have stainless steel braided flood-safe hoses, they will trip for no reason at all. Replace these flood safe hoses with more traditional hoses.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/#sthash.zTyr5Yy1.dpuf
Oct 16, 2014 | Whirlpool duet Washing Machines
How do I fix F20 code
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/#sthash.2RAhsfLg.dpuf
Sep 19, 2014 | Whirlpool duet Washing Machines
What does whirlpool duet error code lf?
Lf or long fill could be a multitude of many. Is the water turned on, is the hoses kinked , the water inlet screen clogged, water lines crossed, bad or faulty water inlet valve, or faulty pressure switch.
May 01, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the code F H mean? and how can I fix it?
Means no water getting to machine or pressure switch not tripped. Check all water valves are switched on and there is water. If the machine is filling up then flashing FH then it is most likely your pressure switch that is faulty. If there is no water at all then its most likely you water inlet valve. Both of these are easily changed by removing the top panel. The pressure switch is a round part about 2-3 inches and has a thin tube pushed onto it and a wiring plug. The valve is at the top back, most likely if there is 2 hoses then it will be the hot water 1. Hope this helps
Mar 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Model WFW9150WW00 Whirlpool Duet: When the machine is ran with either hot or cold it eventually fills up more than half full of water and then it gets error F8E1 .. which is "long fill - no water or...
I agree. here are some things to check for
• Make sure that both valves at the water source(s) are turned on all the way.
• Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
• Verify inlet valve operation
•If there is water in the unit • Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
•Verify there is not a siphon problem
•Verify wire harness connections to Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter, and Central Control Unit (CCU)
•Check all hoses for possible leaks
•Verify pressure switch operation
•Verify flow meter operation
•Verify CCU operation
Feb 11, 2011 | Whirlpool WFW9150W Front Load Washer
Whirlpool duet washer giving error code FH begins cycle filling with water then stops and only get humming and no more water and finally the error code
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1.Make sure that both valves at the water source(s) are turned on all the way.
    2.Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3.Verify inlet valve operation
  • If there is water in the unit:
    1.Verify Drain pump operation
    2.Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Dec 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WHAT DOES F 20 MEAN?
Hi, The reason for "F 20" is that while there is "NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED." If after 30 seconds not minimum 0.1l of water entered or maximum fill time of 13 minutes is exceeded, the valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display.
The possible fix for this problem is: If there is no water in the unit: Make sure that both valves at the water source(s) are turned on all the way.
Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
Verify inlet valve operation.
If there is water in the unit: Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Unplug washer or disconnect power.
2. Verify there is not a siphon problem.
3. Verify wire harness connections to inlet valves, pressure switch, flow meter, and Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power.
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Apr 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My duet front loader will fill with a large
there are two water valves above the soap drawer, that are sping loaded to stay shut when power is off. if the water pressure to the machine has increased, sat due to an increase in main pressure from the water board fixing a leek further up the supply, then this could force open the valves. try turning the stop valves at the inlet pipe end, away from the machine, down a quarter turn and see if this stops it.
Oct 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer is filling with water when it is off. it only drips, but two days in a row it was filled up above the bottom of the door openeing and spilled on the floor,
This problem is either attributed to a defective water inlet valve, or defective pressure switch. An easy way to determine which one may be causing the problem is to unplug the washer, but leave the water taps on. If the washer continues to fill, you have a defective water inlet valve. If the water stops, I would recommend changing your pressure switch.
Post back and let me know if you require further assistance. I hope this helps you.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f h
The FH code in the owners manual talks of a water supply.The F/H code means the unit isn't detecting water fill at the flowmeter. The flow-meter sits just in front of inlet valve and is attached via a hose, and off to the left of the CCU. If your washer is filling ok, check the wiring from the flow meter to the control board; I've seen this harness jiggle loose and cause problems. check figure for flow-meter location. c3a1d6e.jpg
Or
  • Verify CCU operation.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
May 10, 2009 | Whirlpool GHW9400 Duet Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
254 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
