Question about Hotpoint WMA46 Front Load Washer
WMA46 stopped woking power off mid cycle
I got a hotpoint WMA46, Put washing on this morning started as normal so i left. Went back an hour later to find machine off no lights on or anything washing soaking wet with loads of water in the drum but i was able to open the door. I have changed the fuse, nothing used an extention lead to a different socket, nothing. Help please
  • 75 Answers
Hi there the problem you have sounds like the motor has shorted out causing the pcb to blow, sadly this is a costly repair and is usualy not worth repairing as you will need a new motor and pcb
murdozzz
Posted on Dec 09, 2007
Good evening all, This morning woke up to my home
Sounds like a faulty Tstat that's sending a low voltage signal to the contactor coil only sometimes. The high pressure cut out or the compressor's internal thermal protection could of opened, and then closed again after cooling. Make sure the condenser is clean and not obstructed.
Aug 31, 2013 | Whirlwind FH-778 Air Conditioner
Frigidaire FDB126RBS2
Be very careful, it sounds like an electrical failure, were the machine has cut out to protect you and itself. You need an expert there and quickly. Water and electric are a bad mix and more house fires are caused by washers than most other appliances.
Sep 23, 2012 | Dishwashers
Does not empty at end of wash cycle (not blocked or pump)
faulty program board not progressing
call a technician
Jan 01, 2018 | Hotpoint WMA46 Front Load Washer
Hotpoint WMA33 washer - door won't open
Problem seems to have corrected itself! I tried another slow spin cycle, waited a reasonable interval for the Door Locked light to go off, then when it didn't I switched the power to the machine off. I tried squeezing the door catch a few times and pressing the door downwards, then left it. Some time later when I went into the kitchen the door was open. I washed a small load this morning and the machine worked normally. Fingers crossed, it's ok now.
Oct 07, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Select a program , i makes the normal noise , but nothing happens
Hi did you find a solution? as mine has just started doing exactly the same!
May 15, 2009 | Hotpoint WMA46 Front Load Washer
Hotpoint w440 washer/dryer keeps repeating cycle load?
Hi there, I've got a Hotpoint Aquarius washer / dryer and this has just started happening to me - it seems to get to the end of the cycle then repeat itself. However, I do not seem to be able to cancel the cycle, or am I able to switch it off. It's been going for about 4 hours now. Any ideas?
Feb 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint washer/dryer aqaurius stopd mid cycle with message F-01
f01 is a motor short circuit. you will probably need a new one and maybe the circuit board that powers it if all the lights went out unless the fuse is gone.
Jan 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
WMA46
check that the outflow pipe is not blocked. Turn off power supply get a bucket ready, disconnect the outflow pipe from the u-bend under the sink and check that it is not blocked.
Mar 15, 2008 | Hotpoint WMA46 Front Load Washer
Washing still wet - door won't open.
not a fault with washer. i guess you are plumbed into trap under sink. the spigot you fastened drain hose to is blanked off - there are various methods of doing this including have to saw off the end of the spigot with the bread knife. possible also a fault with pump or filter
Nov 16, 2006 | Hotpoint WMA46 Front Load Washer
Hotpoint WMA46 Front Load Washer Logo
211 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
