Question about Garden
Model 01902 2350 psi . engine runs fine , sprays out nozzle but lower pressure and water sprays out plastic elbow on relief valve , that is supose to **** in soap if used , cant hold finger over spray from elbow , high pressure , took apart relief valve and plastic valves all orings are ok , brass pump seals look ok , all back together , still blows out elbow . ?? plastic spools were out by somebody else , not sure if they are in right , cant find picture to compare .
  • Anonymous Mar 26, 2014
    not sure what size my 2700 psi thermal relief valve is
    Problem Solver:
  • 6 Answers
It sounds as if the non return valve in the elbow is the wrong way around .The o-ring normally goes in first then the ball then the spring. Try it and good luck.
Posted on Sep 08, 2009
I have a reddy heater 40,000 btu it works with the top off and then when I put the top back on the fan hits it? what do I do
You will need to adjust your pressure.
Heaters with Hot Surface Ignitor technology are extremely critical to pump pressure. If the pressure is off by 1/2 psi, the heater may run for 5 seconds, then shut down because of IGNITION FAILURE. The only way to correct this problem is to set the pump pressure to DESA's recommended pressure specification.
  1. The FIRST STEP in diagnosing any heater problem should be checking the output of the air pump. Determine the air pressure required for the heater model that is being tuned. The air pump, in turn, is responsible for fuel delivery.
  2. If you do not know the required pressure look for a decal on the side (usually) of your heater. This decal will state the model number, serial number, fuel capacity, pump pressure, etc.
  3. If your plastic end cover looks like this......
m29609t.jpgM29609 has 2 threaded holes. The hole on the left has a square plug inserted. Remove the plug. Screw in the nipple end of the gauge into the threaded hole. Check for air leaks with soapy water.
or
m16545t.jpgM16545 has 2 threaded holes. The shorter projection with a hole on the left has a square plug inserted. Remove the plug. Screw in the nipple end of the gauge into the threaded hole. Check for air leaks with soapy water.
4. The other hole (longer projection) has a screw with a hole which adjusts a ball and spring relief valve assembly. Carefully adjust the screw until the gauge is reading the pressure level that is specified on the heater's label. If operating properly, the pump should produce more pressure than is required to operate the heater. The relief valve allows the excess air to escape before being sent to the nozzle.
5. Replace plug. Test for leak.
6. If you are unable to reach the desired pressure spray soapy water around the seal of the end cover- at the same time check the plastic cover for a crack. A cracked end cover will not allow the heater to perform properly and will not allow for an accurate reading. The pump must be set at the specified pressure in order to have adequate fuel delivery an adequate fuel atomization. Replace if needed.
7. If you set the pressure to specs and the heater does not perform properly or the cone does not glow a soft red, then check for other fuel delivery problems such as a clogged fuel filter, cracked rubber hose, clogged or worn nozzle, or a cracked nozzle adapter. Soapy water lightly sprayed in these areas will quickly identify the problem most of the time. Any air leak will create problems.
Feb 28, 2015 | Reddy Heating & Cooling
Starts then shuts off
REAL FACT is: If all individual components of the heater are at 100% but the air pump pressure is not on it's mark, then the heater WILL NOT continue to run!
Air Pump Pressure is directly related to fuel delivery. Read that statement again! It is the most important line of text on this website.
If the pump pressure is incorrect, then, the fuel delivery will be incorrect. As a result, the heater will not run to specs.
Instructions for setting the air pump pressure:
Air pump pressure is the pulse of the heater. Pump pressures range from 3 psi to 6 psi depending on heater BTU size (see chart below). A loss of ONLY 1 psi translates to a 30% to 17% loss of FUEL FLOW (starvation). You must know the specified required pressure and set the pressure accordingly.
or
Feb 17, 2015 | Reddy R60A Utility Heater
I have a Honda GCV 160 Homelite 2700 PSI 2.3 GPM pressure cleaner and it has been working fine until today. While the pressure cleaner was running (not spraying at the time) I noticed that underneath
It sounds like a pressure relief valve. That part is usually disposable. You can try looking for the part at a Northern Tool store or you just remove the relief valve and replace it with a brass screw in plug the same size as the valve. When replacing parts like this, always use a Teflon tape on the threads! Best of luck!
Sep 26, 2014 | Garden
Starts then shuts down
or
Mar 02, 2014 | Reddy Heater-170,000 BTU Kerosene Deluxe
Runs when started but won't stay running.
or
Feb 13, 2014 | Reddy HEATER R70DT 70,000-BTU PORTABLE...
Porta heat 55 model 50137 does not work, fuel problems
or
Jan 21, 2013 | Reddy Heating & Cooling
My kerosene torpedo heater turns on but then it dies after five seconds
or
Jan 08, 2012 | Reddy Heater-70,000 BTU Kerosene w/T'stat
I bought a new 2600 psi pressure washer. It starts great. The pressure starts out fine. However, when I disengage the spray nozzle lever and then push it again there is along delay before I get any...
Hi. I think the problem may be called either vapor lock or cavitation, or it could be called something else, but the solution is to take the wand apart in the center and let the trapped water escape, then putting it back together before re-engaging the lever.
Sep 14, 2011 | Craftsman 2600 PSI Honda Powered Pressure...
STARTS AND RUNS FINE BUT WHEN I START WASHING IT QUITS SPRAYING AND THEN BUILDS PRESSURE AND KILLS ENGINE
The reason it stops spraying might be a clogged gun, hose or nozzle-tip.
The reason for pressure buildup killing the engine might be a stuck unloader valve in the pump.
While you are checking each component of the "output" side, spray some penetrating lube into the "input" side of the pump (where the garden hose connects) and let it be working on the unloader valve.
Fix the spraying problem first:
Start at the nozzle and verify that it is open by using low-pressure air. Clean or replace as needed. Next check the hose (with nozzle and gun unhooked) and finally the gun/trigger mechanism.
All must be clear and open to perform correctly.
Next, pour a few ounces of power steering fluid (or similarly LIGHT oil) into the garden hose, attach it to the pump and turn on the water supply.
Leave the "output" hose, gun, etc. UNHOOKED and point the output port of the pump (where the high-pressure hose connects) towards a vacant, safe area.
Startup the engine and allow the oil in the garden hose to work its way thru. (About 1 -3 minutes of run-time.) Shut it down and attach the high-pressure hose.
Hope this solves the problem!
Oct 05, 2009 | Honda Pressure Washer PSI 3000
Garden Logo
172 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
