Question about Mtd Garden
My drive belt jumped off the pulley. Didn't break. Need a diagram
Huskee 42''Auto 18.5 HP 8STY Model #13AL608G731 Ned diagram to see how it should wind on, and what if anything broke
  • 37 Answers
SOURCE: Drive belt comes off the rear pulley.
Hi, this is a easy solution. on your drive pulley, there should be three belt keepers to keep the belt from coming off. ( belt keeper is a 1/4" dia. rod that goes over the pulley)
Posted on Nov 22, 2008
rockitman187
  • 2559 Answers
SOURCE: need drive belt diagram for LGT2654 Huskee
Here is a link to the manual on pages 7, 8, and 40,
Please take time to rate this a fixya
Posted on May 10, 2009
  • 130 Answers
SOURCE: I replaced my 42
your bearing are bad in the spindale.replace spindale its easyer.
Posted on Jul 22, 2009
SOURCE: huskee 42 inch drive belt
does anybody know what kind of drive belt a huskee 24 horse 42 deck takes?
Posted on May 29, 2010
SOURCE: Need to replace drive belt, but can't get the
I have the same model and am in the process of replacing the drive belt. To get it on the front (engine) pulley, I had to take out the 4 engine bolts and jack up the engine about 3 inches. Go slow because exhaust manifold is still attached. Once the pulley was about 1/2 inch above the frame plate I was able to slide the belt up through the frame and onto the pulley. Tractor Supply Co said it was a 77 inch belt, but I'm not sure since now I can't get the belt over the fan and around the transmission pully. I'm afraid I'll have to take it off the engine again and put it on the transmission first.
Posted on Jul 13, 2010
DIAGRAM OD DRIVE BELT ON 46 INCH CUT HUSKEE MOWER
You will need the model number to find this info. Usually on a plate or sticker under the seat. The use a parts site like jackssmallengines.com or simply Google your make and model followed by "deck belt"
Oct 07, 2016 | Huskee Tractor Replacement Riding Lawn...
Need instructions how to put on and route a mower 42 deck huskee lt 4200
here is a diagram from the internet, hope it helps.
May 15, 2016 | Garden
How to change drive belt
  1. Step 1 - Loosen tension and remove belt. Locate the adjustment fastener and loosen it. ...
  2. Step 2 - Inspect drive and drive pulleys. Check the drive and pulley wheels. ...
  3. Step 3 - Select correct replacement belt. ...
  4. Step 4 - Install V-belt. ...
  5. Step 5 - Correctly tension new belt. ...
  6. Step 6 - Start the engine.
Mar 24, 2016 | Huskee Tractor Replacement Riding Lawn...
Model 13aj771g031 huskee lt4200 lawn tractor 18 1/2 HP engine. 2009 yr. Need to find out deck belt size. Got far enough to find out its part 44 on sears part diagram but that's as far as I got. No size or...
It is a "G" deck which is the 42" Cut.
Deck current part number 954-04060C which is 1/2" x 96-1/2"
Just Google 954-04060 and you find several online suppliers.
Pricing depends on the supplier and if it is OEM or aftermarket.
Mar 28, 2015 | Sears Garden
Belt routing diagram
if you type in the model number of your particular mower, you should be able to find a replacement manual, and or you could click images and it may show you a page with your belt breakdown as a picture
Jul 18, 2014 | Huskee Tractor Replacement Riding Lawn...
Mower deck drive belt keeps breaking
I HAVE A CRAFTSMAN 18 H.P. 3 BLADE 46" MOWER DECK.
1. THE PLASTIC PULLEY COVERS ON BOTH SIDES OF MOWER...WILL TRAP STICKS AND DEBRIS WHICH VERY RAPIDLY WEARS THOSE BELTS..I REMOVED MINE
IF IT IS RUBBING:
1. EITHER THE BELT HAS STRETCHED-REPLACE
2.THE SPRING MOUNT (WELDED TO DECK) GOT BENT...STRAIGHTEN
Jul 21, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My 18 hp cub cadet deck belt continually jumps off pulley
There are MANY pulleys on that deck. Which pulley are you talking about?
Jan 24, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I need diagram to thread blade drive belt.
Route the deck drive belt between the two inner, forward pulleys and then out and around the outer blade pulleys.
Jul 30, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to replace drive belt, but can't get the front pulley (under engine) off of a Huskee 42" 13AQ698G131
Apr 19, 2010 | Mtd Garden
Garden Logo
143 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
