Question about Garden
How much oil to fill a tecumseh 6 hp engine on an ariens string trimmer?
  • 138 Answers
This engine should take just alittle less than one quart. Doesn't it have a dipstick on it ? Irregardless about 1 quart should do it. Good Luck
Posted on Sep 09, 2009
What weight of oil is used in Ariens st622 string trimmer with a tecumseh 6hp motor
Since this is used in the summer any good grade is SAE30 oil will protect the engine..no need for muti viscosity oils..good luck.
Oct 02, 2014 | Ariens Wheeled String Trimmer - 946152
What weight of oil should be used in the walk behind Ariens Mower
Most mowers today have either a 3.5 to 7 HP Briggs and Stratton or a Tecumseh engine on them and they usually recommend a straight 30 weight oil in them; not a multi-viscosity, since you do not run them year round. A good synthetic 30 weight is even better and will hold up longer between oil changes. I run 30 in all my mowers. Best of luck to you.
James
Jun 02, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
8 hp tecumsch engine for snow blower oil comes out the side vent tube when running
replace the oil breather filter and make shore you did not over fill the moter with oil
Jan 16, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Using ariens snowblower today, model# 924026 and heard a ping and everything stopped. Tecumseh engine model3 H80 155006. Some white smoke came out and some oil leaked down side of metal part that oil is...
Check your compression tecumseh's are known for the exhaust valve seat poping out of the head. If you have compression check the governor shaft it should only turn about a 1/4 turn.
Dec 18, 2010 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
OUR CHURCH HAS AN 18" YARD MACHINE STRING TRIMMER BY MTD. MODEL NUMBER 25A-203L129. NO ONE KNOWS WHERE THE MANUEL IS AND WE NEED TO ADD CUTTING STRING. HOW DO WE DO THIS? 5.0 TECUMSEH ENGINE. THANKS MONTE
The trimmer line is pretty easy to attach. The trimmer line comes in pre-cut lengths, and is threaded in two places through loops on the spindle. (Two pre-cut trimmer lines are needed.)
Oct 11, 2010 | Mtd Garden
6 HP Tecumseh Engine won't stay running
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
May 09, 2010 | Garden
Need a carburetor
http://www.ariens.com/ Hope this helps
Jun 02, 2009 | Garden
Need parts for Ariens ST 622 string trimmer
MY ARIENS ST622 starts but then dies down quickly any ideas?
May 04, 2009 | Garden
Garden Logo
1,375 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
