Question about LG enV VX9900 Cellular Phone
Jabra bluetooth headset will not pair with my vx9900 both are verizon i had a friend pair with the jabra and it worked fine as well as my old phone picked the jabra up is their anything i might be doing wrong with the the vx9900?
How do you pair blue tooth to Jabra VBT185z
it auto pairs .
set mobile phone to bluetooth on
finger click on blue tooth and select discover bluetooth devices
you should see mobile phone detect jabra vbt185z
then pin is 0000 if asked
http://uswww03.gnnetcom.com/jabra/verizon/vbt185z/Datasheet_VBT185z.pdf
Oct 19, 2015 | Jabra Radio Communications
Manual for jabra t820
To pair the Jabra with a Verizon Wireless phone, the phone must have Bluetooth. Bluetooth allows a device to communicate and transfer data with another Bluetooth device without having to be physically connected to it. The instructions for connecting the Jabra with the Verizon phone vary slightly depending upon your phone model. Jabra headset instructions don't vary per model.
Jun 19, 2012 | Radio Communications
I need instructions to pairing the Jabra BT2020 bluetooth to a PS3 system. I've misplaced the directions to the headset unit.
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
password is 0000
Jan 02, 2010 | Jabra BT2020 Bluetooth Headset
Can't get new Jabra BT8040 to connect to LG Env3
I have the env Touch and the Jabra Halo. Initially, I had a problem pairing the two, then I realized that I was not following the directions properly. The manual shows two sections for pairing ("first time pairing" and "later pairing"). I was following the instructions for the former when I should have been following the latter. I also failed to notice that the BT indicator was flashing blue and not solid blue, as it needs to be, for pairing mode. So, if you haven't already done so, follow the instructions for "later pairing" here. Make sure that you see the SOLID blue light on the BT indicator on the headset when you try to pair.
Jul 17, 2009 | LG enV VX9900 Cellular Phone
Igave been using my Verizon Jabra VBT185Z
where can I find the setting on my Blackberry Curve to pair my Jabra VBT185z
Jun 20, 2009 | Jabra BT350 Bluetooth Headset Headset
I dont know how to pair my jabra bt350 with my lg dare from verizon
hello mom. try putting your phone into activate new device and than your tooth into discover mode, than your phone will ask you for password key and put in 0000 and press the o.k. button and pair it. it works most of the time. good luck.
Jan 24, 2009 | Jabra BT350 Bluetooth Headset Headset
Cannot pair LG Voyager cell with Jabra BT150
do you have the bluetooth in discovery mode first before trying to pair?
Nov 30, 2008 | LG VOYAGER VX10000 Cellular Phone
Bluetooth problems
most bluetooth default passwords are 0000
it should pair up.
Feb 12, 2008 | LG enV VX9900 Cellular Phone
Sidekick 3
piece of **** that sidekick 3. I have a piece of **** LG by verizon and it works just fine with the Jabra bluetooth. Sidekick is **** and so is t mobile!!!
Dec 19, 2007 | Jabra BT800 Consumer Headset
How do I pair my Jabra Bluetooth -48D
well what you have to do is to go to the bluetooth menu turn  it on and select add new device now on you jabra headset it has an answer button wich you can press untill the blue light stays on that when the env can find and paire the device
Oct 22, 2007 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
270 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
