Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
How to reset a RP2100 pool heater with original pc board
How to reset a RP2100 pool heater with the original year 2003 pc board.
    Top Expert:
  • Raypak Master
  • 7,919 Answers
Up and down button and mode or enter at same time for 7 seconds
Posted on Dec 02, 2017
3 Suggested Answers
john224
  • 1378 Answers
SOURCE: Raypak RP2100 not showing even close to correct pool water temp.
Bad thermistor probably. It is not a very expensive part.
Posted on Jun 14, 2009
  • 8 Answers
SOURCE: Raypak RP2100 pool heater set temperature stuck on 50 degrees
Could be spider webs in the orfices, which would allow the burners not to light.
Could also be a bad thermostat or pressure switch.
Posted on Jun 20, 2009
I need to now how clen a filter on my rp2100 digital
rp2100 is a pool heater by raypak it has no filter. you need to clean the filter whatever type it may be. sand/de filters can be taken apart and the medium takin out and replaced, while cartridge can be taken out and sprayed with a hose and put back.
Sep 28, 2015 | Pool & Spa
Rp2100 main board has a piggyback circuit board attached to it with 2 relays controlling or wired to 2 jandy actuator valves. I upgraded heater to a new raypak heater & have no clue how to rewire with...
The new board may have the actuator relays and connectors on the main board. If so plug the wires in. If that is not the solution then you can call the Raypak technical support line and they may be able to direct you. Good luck.
Aug 11, 2011 | Raypak RP2100 Heater PC Board Control IID...
How can i get a power vent for my raypak rp2100 pool heater
yes if no area on board for fan hook fan if series with firemans switch when fan on heater will work or a air switch
Oct 29, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I get an ILO Fault Code and it will not lite
iGNITION LOCKOUT-turn off main power switch(on side of unit) or breaker controlling power to heater. This should reset board. Happy Swimming
Aug 09, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Bad LCD = Bad PC Board unfortunately...
check grounds to board also check transformer for voltage look for blown fuses
Jun 22, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Jun 19, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
TA6 or tab code rp2100 digital pool heater
yes that tab means you heater pc board is bad you need to replace it the code tab will not be in inside of the heater door with the other codes its only meant form service tech if you need a pc board i can get you one at a good cost 3614619875 durans pool service
May 03, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pool heater will not work
Eol is a manufacturers code meaning End Of The Line. I have never seen this displayed on any malfunctioning heater that I've serviced. Try shutting down the power to unit and resetting the board.
Apr 09, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
61 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
