Question about Sony Ericsson K790i Cellular Phone
K790i: Problems with contact list
I have several contacts, and have noticed errors with two entries.
1. Contact starts with A: The number saves incorrectly, no matter how man times I try to correct it.
2. Contact starts with N: The entry is not visible on the main list, but displays the name when that person calls me or txt me. The only way I can call this person is by finding a txt and using the number from there.
How do I enter contacts and their phone numbers
Hi Joseph
Add a New Contact
Step 1 Touch the "Main Menu" soft key on your LG phone, or use the directional keys on your phone to select the "Main Menu" option.
Step 2 Touch or select the "Contacts" option to access a menu that allows you to add a new contact. Select the "New Contact" option using the soft key or directional keys. This action opens a blank contact template.
Step 3 Touch or select one of the blank number fields, such as Mobile 1 or Work. Use the keypad to enter the appropriate number into the field. Add the contact name in the same manner. Touch or select "Save" to complete the addition of the new contact.
Add a New Number to an Existing Contact
Step 1 Touch the "Main Menu" soft key, or use the directional keys on your phone to select the "Main Menu" option.
Step 2 Touch or select the "Contacts" option. Scroll through your contact list and select an existing contact to whom you want to add a number. Touch or select the "Edit" option.
Step 3 Touch or select one of the blank number fields, such as Mobile 1 or Work. Use the keypad to enter the appropriate number into the field. Edit the contact name in the same manner if desired. Touch or select "Save" to save the new number under the existing contact.
Apr 18, 2016 | LG Cell Phones
I have HTC Wildefire, when I receive an sms, I get only phone number in international format but no name of contact. knowing that the contact is saved in my address book.
HI there!
This is a pretty common issue. The trick is to save the numbers in your contact list in the format you receive the texts in, for example here in canada the format would be 1-xxx-xxx-xxxx and this would show up on the phone as +14038486756. Either save the number from your text messages OR change the ones in your contact list and you should be set!
May 04, 2011 | HTC Wildfire Cell Phone
Contact Number
Hi, You can import phone data from a Subscriber Identity Module (SIM) card to the address book application on your BlackBerry smartphone.
Contacts in the address book can be saved to the SIM card individually. You cannot import data from the address book to the SIM card.
To import a single contact, complete the following steps:
1)On the BlackBerry smartphone Home screen, open the Address Book.
2) Display the menu and select SIM Phone Book. The SIM phone book is loaded.
3) Select the contact you want to import, then select Add to Address Book.
4) In the New Address screen, add any additional information.
Import all contacts, complete the following steps:
1) On the BlackBerry smartphone Home screen, open the Address Book.
3) Display the menu and select Copy All To Address Book.
4) Go back to the Address Book and make sure all the entries are displayed.
After adding information to ddress book you can able to veiw contact list, I hope this information will be helpfull.
Oct 14, 2009 | RIM BlackBerry Bold 9000 Smartphone
How do i remove a number from the reject list of the samsung C3050?
Settings> Application Settings> Call> All Calls> Auto Reject> Reject List> Delete
Jul 13, 2009 | Samsung Cell Phones
How do i find numbers that are saved to my sim?????
Most phone have settings to display, only sim contacts or only phone contacts or both
the user manual explains it and it is available in the following link
http://downloadcenter.samsung.com/content/UM/200810/20081030012522500/att_a867_eternity_ug.pdf
Address Book Settings
1. Touch ➔ Address Book Address Book Settings.
2. Touch any of the following options to activate a function:
• My Business Card: attaches a user created virtual business card
as an attachment to outgoing messages.
• Save New Contacts to: defines the destination for new contact
entries (Phone or SIM Card) (page 95).
• View Contacts from: to filter the display of current Address Book
entries. Options include: All, Phone, or SIM Card (page 91).
• Own Number: to display your current phone number (page 93).
• Fixed Dial Contacts: assigns phone numbers as FDN entries
(page 93).
• Used Space: displays the memory storage allocation (total available
and remaining) within both your Phone, SIM card, and FDN list
(page 97).
Hope this helps !!!
Apr 18, 2009 | Samsung Eternity Cell Phone
Cect i9 contact recognition problems
you cant put 1 infront of the number you have to edit them ex my area coe is 510 i had put 1510 and it never reconized it so i took off the one and it found most of them
Jan 25, 2009 | Dual Electronics CECT P168 Cellular Phone
Already have numbers saved to phone, trying to save to sims card, please help! I am purchasing a new phone and want to be able to insert the sims and have the numbers.
How Do I Copy Contacts From My SGH-d807 Phone To The SIM Card?
To copy an address book contact to the SIM card follow the steps below:
While in standby mode, press the left soft key for Menu
Select Address Book (8)
Select Contact List (1)
Select the desired contact entry, stored in your phone's memory, using the navigation keys
Press the left soft key for Options
Select View (1)
Select one of the contact phone numbers, using the navigation keys
Select Copy (3)
Select SIM (2)
Press the left soft key to Save the single contact phone number to the SIM card
Note: Each phone number for a contact must be individually saved to the SIM card
PS-Not sure about updating/replacing entries though, which is what you may have been asking about
Dec 28, 2008 | Samsung SGH-d807 Cellular Phone
Favorite Contacts
1. Press Phone
2. Select Favorites tab
3. Press Menu
4. Select New Favorite on Record menu
5. Enter a label for the favorite
- if entry is for an existing contact, select Lookup.
- if entry is for new contact, enter the label, press Down & enter the no.
Nov 29, 2008 | Palm Treo 500 Centro
I want to program a new number into my old A900 Samsung phone to replace my wife's old phone.
Hi
Surprsingly u never mentioned the name of the network which u r using. Please mention the CDMA server's name.
Thanks.
Supriyo DG
Jun 19, 2008 | Cell Phones
MS Outlook Contacts error solution
completely uninstall and download ccleaner from downloads.com. run it which removes any previous office system related files. then reinstall office
Jun 06, 2008 | Microsoft Office Outlook 2003 for PC
Sony Ericsson K790i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
