Question about Protron PLTV-4250 42 in. LCD Television
The cable connection is broken i need to replace this part
    Problem Solver:
  • 17 Answers
Thats a little tough to do, You need to take apart the TV, remove the welds that hold the coxial in place and sodier on a new one. You could get a cable box from you cable company by requesting one and just use the RCA outputs on that box, you will have to change channels with the new remote but it will work. Also if you have an old VCR you can run the cable into there and the RCA out to your TV, just set your TV on the input you have the VCR coming into and change the channel with your VCR remote.
Posted on Sep 08, 2009
I replaced the ribbon cable on my Frigidaire refrigerator and the ice auger for the ice continue to run and water will not dispense when water dispenser is activated. I want to correctly replace the r
Hey friend, thank you for your inquiry!
From my understanding you were replacing the water dispenser on your Frigidaire refrigerator and the ribbon cable disconnected. I would suggest a generic search online for any additional information regarding the ribbon cable. I was unable to locate that information for you. Additionally, if you continue to have problems I would consult with a professional technician for proper attachment of the cable. Best of luck! -Matt
Sep 11, 2014 | Frigidaire Refrigerators
Connection cable screw broken in side tv
the main board will need replacement as the cable input is an integral part of the main board. You can get the main board from www.tvcircuitboards.com
Mar 01, 2013 | Coby TF-TV3217 32 in. LCD TV
I have a Panasonic 32 inch TV, Model CT-3268SV, Serial MD73150155, the terminal that is in the back of the TV, where you connect the cable is broken, I need to replace it, the part number listed is EN
The input socket [RF input] is the part of the tuner. If it has been broken, you have to replace the tuner. It is a box type unit, and can be bought from most of the electronic spare part selling shops at your town.
Jan 28, 2013 | Panasonic CT-20D11 20" TV
Why would speedometer needle bounce
The needle bounce may be related to the cable, it may be broken or just needs lube.
Remove the speedometer cable, locate the connection at the transmission and unscrew it, then locate the connection at the rear of the speedometer, remove the cable from the car, pull cable out of plastic housing and see if it comes out in two parts, if it does then cable needs replacing.
You will see the cable has two ends, is the cable is broke replace it, a broken cable will sometimes spin and not spin causing needle to jump, also a binding cable will do the same, if cable is good then spray wd40 in to cable and spin by hand. note; if cable is binding you will need to work it so it does not break. good day
Apr 29, 2012 | 1984 Toyota Celica Supra
Change battery on 2005 nissan frontier wont start
Hi, If the problem is associated to you replacing the battery, then it could be a few different things. 1) Is the replacment battery fully charged? If not, charge and retry. 2) Are the positive and negative battery cables connected correctly to the battery? With this you have to be sure that you have a good connection to each battery terminal. Try removing the cables and taking a wire brush to the terminals. Once clean, reconnect them and try to start again. 3) Is the positive cable broken? If broken replace the cable. 4) Is the negative battery cable broken or properly connected to the car? If broken, replace the cable. Good Luck!
Jan 11, 2011 | Nissan Frontier Cars & Trucks
Locate and replace battery cables in 1999 toyota corolla
in my time as a engineer i have never replaced battery cables.so what makes you think you need to replace the cables.?????what ever your problem i would suspect a broken cable or a loose small wire going to the starter.1 take a large cable and connect from body of car to earth of battery,see what happens,large cables dont usely need replaced,follow the cable down the line and you will come the broken joint.adrian,,across
Dec 02, 2010 | Toyota Corolla Cars & Trucks
Gearshift seems to have broken linkage..no connection with gears. Can it be fixed (ie, broken linkage) or does it need to be replaced?
there is a common problem with the shift cable bushing. so take out the console and examine the connection between the cable ends and the shifter levers. possibly the cheap little repair kits they sell on ebay for less than 20 bucks will set you right. if the cables themselves are broken, you need to get another set of those, cheaper at autozone or advance than at a dealer.
Aug 18, 2010 | 1997 Saturn SL
The phone dropped and separated the connecting cable has broken what to do
Michelle,
There is nothing else you can do but to replace the connecting cable. has it broken or has it come off??? If it has just got unplugged then it has to be plugged back. While if it has broken (I doubt very much) the it needs to be replace. Seek a professional help if you cant handle it yourself or have the right tools to open the phone. All the best.
Jan 12, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Protron PLTV-4250 42 in. LCD Television Logo
49 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
