Question about Bissell LiftOff Revolution Pet Vac 37602 Vacuum
This vaccuum is absolutely terrible on laminate it can't even pick up a sunflower seed. I can't return it . What should I do?
  • anwinter Sep 08, 2009
    It is 4 months not used for a month because of holidays. I always clean the filter and still does not work well!
  • jason king
    jason king May 11, 2010
    is it new ? does it need cleaned ?
    Brigadier General:
  • 4,088 Answers
Remove the bottom plate and check all of the air passages up into the bag for clogging. Does it use paper bags or a reusable bag? Remove the belt from the brush roller and see if the roller turns easily. Anything that chokes air flow needs to be cleaned.
Posted on Sep 08, 2009
    President:
  • 1,865 Answers
You have a clog in the system, clearf the clog, and you'll be good to go
My eureka multicyclonic vaccuum isn't spinning or picking up any dirt, what do I do?
Try open the bottom cover where the motor is located. It seems the the power belt is broken. Guides and Manuals Eureka
Apr 13, 2014 | Eureka Vacuum Cleaners; AIRSPEED One...
Picked up a cord, now my floor assembly is vibrating, sounds terrible
i have similar problem, picked up something and it makes terrible noise-hose not clogged- think it is way inside-how do i open it up-or which part do i open up?
the u shaped piece is clear-
thanks for any help at all..
karen
Apr 02, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
I use it on a laminate floor { pergo } and it shows streaks every time. It looks terrible when I am done.
This type of problem usually is not he fault of the Shark Steam Mop.
The problem is the old residue left on the floors by other cleaners.
Here is a tip that I wrote that will help you out with that problem...
Shark Steam Pocket Mop Cleaning Problems
heatman101
Feb 11, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Noisy vacuum that wont pick up properly
Your vacuum is still under warranty. Call Miele or the Miele dealer you bought it from. They are obligated to repair your vacuum.
Jun 05, 2010 | Miele S4210 Carina Bagged Canister Vacuum
Burning smell and not picking up dirt
You probably need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Jul 02, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
No Suction
Your Power head is blocked with hair or dirt,,or the hose which connects the Upright with the power head is blocked.
Try taking a steel coat hanger apart (straighten it out) and then push it into the pickup hose to remove blockage.
Jan 29, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Vaccuum forms in hose- will not pick up dirt
Check your wand for a clog. The DC17 line has common clog issues in its wand. It may be difficult to remove but if you have a long skinny pole(like one for curtains) you can use that to remove the clog.
Dec 05, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Kirby Vaccuum Cleaner:
likely a broken belt. turn vac over and see if roller turns free. if it does the belt is broken. turn the handle on front of vac. turn latch under headlight and remove head. open bottom plate and return handle to normal position. belt and brush roll will lift out. reverse procedure to install. directions are usually printed on the head of vac under headlight.
J
Jun 12, 2008 | Kirby Vacuums
We have a beam built in vacumn system ( old one) there is virtually no suction coming through the hose. I suspect some sunflower seeds were picked up and clogging it somewhere. What to do?
You need to figure out if it is the hose that is clogged, or in the piping. If in the hose, you can use a long plumbers snake to try to remove the clog. If you have no suction in none of the outlets, then I would suspect the hose, or the main pipe came loose from the cannister. Also are you sure that the cannasiter is coming on? If the blockage is in the piping, you can use the plumbers snake there also.
Apr 30, 2008 | Vacuums
VACUUMING FOREVER?
Looks like a filter has slit or gone missing on the exhaust side of the motor.-or perhaps you did not know there was one - it has clogged and a bypass is operating. You will have to consult the handbook for your model re filter changing to sort it. The Hoover Web site may be a help - have you looked?
Jun 16, 2007 | Hoover U5163-900 Upright Vacuum
Bissell LiftOff Revolution Pet Vac 37602 Vacuum Logo
65 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
