Question about Cobra 29 LTD CB Radio
When i click the mic i get no transmit
I have a cobra 29 ltd cb radio. when i click my mike it does not transmit. do i have a problem with the mike or the radio?
  • 141 Answers
Receives, but wont transmit:
Bad mic
Blown RF Transistor
Posted on Jan 30, 2010
  • 86 Answers
If the receive works ok,sounds like a mic
problem,try another mic if you can find a
buddy who has a Cobra that may let you
try it most all Cobra mic will work but not all.
Good Luck
Posted on Sep 12, 2009
My cobra ltd wont transmit
sub the mic first as a broken wire inside it can cause this, does transmit light come on when keyed?
Oct 15, 2012 | Cobra 29 LTD CB Radio
What is wrong with a cobra 29 ltd when the meter sticks when you transmit and will not recieve
could be a mic problem. try using a process of elimination to solve you problem.
Sep 06, 2012 | Cobra 29 LTD CB Radio
Cobra 29 cb receives well, but no one can hear me when I transmit?
open the radio and turn vr 4 wide open but before you do get a new mic and hook it up to eliminate the squeal the turn up vr 4 to raise the modulation.
Jan 13, 2012 | Cobra 29 LTD CB Radio
I can recieve but i cant transmit have new antenna and new mic
Check that your mic gain or dynamike knob is turn clockwise if it is full counter clockwise you will have no modulation with your tx power.
I would like to help but one sentence describing your problem can lead to a vague solution.
Be aware that not all 4 pin mikes are wired the same.
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Aug 28, 2011 | Cobra 29 LTD CB Radio
29 ltd classic wont transmit
Great radio when it works.
If you have your settings on CB - not PA - -be sure that your Cobra has that setting selected.
If CB -is selected and still nothing - be sure you have a working mic. These wires are fragile and can break internally. One easy way to check is to borrow a cobra mic or even drop by a CB repair shop and ask them to do a mic check with the mic - it is free.
If you have a bad mic replace it and all should be well.
If your mic is good and it still doesn't transmit you will need to replace the finals in the unit. It is common that these burn out of you got too close to someone with too powerful a radio. The CB shop will need to look at it further and repairs should not be over about 40.00.
Good luck with your Cobra.
Mar 31, 2010 | Cobra 29 LTD CB Radio
Where does the pin on a mic go to on a cobra 29 ltd
1/ shield 2/ audio (usually white,it's the wire the shield is wrapped around) 3/ red 4/ black if the radio transmits without keying the mic. switch # 3 and # 4.Good Luck
Apr 25, 2009 | Cobra 29 LTD CB Radio
Radio stays transmiting after mic released
What happens if you "key up" and "let off" and the transmitter "hangs", you remove the microphone plug from the Cobra ?
Will it still be transmitting or will it stop ?
If it stops, the problem is in the microphone with a "hanging" switch which you can easily clean or replace.
Iif it keeps transmitting while the mike is disconnected, there is a problem with the Rx/Tx switching circuit. This needs further investigation by use of a circuit diagram.
Feb 13, 2009 | Cobra 29 LTD CB Radio
Cobra 29 nw ltd won't transmit
Have you cracked the radio open yet?  check for loose connections etc.  get back to me if that doesnt yeild any results
Dec 23, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
688 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
