Question about Kenmore Washing Machines
To roberta3fan..I just replaced the motor like a month ago. It does work..have pulled it and ran tests..and wouldn't the machine not perform at all if the lid switch were activated? This problem is a strange one..thx
  • 15,935 Answers
It appears your lid switch/door latch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
How do I perform an incline calibration?
I would suggest referring to the service manual for your machine. Using your make, model and serial number, you may be able to find this manual at the following link: Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Dec 15, 2015 | Exercise & Fitness
2003 Saturn Vue with a identity anti theft system. Replaced my battery a few months ago. Couple weeks ago noticed a little difficulty starting up. Last week wouldn't start just clicking noise. Jumped...
Anti-theft system has nothing to do with it . Battery cables , maybe , Park neutral safety switch possibly ! With anti-theft system problem you wouldn't a click or anything , that is if the anti-theft disables fuel or the starter . Plus the SECURITY light would be on if it were a anti-theft system problem . Your best bet , take it to a qualified repair shop that knows how to do starter circuit testing >
Starter Voltage Drop
How to voltage drop test starter motor circuit
And what's this identity anti theft system ? No such thing ! The vehicle has a content theft an vehicle theft deterrent system !
This system disables fuel not cranking of the engine. The VCM/PCM will not disable the fuel due to any BCM message for the remainder of the ignition cycle.
If the VCM/PCM does not receive the same password from the BCM as the last learned one, the vehicle will start and then stalls due to the Fuel Lockout.
May 17, 2017 | Cars & Trucks
AC/Heater Blower Fan in 1990 LS400 works intermittently
Due to the age of your vehicle, the brushes in the fan motor are worn out. you will have to replace the fan motor, it is not serviceable.
May 30, 2017 | 2001 Lexus RX 300
Won't idle and slow to accelerate took to the need to adj carb..
Call the repair shop and inquire what ratio fuel/oil mix they used. If they tuned it to operate at 50:1 and you fill it with 32:1 it will impact performance. HTH
Lou
Replace the plug if you ran it rich for a period of time. How old is your fuel mix? 1.5 months is all that is recommended. Clean the air filter.
Nov 15, 2009 | Garden
I keep getting an Ld code on my cabrio. It always has 14 minutes left. I even unplugged and replugged it, and it goes right back to the code. I had to have a new computer board put into it less than a year...
Long Drain Ld flashes when the water level does not change after the drain pump is on. • Is the drain hose or the drain pump clogged? • Is the drain hose height greater than 96˝ ? • Is the pump running? If not, see TEST #7.
TEST #7 Drain/Recirculation Perform the following checks if washer fails to drain or recirculate. 1. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test. 2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies. 3. Visually check that the P4 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1. 4. Remove connector P4 from the machine/ motor control and check resistance values of pump motor windings. Resistance values should match those shown in wiring diagram, page 7-1. If resistance values are good, go to step 7. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, a problem exists in the motor winding or in the connection between the machine/motor control and the motor. Go to step 5. 5. Tilt machine forward to access the bottom of the machine and the pumps. 6. Check the resistance at the pump motor. Remove the connector at the motor and take measurements across pump terminals. Measurements should be as shown in the wiring diagram. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, replace the pump motor. If the resistance at the pump motor is correct, there is an open circuit in the wiring between the motor and the machine/ motor control. Repair or replace the lower wiring harness. If the pump motor windings and machine/ motor control check OK, repair or replace the pump. Be sure to check the pump and tub sump for foreign objects before replacing pump. 7. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test. 8. If the Manual: Pumps test failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Manual: Pump test.
Jun 17, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Engine using oil. No sign of leaking. Catalytic converter replaced 13 months ago, now needs replaced. Told need new engine. What is causing the catalylic converter to plug?
Was a leak down test performed on the motor?This will determine if the oil loss is due to bad rings or a head gasket.A head gasket can be repaired,rings will require an overhaul or new motor.Have checked the coolant for oil contamination?
May 31, 2009 | 2002 Nissan Altima
Delay in shifting when excelerating
throttle position sensor, but check fuel filter first
Jan 03, 2009 | 2004 Chevrolet Tahoe
I do not know how to make my printer work
it needs the complete service with the cleaning of head. it is better to perform the task professionally.
Dec 23, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Replaced Motor Control, motor and Main Control board, but still won't work
The only other thing that could cause the ON light to turn off as soon as the motor is about to start would be a bad or loose connection that causes a break in the circuit. Even if the components are O.K. the connection could still be causing the problem.
Feb 19, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
15 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
