Question about Lexmark E323 Laser Printer
Sheet feed feeds more than 1 sheet at a time
  • 61 Answers
I sugest that you leave the sheets in a warm box (there are for sale in computer stores) and put them on the printer just when you´ll use. The sheets that you does not use, put back in the warm box. To shuffle an fan before put them in the printer, will help it too.
Posted on Apr 18, 2008
    Genius:
  • 2,985 Answers
Shuffle the sheets and 'Fan them before inserting into the slot.
Posted on Dec 09, 2007
DP80F FAX WILL NOT FEED ONE PAGE AT A TIME. IT WILL TAKE 1 PAGE , 5 PAGES , 2 PAGES . HOW DO I FIX THIS MACHINE TO FEED ONE PAGE AT A TIME
Potential solution: When putting in several sheets of paper, grab the sheets by one end, and fan the papers (spread them) at the other end. Reverse your grip and do the same thing to the other end.
Reason: paper is cut by a shear. If the blade of the shear is not perfectly sharp, it crushes fibers into the edges of the adjoining sheets. This causes the sheets to misfeed in the random way you describe. Ruffling the paper before putting it into the printer separates the pages so they will feed properly.
Nov 07, 2011 | Toshiba DP80F Printer
Paper feed feeds more than 1 sheet at a time
he problem you are having is caused by a worm separation pad assembly. This assembly is what separates the paper into individual sheets. It takes about 30 minutes to disassemble the printer and replace the part. Most printer repair shops will do the repair for you but the cost may be a bit much. If you are interested in doing the repair yourself we do stock the part. We can provide the separation assembly and a service manual on CD that gives directions for replacing the parts plus other information about the printer. The part and guide runs $14.95 plus shipping. Let me know if you need one, tech
Apr 26, 2010 | HP LaserJet 6L Printer
The scanner takes 2 sheets of paper at a time instead of 1 so only 1 is being scanned. I've tried a different paper that is thicker than regular printer paper and it's still doing it.
There is a pad below the feed roller that wears out. It is called a ****** pad, it retards the feeding of extra sheets of paper. That pad will need to be replaced. Once it is it will stop multisheet feeding.
Apr 01, 2010 | Xerox DocuMate 152 Pass-Through Scanner
I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Oct 07, 2009 | Canon PIXMA MP470 All-in-One Printer
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
Sometimes two sheets feed in instead of one.
Most faxes have a rubber separation pad which is designed to stop multi feeding. It is in the feed area.
They vary in size  but can be up to an inch square.
If they get dirty they can slip and allow more than one page to feed, if this happens you can clean it with a damp rag with a bit of detergent on it . If this does not work (give it three or four tries) you will have to replace the separation pad
Dec 14, 2008 | Panasonic KX-FLB756 Plain Paper Laser Fax
Printer feeds 1 and a half pages and jams every time.
PUT 1 sheet in at a time nd it will be fine
just dont put loadz in at da same time
Oct 17, 2008 | HP Officejet 5610 All-In-One InkJet...
Double feed detection
though it has a flexible papr handling capabilities you might want to consider the ff:
Stacker Capacity: 100 Sheets Document Feed: Automatic or Manual Document Size: Width: 2.2" - 10.1"
Length: 2.8" - 14.3" Thickness: Automatic: 0.06 - 0.15mm
Manual: 0.06mm - 0.20mm Feed Capacity: 100 Sheets
all scanner are equipped with double feed prevention, however it still the user responsibility to ensure that you follow manufacturer's advice, to prevent double feeding:
1- do not feed dog eared paper
2- moistured paper or with strong humid
3- concave paper
4- convex paper
cheers!
Aug 28, 2008 | Canon DR-3080CII Path-Through Flatbed...
Feeds more than 1 sheet
Yes, I have had the same problem at times. The best solution is to 'fan' the paper well (put air between the sheets) BEFORE putting it in the tray. Also, tap down the front edge of paper (that enters the printer) to align the sheets better. You can also clean the rollers with a damp rag to help traction. Hope this helps!
Apr 17, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Lexmark E323 Laser Printer Logo
121 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
