Question about Fujitsu Tablets & eReaders
Internet does not connect - can not get ip address have good connection -
    Scholar:
  • 96 Answers
First thing you want to do, is to make sure all the network cables are plugged into the correct devices such as your router, modem and the computer. if all is running well (everything is blinking with lights) go to your computer, open the control panel, select network connections and open it.
Right click on the Local Area Connection and right click on it and select repair. Wait for about 2 mins. After that restart your PC. Try to get on the internet. If you are still not able too, you will need to go to the command prompt, you can do this by selecting start then run, type in 'cmd' and enter.
(The screen above is in German Sorry, but you will get the point)
You will see a windows that pops open, it should see something like c:\Documents and settings\keith> or something like this. type in 'ipconfig /all' you will hopefully you will see a ip address and a lot of other information. the ones you will need to look at is to see if your dhcp is enabled if it is then this will give you a auto ip address if it is not, you will need to get a static address from your isp. You will try to see if you can communicate with the IP address by typing in 'ping ' then the ip address. for example 'ping 192.168.1.1' if you have not packets lost, then that is a good thing. then try to ping your gateway, this will be your router ip address. you can find this ip 'Default Gateway' if you are able to ping this, you should be able to go online fine.
If you are still not able to fix this
after the c:windows> type in 'ipconfig /release' so it will look like this
c:windows>ipconfig /relinternet does not connect - can not get ip address - 9275320.gifait untill it shows 0.0.0.0
Then type in ipconfig /renew
Keep this in mind this is usful if you have DHCP enabled. unless your in a workplace, you should have DHCP selected.
If you are still stuck, Please let me know and I will be more then happy to help.
Please don't forget to vote!
Posted on Sep 08, 2009
When accessing the internet on tablet the `Unfortunately, internet has stopped` message appears even though it is showing that wifi is connected
Verify that your router has a good internet connection and that its local IP service (usually through DHCP) is running. Try entering the router's TCP/IP address (e. g., http://169.168.1.1) in your browser's address bar to see if you can get the router's status page.
One of the more common failures in older routers is IP service dropout, particularly if the router overheats because something was stacked on top of it. This will result in client error messages such as the one you describe.
Another possibility is an authentication failure, but that would generally mean somebody messed with the wireless network access password, or there's a bug in the wireless coding (as in some ASUS laptops - this was fixed in a firmware update).
May 28, 2016 | Samsung Galaxy Tab 10.1 Wifi - Tablet -...
Where can I get an I.p. address for my tablet . Im not sure what happened , I put it back to factory settings and after that there was no ip address. Please help?
What most likely happened is when you factory reset the device, the wireless setup that you use to connect to the Internet was reset as well. You need to go into the wireless setup area and look for networks to connect to. The one that you use regularly (assuming you are where you use the device), should be among those listed. You then tell the device to connect to the network. This is where the device will ask you for the network password if it is a secure network (and most are). Once you input the password, then the network router will assign an IP address to the device and connect it to the network. After that you can access the Internet normally. If you don't know or forgot the network password, someone in the household (or business) should be able to provide it so long as you are authorized to connect.
Dec 11, 2015 | Sungale Tablets & eReaders
I have had Wi Fi on my Kindle Fire and now it will not connect and keeps asking for an IP address
See if this article helps you.
http://classroom.synonym.com/ip-address-kindle-fire-15120.html
Jul 12, 2015 | Amazon Kindle Fire HDX 7
Adding ip address
You cannot add it manually...you can switch OFF and ON the device and again try the internet source like Wifi etc...If it gets connected..visit Ip-details.com and get the Ip address.
Jan 06, 2014 | Tablets & eReaders
4.1 jellybean keeps searching for IP address. Will not connect. All apple products connect fine
This is the result of a bug in Android 4.1, you'll have to manually assign an IP address to your Android device.
Instructions on how to do this are available here:
http://www.trickswindows.com/2011/12/fix-obtaining-ip-address-android-wifi.html
Dec 15, 2013 | Curtis Klu 7-inch Touch Screen Mobile...
Hisense Codes
Try opening internet explorer and going to www.google.com
If this also produces an error, go to START -> Type "CMD" in the search box and hit ENTER
A black box will apear.
Type "ping www.google.com"
If it comes back with errors, it is your internet connection. You can be connected to your home network whilst your internet is not working.
Are you on windows 7?
If so try this:
There should be a network icon at the bottom right of your screen, a computer icon. Right click it, select "open network and sharing center"
You should have a network that says LOCAL AREA CONNECTION. Select this.
Click on DETAILS...
You should have an IPv4 Address that looks similar to "192.168.1.3"
Write down this address.
Close the current screen. You should be on the LOCAL AREA CONNECTION STATUS screen again.
Click PROPERTIES.
Double click the INTERNET PROCOTOL VERSION 4
Select USE THE FOLLOWING IP ADDRESS:
Now remember that IPv4 address i told you to remember? Well put that down in the IPADDRESS field, except add +15 to the number.
Eg. original: 192.168.1.3
Make it: 192.168.1.45
Subnet should be: 255.255.255.0
Default gateway should be the same as your IP but with a 1 at the end.
EG: 192.168.1.1
As for the DNS - Log in to your router/modem and in the summary or overview section it should list the primary and secondary DNS ip addresses, find them and fill in the remaining 2 boxes.
That's it, you're done. Enjoy your internet.
Oct 24, 2013 | Tablets & eReaders
My archos 97 wont connect to the internet
when you try to connect by your WIFI is it showing always obtaining IP address ??
and what is the language is your keyboard ??
Nov 13, 2012 | Archos 97 carbon 16GB 9.7" Capacitive...
Cannot connect to the internet with my w-fi, I have put in the appropriate passwords etc to no avail, it keeps scanning for IP address. kaleidoscope639
Is there a DHCP server running? Like a router with DHCP enabled? How does your laptop connect? do you have a fixed IP address for the computers/laptops? What kind of encription are you using ? WPA ? WEP ? none ? Set a fixed IP within the same range and try again.
Mar 05, 2011 | Samsung Galaxy Tab Tablet PC
I cannot connect to the internet. My wireless connection says that it is connected to my wireless hub. All other computers in the house hold are connecting to the internet wireless, so it is not a wireless...
Do you have anti-virus installed? You may have a virus that prevents you from surfing the net.
Also check if you are getting an IP address. Go to start>run>type in cmd and press enter. On the command prompt(black screen) enter in ipconfig and see if you have a IP address
Jun 03, 2010 | Toshiba Portege M200 Tablet PC
Internet explorer connection
This problem could be due to your DNS settings or your IP Address. First of all you will have to configure your router to accept the new computer. To do this you will need to go in to the router in your browser window and add your new device.
Then you will need to configure your router to either automatically assign an IP Address or use an allocated IP Address and use the same setting on your new computer. Also, you will need to configure your router to either assign a DNS Server automatically or to use an allocated DNS Server and once again you will need to use the same settings on your new computer.
Your IP Address is crucial in order for your new computer to connect properly to your network. Your DNS Server is crucial in order for your new computer to access the internet through your network.
If you still have problems, please do not hesitate to contact me directly on Skype (Skype Username: fixya-support)
Thank you for using FixYa! Have a great New Year and please remember to rate this solution.
Warm regards,
BearWeb
Jan 09, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Tablets & eReaders Logo
382 people viewed this question
Top Fujitsu Tablets & eReaders Experts
k24674
Tony
Tony
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
