Question about Kenmore Washing Machines
My Kenmore Calypso will not go into drain mode without the machine being tilted nearly 45 degrees backwards. The drain motor checks fine and the lid switch is engaged...any other clues?
  • 15,935 Answers
It appears your Pressure Switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
  • crabblers Mar 30, 2011
    Found a short in the wiring harness after finding this problem listed on other sites. Found a broken wire, spliced in a new one and off we went!
I have a Kenmore Calypso top load washer. I cannot get it to finish the spin/drain cycle. We just moved and checked to see if it was level which it is. What else could be wrong?
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the lid switch assembly, you jump it to test it. If the lid switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 05, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso has unbalanced "L5" message
LS is a "Lid Switch Error"
The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display. If opening the lid or pressing STOP/CANCEL does not clear it, unplug your washer for 5 minutes.
Here is a link to a PDF manual for it also.
Calypso Manual
Nov 21, 2010 | Kenmore Washing Machines
Washer will not drain or spin.
Pump is clogged. Pull washer out 3-4 feet and tilt at a 45 degrees angle. Pump is in front to work with. Drain water out has much as possible before working on it. Have towels around.
Oct 23, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My machine will not go into drain mode without the machine tilted backward?? why is that?
try pushing down on the lid or the lid switch to see if thats your problem. if not its probably a bad pump.
Sep 07, 2009 | Washing Machines
LSQ9649 Whirlpool washer body panel
Remove Phillips screw from rear of console head. (one on each end) Pull console toward you and turn up. With a flat head screwdriver remove clips on top of machine( both ends) pushing down and up. un-do wire for lid switch. Open lid and grab inside lip , Tilt back at 45 degree and walk backwards Cabinet is now removed. More than likely your pump is leaking locted in front of motor with 2 clips,
Jul 07, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My admiral washer wont spin the clothes dry
Probably not getting upto full spin speed, drum may wobble more than usual?
Change the motor drive belt below the machine, tilt the machine 45 degree backwards to access underneath, belt pulls off and replace same way.
Jun 09, 2009 | Admiral AW22 Top Load Washer
Water will not drain from machine
one of three thing is happening,lid switch is bad,the motor coupler that turns the water pump has broken or the water pump itself is broke or clogged with somthing,you can check the lid switch buy lifting and closing the lid slowly to see if you hear the clicking sound,to remove cabinet remove the 2 head screws one on each side of head,flip up,use a screw driver two remove the 2 spring clips one on each side under head,unplug lid switch,tilt the cabinet toward you and pull it off,you now can check the water pump and motor coupler,let me know what you find-mike
Apr 08, 2009 | Kenmore Washing Machines
FL code on a Kenmore Calypso top loader
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$#@!
Jan 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Machine will wash but not spin or drain-Kenmore series 80
needs a new drain pump you can replace it easily by leaning the washer back at a 45 degree angle then right at the front panel you will see the 2 hoses hooked up on the drain pump there is a clip on top and bottom of it unclip them and slide the pump off the motor shaft then undo the hoses and do in reverse order to replace and please rate me
Jan 05, 2009 | Kenmore Washing Machines
Kenmore Elite Calypso won't drain
The most likely thing to cause the code and the leak is the water pump. If the shaft seal on the pump leaks, the water gets into the drain pump motor and shorts it out. The code is telling you there is a high current/amp draw at one of the motors.
You can see if the pump is leaking by tilting the machine back, removing the screws that hold the bottom to the front edge of the machine and looking at the pump. If the pump is leaking, you will need a new pump and possibly a new motor control board.
Post back if you need further instructions and we will walk through the repair.
Nov 09, 2007 | Washing Machines
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
