2005 Chevrolet Impala Logo
Posted on Sep 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2005 Chevy Impala ignition switch stuck in off position
I have a 2005 chevy impala. My key wont turn at all when in the ignition. I tried my wife key and the same problem it wont turn at all. I had my car for two years this is the frist time this happen to me. Can anyone please tell me what can I do to fix this.
  • 1 more comment
  • Anonymous Jan 03, 2012
    you may need to replace ignition lock. could be bad tumblers in lock or couls be a problem with steering column
  • Brian Troutman
    Brian Troutman Mar 07, 2014
    Bend over and get ready to take it. I had to pay about $600 to have it repaired, not counting $32 for towing.
  • Anonymous Mar 13, 2014
    key broken inside ignition 2008 chevy impala
marcial adorno
Level 2:
  • Expert 246 Answers
  • Posted on Sep 08, 2009
marcial adorno
Expert
Level 2:
Answers
246
Questions
Helped
117507
Points
806
If it doesnt turn you have a worn out ignition cylinder, the only fix is to replace it, Code the ignition lock cylinder, if necessary
CAUTION:Perform the body control module (BCM) theft deterrent relearn procedure whenever you replace the ignition switch lock cylinder.
Anonymous
Level 3:
Brigadier General:
  • Master 4,088 Answers
Anonymous
Master
Level 3:
Brigadier General:
Answers
4088
Questions
0
Helped
1512659
Points
12435
Someone may have tried to steal the car and damaged the lock's internal pins. Replace the entire lock with new.
Anonymous
Level 3:
President:
  • Master 353 Answers
Anonymous
Master
Level 3:
President:
Answers
353
Questions
Helped
351284
Points
1581
Try turning the steering wheel hard in each direction when turning the key. If there is too much pressure on the steering wheel lock the ignition will jam.
How to program a key fob to a 2005 Chevy Impala with a aftermarket Radio
Transmitter Programming Procedure
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on the transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of the transmitter.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
Operate the transmitter functions in order to verify correct system operation.
Good luck
2answers
Put key in ignition, turned it, click - nothing. no power, can't remove key. what's wrong?
Check battery and make sure the charge is good. If unsure , try a boost
What fuse go to the theft system on a 2005 chevy
Theft light on car won't start , hook a battery charger up to your car to maintain a good charge . Then turn ignition to on position , do not crank it over leave in that position for ten minutes then turn to off and repeat this cycle two more times .
After the third time turn to off and remove key from ignition then ,
reinstall key and try to start vehicle if it works you just relearned your key to the anti theft system and you gain a free lesson !!!
1helpful
Chevy impala cuts off while driving
Check for any stored engine codes, this may give you an idea of any problems that may cause your complaint. Possible crank position sensor, cam position sensor or ignition module would cause a 'die in flight' situation.
I replaced the ignition in my 04 chevy Impala and
You have to have the key coded with the ignition switch at a lock smith,or the dealer.
Ignition switch stuck on 2001 chevy impala
sounds like stuck pins
insert key tap the end of key with malet untill it turns
once it turns drive to lock smith have them remove and repair the ignition cost will be 50 - 75 bucks verses dealer at 200 bucks
2answers
Ignition Switch stuck in OFF position -Cannot Remove Key Cylinder
Yes the 2002 and 2005 are the same model and use the same lock.
2000-2005 Are all the same for anybody else needing similiar info.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
