Question about Whirlpool LSB6000PQ Top Load Washer
Just finished a load of laundry and the machine smelled hot plus there was still soap in the machine. It finished its cycle but I had to rinse the clothes by hand to get all of the soap out.
    President:
  • 1,776 Answers
I don't know if it has been considered, but I would look at a cold water supply problem, since cold water is what is used in the rinse. Check the water inlet valve. Remove the water supply hoses and check the small screens inside the openings on the water inlet valve (especially the cold water side). Make sure they are clean of rust or debris. Next, check the solenoids. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 08, 2009
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Its a stale, manky smell on all the clothes when they come out.
Hi, You did not mention front or top loading machine so I am going to assume you have a front loading machine.
Do this to clean your machine. Run a hot wash with 1/4 cup NON-bleach "powdered dishwashing soap" (Dawn or Cascade) and 1 cup of bleach. Then run a rinse with 2 cups vinegar and finally a regular wash with cleaning rags and HE type laundry soap. You may hae to do the dishwashing powder and 1 cup bleach wash 2 times to clear a bad case of mildew build up. You will not find this in any manufacturers user's manual but it will rid your machine of the nasty / musty smells.
If you are using regular laundry soap this problem will repeat often. If your using HE laundry soap you should do the above procedure about every 90 days.
We would appreciate hearing any success or failures related to your post by a future response from you as to how the solution above worked out.
Thanks for choosing FixYa,
Kelly
Jan 11, 2011 | Washing Machines
The clothes smell moldy after washed in our Samsung frontloader. How can I get that moldy smell out?
1/4 cup powdered DISHWASHING soap and 1 cup bleach straight into the wash tub with a squeeze of lemon on a dirty rag HOT water wash. You may have to do this 2 to three times the first time.
Make sure your using HE laundry soaps.
There are at least 2 products out there for HE washer cleaning cycles. Tide and Affresh. It is in the laundry soap section of most supermarkets. You should use one of these type products at least one a month.
Thanks for choosing FixYa.
Kelly
Aug 16, 2010 | Samsung WF337AA Front Load Washer
How to get rid moldy smell in LG Front loader washmachine?
There are several cleaners for front loading washers on the market, such as affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, and tide washer cleaner. Clean out the filter located behind the access door at the lower left front of the machine, then, if your model has a tub clean setting, use that with one of those cleaners, if not, use one of those cleaners with the longest, hottest cycle. If things were very bad, you may have to clean it twice. Now, after it is cleaned out,.....STOP USING SO MUCH SOAP ! Use only one tablespoon of HE laudry detergent per cycle, and only one teaspoon of fabric softener if you use that. (Note: Bath towels, used only to wipe off clean bodies, then tossed into the laundry are not dirty enough to require soap usage, and should never have softener used on them) The odors in your washer are caused by a build up of soap and fabric softeners on the inside of the washer's drum. Also, you may have a build up of soap or fabric softener on your clothes. Wash them again once with no soap or fab softener to rinse them out.
Mar 17, 2010 | LG WM-2277HW Front Load Washer
Everytime we do laundry, we have a horrible smell in the washing machine. We have tried bleach and hot water but no success. Any other ideas?
Be sure your using HE Laundry det. only use the recommended amount on the bottle, I use the liquid, the less the better, I use the least amount.....To much soap left in clothes can cause mildew and stinky smell, also I recommend using a fabric softner, it helps to remove the soap....and smells good....also use a good washer cleaner, I use Affresh, they come in tablets, go to www.affresh.com and put in you zipcode to find where you can purchase it in you area......make sure after a load is finished that it doesn't sit in the tub with the lid down for long, removing the laundry promptly will also help with stinky laundry........also, leave the lid or door open for a couple of days to air it out after cleaning.....use the Affresh at least once a month.......hope this helps you
Jan 08, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Bath towels smell sour
I started adding 1 cap of bleach with 1 cup of water to all my loads in the bleach dispenser and this stopped the smell problem with my sweaty clothes.Sour towels i fixed with using Win high performance sports detergent plus my usual dose of he detergent along with a 2nd rinse.Keep the lid open when not in use always.
Dec 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My washer smells really bad
your smell is comming from over soaping
a front load machine only needs 1 Tblsp of soap
any thing it builds up and rots thus the smell
get a crystal dish soap
1 cup run the machine empty a full cycle
now use trhe proper soap it will clean away
Oct 03, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Laundry smells like mildew after washing
Front load washers retain water that you cant see or get to. There are cleaners for washing machines available. I clean mine every month with alot of bleach , try pouring a half gallon of bleach in the soap insert on a normal wash cycle and an extra rinse would not hurt no clothes of course.
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool LSB6000PQ Top Load Washer Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal De
