I just got a used Xl-115 air purifier. When I turn it on in automatic mode the ozone generator does not activate. Is it supposed to come on right away? I would assume my currently un-purified air would cause the ozone generator to activate immediately and stay on until the proper ozone levels are achieved. ?? It does not make a difference what room size setting I have it on. When I switch to manual mode it starts hissing and I smell the ozone immediately. I'm just not sure if something is wrong with it or the automatic mode only turns on the ozone once in awhile. Help. Thanks
your sensor board has failed , a realy common problem , most if not all are dead and no parts are made for it ...... you do not need the sensor anyway it was only installed as a knee **** reaction to fda worrys of ozone levels over 0.05 ppm in bedrooms . so the board was installed to cut at 0.05 ...... it was a failure , so a bypass switch was added to get around the problem board ... just set on man , adjust for your sq ft ... you will be fine
I have a Classic Living Air model XL-15C. I keep hearing a loud rattling noise from inside. I...
(More)
I have a Classic Living Air model XL-15C. I keep hearing a loud rattling noise from inside. I believe the noise is coming from the (yellow light) fuse-located in the middle right side of the unit. I also noticed the fuse in upper left corner of the unit (which I believe lights up green) is not on -Would the rattling sound be due to the fuse needing to be replaced? Can I replace both fuses myself?
Appears that the high volatge supply has failed. Neither lamp (inside) is illuminated consiquentlky...
(More)
Appears that the high volatge supply has failed. Neither lamp (inside) is illuminated consiquentlky no ionization is occurring. Fan operates properly, has new plate. No apparent physical issues.
the ozone only comes on at the highest setting. It is to strong to have it on that level. What is...
(More)
the ozone only comes on at the highest setting. It is to strong to have it on that level. What is the problem? the disks are new.
Not producing ozone, wire on little round sensor is broken on the small silicned in circuit board...
(More)
Not producing ozone, wire on little round sensor is broken on the small silicned in circuit board that is in the left rear of unit. Is this board replacable and if it is where can I get one?
