Question about Performance Teknique ICBM-782 Car Audio Amplifier
How do i hook up a performance power cap i lost my diagram.
  • 434 Answers
Hot from battery into the + on the cap. Out of cap on other terminal to the Amp.
Posted on Sep 08, 2009
HOOKING UP THESCOSCHE 500K MICRO FARAD CAPACITOR. I LOST THE HOOK UP DIAGRAM AND DON'T WANT TO HOOK IT UP WRONG
Connect ground wire to ground. Connect positive wire to the same positive wire as the amp is. If you lost the charging resistor then connect the wire to the cap first then connect to the power source. This will keep it from sparking and damaging the plating on the connector.
Jul 31, 2016 | Heating & Cooling
Cuts out when volume high
Hook a power cap up and double check all your wires.
Nov 13, 2013 | Performance Teknique Car Audio & Video
How do i hook up logitech speakers #z313 to my desktop i need a diagram
Phone jack on woofer goes into computer tower (should be color coded green) and power cable on woofer plugs into 120VAC. Speaker phone jack plugs into back of woofer. The speaker cable has an on-off switch and volume control as well as a phone jack for your headset.
Nov 14, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
How to wire light switch?
ok! only hook up the switch to the black wires and cap the 2 whites together. just run 12/2 wiring with ground to switch, hook the black to switch in and black to switch out to light.. cap the white wires to and from switch! you can either hook ground wire to switch or the steel switch box. hope this helps, im not very good with words.
May 04, 2012 | Cars & Trucks
Chargingsystemimpala2000will not charge changed ignition switch starter new battery new cables need a diagram of how the battery to the starter how do they hook up i think we lost the negative ground
if the charging system isnt charging test the altinator or take the car to a parts store ie napa, advance, autozone, most will perform this test for free
Nov 07, 2011 | 2000 Chevrolet Impala
I bought a craftsman 9" band saw from a neighbor and I need to hook up the switch to a SH cap to the motor. I am unsure of how to hook up the wire diagram? Please help. Antonio
there should be a wiring diagram in the motor case or inside the wiring junction box on the motor, and if like most 120 volt motors it will have 2 wires coming out of the motor case and a cover where the cap is covered / stored on the motor,just hook-up the 2 wires to the cap, either wire on either cap terminal is ok
Oct 11, 2009 | Garden
We are trying to install a pionere radio and without the power antena/system control wire hocked up the speakers have no sound when you hook it to 12 volts the tweeters click what should i do
The antenna wire, witch should be yellow. is not supposed to be hooked up to 12 volts. It is only meant to be used as an on censer . If that wire is the reason your speakers are not working then the stereo is defective. That wire should have 12 volts coming out of it when the stereo is on. And hooking it to 12 volts could have damaged your stereo. I would look at the wire diagram again before doing anything else.
So anyway if you are not using the power antenna wire cap it off and leave it alone. you do not need it. Check all of your connections again and follow the wire diagram.
Good luck.
Aug 08, 2009 | 2001 Dodge Dakota
Need wiring diagram for Ruud Model UPCA-048jas
The wiring on these is pretty straight forward
Basically a contactor, either DPST or DPDT, depending. Input power connects here.
Compressor C terminal connects to one side. R terminal connects to the other. 1 terminal of the run capacitor connects to the terminal with the R terminal of compressor. The other side of run capacitor hooks to S terminal of compressor. One wire of condensor fan hooks with compressor R terminal, the other condensor fan lead hooks with compressor C terminal.
Only things missing from all this is a hard start kit and crankcase heater. Let me know if you want to know how to hook those up.
Jan 29, 2009 | Ruud UAMB Air Conditioner
Radio Blowing Tail Light Fuse
by the way you tell me that the radio illumination is the gray wire and all of the rest you are wrong. try the correct way red is key positive,yellow is constant power,black is ground,orange is illumination,blue is remote,gray is right front positive and gray black is negative,white is left front positive and white black is negative,green is left rear positive and green black is negative,violet is Right rear positive and violet black is negative,
Nov 23, 2008 | 1993 Oldsmobile Cutlass Ciera
Lanzar amp
If it keeps blowing fuses then #1 its internally damaged or "blown" .. Or #2 i would make sure you have the battery power hooked up to the + terminal and the ground wire running from the car body to the - terminal.. so if its hooked up correctly and keeps blowing fuses then it requires repair.. I wish i had better news but thats all it can be...
Aug 20, 2007 | Scosche Industries Scosche High...
Performance Teknique ICBM-782 Car Audio Amplifier Logo
90 people viewed this question
Top Performance Teknique Car Audio & Video Experts
George Nalley
Level 1 Expert
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
