Question about Sub-Zero Refrigerators
I have a Sub-Zero 700TC/TCI, and it's flashing ''service'' on the LCD display. The refrigerator is freezing liquids such as juice. I tried to make it warmer, but it won't hold. I cleaned the condensor last month, so I don't know what's causing the problem. Any suggestions? The unit is 7 years old. Thanks for your help.
  • roz kay Sep 08, 2009
    Thanks for your response. What are taps?
    Sergeant:
    Champion:
  • 255 Answers
It is low on refridgrent, or condensor is dirty.
if low not much u can do short of installing taps and finding leaks
Posted on Sep 08, 2009
Leaking water
The drain tube under the evaporator in the fridge is clogged. these can only be accessed by removing all the shelves and the light diffuser, then removing the back wall. even then, the hole is tiny and hard to put anything down into to clear the debris. I usually use a steamer to force steam down through to clear out the clog or ice. I get theses hand held steamers at walgreens for about $25. Might be cheaper than a service call to invest in one. Hope this helps.
Sep 07, 2013 | Sub-Zero 700TC Bottom Freezer Refrigerator
Sub Zero - 700 TCI 2 :Water is forming on bottom of Frig.
Most refrigerator doors are adjustable. You may find that adjusting the door so that there is a proper seal eliminates the water collection problem
Sep 12, 2012 | Sub-Zero 700TC Bottom Freezer Refrigerator
Sub zero model 700tc problem. frig heated up to 86 degrees. freezer is fine. What do I do?
Hello.
Well moondoggie, it sounds like your light is staying on. You can depress the light switch while the door is open to confirm this. If it doesn't go out, you need a new switch.
Give it a try and let me know.
fil
Mar 06, 2011 | Sub-Zero 700TC Bottom Freezer Refrigerator
Sub zero 700tc runs all day
make sure condesor coils are clean, and the fan that blows over them, located on the bottom of fridge
Oct 29, 2010 | Sub-Zero 700TC Bottom Freezer Refrigerator
Drawers not cooling. Staying at 70 deg. Solution?
This is not a diy unit for repairs- call in a professional.
May 28, 2010 | Sub-Zero 700TC Bottom Freezer Refrigerator
My sub zero 700tc refrigerator won't get cold? Freezer is working just fine
We are Sub Zero factory authorized service and parts suppliers.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct parts out to you asap. This is a simple repair and you will save a lot of money by repairing it yourself.
We look forward to working with you.
Nov 09, 2009 | Sub-Zero 700TC Bottom Freezer Refrigerator
SUB ZERO 700TC Motor is very load and never seems to stop
If it's one of the two fan motors, if the fan blades aren't hitting somthing such as a wire or ice buildup, you'll just have to replace the motor. If it's the compressor making the noise you can either put up with the noise till it stops working or go ahead and get it repaired. Compressor work and replacement don't come cheap.
Aug 21, 2009 | Sub-Zero 700TC Bottom Freezer Refrigerator
My freezer isnt working
this may sound stupid but is the ice maker turned on? Does it say "ice" in the display? If it does, check to see if the ice level arm is jammed into the upper position also make sure that the ice bin is in place (it actuates the ice maker switch) make sure there is no ice stuck to the top of the ice maker
Jun 16, 2009 | Sub-Zero 700TC Bottom Freezer Refrigerator
Sub-Zero service manual
Here is a link to the error codes. If there is a fault condition these should be flashing on the display:
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
One this to try is a hard reset: unplug and wait for a few minutes and re-plug back in. Sometime this resets the service condition and will then display the error codes.
Ice is displayed when the ice maker is turned on. Press the ice on/off and it should turn off.
Feb 19, 2009 | Sub-Zero 642
Refrigerators Logo
192 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
