Question about Dell Photo 964 All-In-One InkJet Printer
Printer panel changed to different language
How do I revert to English
  • Matt Abbott May 11, 2010
    what is the model number?
    President:
  • 566 Answers
You can update the time, date, language and country settings after initial setup by accessing the Setup menu.
Press the Menu button. From the main menu, navigate to Setup mode/menu, using the arrow buttons to scroll through the available menus and the select (check mark) button to confirm your choice.
In Setup, select Language menu. Use the arrow buttons to scroll through the available languages and use the select key to and confirm your choice.
Posted on Sep 08, 2009
I want to change opperating language on my machine
If we are talking about Windows XP, there is a small icon in the right bottom corner stating two letters. Click on it and change to English. Or look under REGIONAL AND LANGUAGE OPTIONS in the control panel. ADVANCED tab.
Sep 14, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
I just purchased my HP 4500 printer and began to install it. I see an error (!) symbol and I believe German writing. I need to remove that symbol and change the language to English.
Selecting the display language
To change the display language on the printer control panel, do the
following:
1 Press and hold [SELECT] on the printer control panel while pressing
the standby button (power switch). Continue holding [SELECT] until
the control panel displays
SELECT LANGUAGE (in English), and then release the [SELECT] key.
2 When the control panel displays LANGUAGE=ENGLISH *, press
[VALUE] repeatedly until your language choice appears.
3 Press [SELECT] to save your language choice. An asterisk appears
next to the selected language. Then press [GO].
4 After the printer warms up, the control panel displays READY in the
selected language.
Note
If the control panel does not display the message in the language you
selected, press the printer standby button and repeat the instructions for
changing the display language.
Dec 07, 2010 | HP LaserJet 4500 Printer
The language is unknowinglychanged from English to
First check www,samsung.com and look for firmware updates for your model and follow the instructions to a tee.
If that does not help then the Main bd is bad.
Apr 10, 2010 | Samsung LA40R81BDX 40 in. LCD TV
How to change the language setting to English?
Computers running Windows®, you have the option of typing alternative character sets. This can be selected by clicking on START>SETTINGS> CONTROL PANEL. Then click on the picture of the world globe. This enables users to toggle between Arabic or Hebrew and English. This requires you to learn the keyboard layout for these languages
First, select the desired language.(the default in the U.S. is U.S. English If your computer was sold in a French spealing country, the keyboard might be different. If this is the case, the only solution could be a new keyboard
Oct 06, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Dell A920 printer not in English, how do I fix this, please.
please refer to your printer user manual and there will be guidelines to change your device language to english. Because the way of changing language will be different for different printers and only your user manual can explain you accurately.
I hope this is helpful to you
Oct 02, 2009 | Dell 922 All-In-One InkJet Printer
I can not print, the error is: LANG=ENGLISH, please help
Changing the Control Panel Display Language
The default control panel display language is set for English.
Supported languages are: English, French, German, Italian,
Spanish, Finnish, Danish, Dutch, Swedish, Norwegian, Turkish,
Polish, and Portuguese. Follow these instructions to change the
display language.
1 Switch OFF the printer.
2 Press and hold Select while switching the printer ON until
SELECT LANGUAGE appears in the display.
3 After the power-on self test, LANG=ENGLISH appears. Press
[Value+/-] until the desired language appears in the display.
4 Press [Select] to save your choice. An asterisk (*)appears next
to the language to indicate it is now the default.
5 Press [Go]. The On Line indicator is lit, and display messages
are now in the language you selected.
Sep 21, 2009 | HP LaserJet 4 plus Printer
Brother HL-1440 Printing Preferences Language Problem
I had the same problem. I finally totally uninstalled the printer from my computer, downloaded the "new" software from the Brother site, and reinstalled it. This is what finally worked for me (WinXPProf.).
Jan 05, 2009 | Brother HL 1440 Laser Printer
It prints in bad language format
It's not the printer that determines the language that is printed. It is the operating system and/or the program that is printing. Also, what you type.
In computers that run Windows operating systems it is chosen in the Control Panel. Use the Start button. Choose Control Panel then Regional and Language Options. Select your language in the pulldown menu. The entire system, including prompts, titles, etc. will now revert to that language. It will not, however, do a translation. If you have documents that were written in English they will still be English. If you want to type in English and print in French it will not happen. You must type in French to print in French...Comprenez-vous ?
A simple translator is available at http://www.reverso.net.
Nov 21, 2008 | Office Equipment & Supplies
Dell Photo 964 All-In-One InkJet Printer Logo
69 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
