I have a JVC 48' widescreen tv approx. 7 - 8 yrs old. the picture is now extremely bad all of the colors seem to be out of wack and the picture bows inward toward the middle at the top and bows inward toward the middle at the bottom.......somewhat like a sideways hour glass. how can i fix this problem? I tried the auto, manual and resetting of the convergence - no success
  • SD Tech
    SD Tech May 11, 2010
    IF CONVERGENCE will not adjust you have a bad convergence ic--most of these sets use two--let me know model number and I will tell you what is needed to repair it. SD TECH
    Scholar:
  • 148 Answers
There's a miror or one like this might have a ''aluminium sheet'' miror.
Open the upper back cover to see what going on there, pretty sure something run out of place...
Posted on Sep 08, 2009
The color is messed up. It's wavy at the top and bowed at the bottom corners.
your convergence ics are going bad. usually around 150 to 250 dollar repair.
Mar 22, 2011 | JVC AV-48WP30 48" Rear Projection...
How do i fix my samsung 1080i hdtv. It has a double picture and is red and blue, and also looks like a bow tie effect
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved pictures convergence problems.The shop,will cost u like $300-$350 for parts and labors.
Nov 21, 2010 | JVC AV-48WP74 48" Rear Projection...
Poor quality picture. specifically the red is brown and can't be adjusted. the tv is about 3 years old.
If the picture is replace the lamp. Lamp only affects brightness if the color is wacked replace the light engine.
Mar 26, 2010 | JVC HD-56FN97 56" Television
Blurry vision on picture
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | JVC AV-48WP30 48" Rear Projection...
I'm seeing double pictures/letters on my 48inch JVC (I'ART) projection big screen tv. It's like the yellow wants to separate from the rest of the colors. What could be causing this problem? The tv is about...
one of the convergence ICs is probably defective, you will need a soldering iron to replace this . there are 2 of them,they start with a part no STK392-XXX
Jun 07, 2009 | JVC AV-48WP30 48" Rear Projection...
Colors out of porportion, maybe a bulb went out
When you have a 3-d effect. this is called convergence. Is the picture disorted or bowed in. if the picture is bowed in then this is an indicaTION of complete loss of power to covergence curcit. I always check to see if you have the convergence option in the setup menu if you do not then i suggest reading the fl231 problem in the tips and tricks sectionl
Mar 15, 2009 | RCA HD52W58 52" TV
JVC AV-48WP30 tv(convergence)
This is a convergence board problem. Have a tech replace convergence IC's. The part no. starts with STK. If you are good in soldering and know how to test resistors, you can do it.
Jul 16, 2008 | JVC AV-48WP30 48" Rear Projection...
Manually adjusting convergence
convergance amp is might have a loose connection or be bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC MODEL # AV-48WP74 48 IN. BIGSCREEN TV.
I had a problem with my TV colors not lining up. One day I turned it on and the green was out of wack. I checked this message board and replaced the STK chips, bad soldering and all led to me just giving up on that and buying a whole new Convergence Board ($185). I just plugged this in and though now my Green lines up okay, my red is out of whack. Is there something I am doing wrong? Can anyone help me? Did i miss a step? Frustrated......Bruce
Jul 29, 2007 | JVC AV-48WP74 48" Rear Projection...
Mitsubishi vs 60719 - Wavy bow in picture
Either a bad solder connection on your convergence module or a bad convergence IC. Repair costs will probably be in the $350-$500 range.
Jan 28, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
