Question about Sony Alpha DSLRA350 14.2MP Digital SLR Camera Digital Camera with Super SteadyShot Image Stabilization Lens
When I turn my camera on, the LCD screen is displaying an odd picture. It looks like a picture of a small hole with cracking around it. There are a few vertical lines down the center of the entire screen & at the bottom of the screen, there is a tiny cursor that is flashing. I took a few random shots even though I couldn't see anything on the screen & when I checked my card, the pictures of the objects I took were there. I took out the battery, recharged it. Took the lens off to see if there were any external visible signs of damage, but did not see any. Any help would be greatly appreciated.
    Problem Solver:
  • 17 Answers
Your screen has a small crack inside, but the screen is not used to take your pictures, so the pictures turn out fine.
Posted on Sep 08, 2009
There are lines through the screen (red and blue) like the screen is cracked but the screen s not cracked as far as i can see
If the set got struck on the screen the screen itself may not be cracked but the panel (The entire front where you view the image is called a display panel) may be damaged inside.
A good photo would tell me--usually it will look like a odd burst or lines and or colors more pronounced where the screen was hit and spreading out in a uneven pattern---Google for "Pictures of Damaged LCD or Plasma screens"
Dec 06, 2012 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
BROKEN LCD
it is repairable. there are service centers around that can change just the screen for you.
Jun 26, 2010 | Polaroid i737 Digital Camera
Outdoor pictures give white display on screen
Go to the menus and reset to default or factory settings. Make sure that the white setting in the picture adjustments in the menus are set to zero or you may have to adjust + or - to get the normal effect again.
Test the camera by taking pictures and saving to a sd card. Then put the card in a card reader/writer which is connected to the computer. Copy the pictures or files to the computer and view them to see if they are in good shape or if there is some problem with exposure or the way it looks.
If the computer pictures show that they are good, and they are not showing good on the camera LCD, then the LCD has a problem, and is possibly either cracked or has some other display problem.
These LCD screens are not that hard to change if you are good at working with small items and screws. If you do this, make sure you have a way to remember where you got each screw, as they can vary in size and kind.
Apr 15, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My camera turns on however the screen is black it takes pictures i just have to point and shoot but i cannot see on the screen exactly what i am taking. I then have to go onto my computer and put them on...
if your screen does not display any figures , numbers or icons then the LCD screen is dead. If you look closely at the LCD scren and fine cracks or lines on it then i advise ou to take it to arepair shop for replacement.
rgds
Luwangula
Sep 12, 2009 | Nikon Coolpix S50 Digital Camera
Cracked Camera
This depends on your warranty, if it covers cracks and the product being dropped I'm sure they will give you a new one to replace it, or find parts to repair it.
Sep 10, 2009 | Cameras
Help! Cracked LCD display on Canon Rebel xti
Had the same problem myself, I purchased a new lcd from ebay (user name: ProphotoSD). He has tons of factory LCD's, cost around 90$. Please note that if you cracked the clear cover above the lcd that is a separate piece however it wont effect the lcd working (this piece is also replaceable). Then I found a simple tutorial for disassembling the camera body on google. Took me like 25 min, very simple job, just need a very small phillips head screw driver. Hope this helps!
Mar 21, 2009 | Canon EOS Digital Rebel XTI Digital Camera
Lines across the LCD screen
Two things can cause lines across the LCD either horizontal or vertically. The first (and most likely) is a small crack in the display wafer. LCD stands for Liquid Cristal Display. They are very fragile and can be easily damaged if dropped. I broke one in my pants pocket.
The second would be if a pin on the ribbon cable (to the LDC wafer) was not making good contact. If you disassemble the camera it is possible to clean the contacts using contact cleaner (or alcohol). Only attempt this is you are willing to replace the camera if you don’t put it back together properly.
Mar 11, 2008 | Sony Cyber-Shot DSC-P100 Digital Camera
Cracked Camera
No easy fix. Pressure or impact is the usual cause of a cracked LCD. Try not to get the black stuff on anything....it's pretty toxic! The screen needs to be replaced (assuming there's no other, internal damage). They are usually in the range of $75 US.
Feb 19, 2008 | Nikon COOLPIX S200 Digital Camera
Camera Screen
The following procedure works on the V603. It uses the same LCD screen as the V803 & V1003.
It would appear you have a damaged LCD screen. The same problem happened to my daughter's V803. The camera will take pictures fine but you will only be able to see them if you download them onto a PC. A replacement screen can be easily ordered and replaced. Call Eastman Kodak. Their parts department can be reached at (800) 431-7278 ext 3. Tell them the model number of your camera and tell them you want to order a LCD screen for it. The cost of the new screen is $31.00 + $15.00 shipping. Don't let them talk you into sending it back for repair. You are looking at a repair bill over $80.00. To replace the screen, remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector. Remember the orientation of the old screen and its cable, as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place. Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard. Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera. These cameras are well known for LCD screen failures due to shocks and drops.
Good Luck!
- Jim
Jan 25, 2008 | Kodak EasyShare V603 Digital Camera
LCD display cracked
You can replace the lcd screen although you do need to be careful. You camera has a flash capacitor that contains 300 volts and if you short it out you can easily fry the camera circuitry. You can check on ebay for an lcd or call fuji usa. I will warn you though their parts department isn't the most helpful.
Nov 13, 2007 | Fuji FinePix A303 Digital Camera
Sony Alpha DSLRA350 14.2MP Digital SLR Camera Digital Camera with Super SteadyShot Image Stabilization  Lens Logo
101 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
