Question about Toshiba 46HM95 46" HDTV
My Toshiba 46HM95 projection TV has been inconsistent with color delivery, particularily the red tone spectrum. When it doesn't work the colors of yellow and blue become more brilliant while reds turn to black or dark. Overall a more yellow tone overshadows the screen presentation. I have changed the bulb, as of today, but the results remain the same on the screen. The owner's manual only suggests adjusting the tint or color from the on screen menu. Nothing seems to improve picture color quality. David Hansen hansend@mchsi.com 563 391-8582
    President:
  • 2,923 Answers
David,
Based on your statement, I can see that the problem is your projection TV has a bad convergence IC. You need to have the right tool to change the convergence IC. Or you may contact an experienced tech to replace it for you. Convergence IC would only costs you $7. Please check the link below to see how it looks like:
http://www.shopjimmy.com/catalogsearch/result/?q=convergence+IC
Have a great day!
Posted on Sep 08, 2009
SOURCE:
I need to replace the color wheel in my Toshiba DLP46HM95, and am looking for instructions.
Try website like YouTube.com type in ur tv model and make will have somebody doing a colors wheel replacement and have tutoring video for u to follow.
Apr 02, 2011 | Toshiba 46HM95 46" HDTV
While watching TV - I heard a slight click noise in the remote and the screen color immediately changed color to predominately green ( still see blues and yellow) but red spectrum is not working ?? I have...
U have all the tools and can u also do basic soldering?Tv might have cold sodering joints on the CRT video board socket that connected video board and the CRT tube together.Must take tv aparts and resolders all the CRT holes sockets of the video board.Also resolders the Yoke wires R,G,B connections to the main board too.Should solved this problems.U can't do this,than u must hire a tv Tech to do the repair,sorry.
Feb 25, 2011 | Toshiba 32A33 32" TV
I have a 46hm95 tv. red light flashes 3 times, then pauses indicating color wheel problem. is this a dealer replace part or can i replace? if so, where is listing to buy part? is it worth fixing or...
Reports indicate the color wheel is sealed in the light engine and MAY NOT BE AVAILABLE AS A SEPARATE PART.
You can contact either Andrews Electronics (LA and largest OEM parts dealer in USA---some of these sets do not sell it as a part--have to buy the entire light engine which is more than the set is worth as a used set.
Google the model number with color wheel after it and you will see what I am talking about.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 14, 2010 | Toshiba 46HM95 46" HDTV
Turn on TV hear a buzzing and then the TV cycles off and on again
Hi,If it seems you are experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.I found it with complete light engine assembly here: http://www.discount-merchant.com/TOSHIBA-2973026206-p/1160068.htm?Click=48173
Apr 16, 2010 | Toshiba 46HM95 46" HDTV
Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
Jan 03, 2010 | Toshiba 27AF45 27" TV
I have a toshiba 56hm195, colors skin tones are washed out, reds
I'm having the same problem; have you found any solutions yet?
Dec 22, 2009 | Toshiba 56HM195 56" Projection HDTV
Red and green colors won't allign....
There is one way. Get way to go in to service menu and set conversions manualy. Remember to save. Tv will be ok
Dec 25, 2007 | Toshiba 46HM95 46" HDTV
Toshiba dlp
The light engine part number is 234054 and cost $456.00
Dec 20, 2007 | Toshiba 46HM95 46" HDTV
Toshiba 46HM95 46" HDTV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
