Question about Motorola Mobility L7I Cellular Phone
My Motorola L7i phone wont turn on
My phone turn off during a call and when i turn it on back the screen ask for a data cable to be attach, i did that and the screen flicker until it went out and wont turn on.
How use Internet on laptop through Mobile GPRS on Motorola L7i
kindly install your pc suite.After connecting the phone using usb cable.got your pc suite icon,there will be option to connect to internet.then you can enjoy internet..
Nov 07, 2010 | Motorola Mobility L7I Cellular Phone
I am planning to share contacts from my L7i to another phone
If the other phone is a Motorola too, then there should be no problem. But if the other phone is not Motorola then you will have problems. The reason is that they both have different formats of Contacts. What you can do is copy as many (max of 250) on the SIM and then insert this SIM into the other phone and copy them there on the phone's memory. Then remove SIM from new phone and insert it back into the original phone. Delete all contacts from the SIM and copy the balance to the SIM. Remove SIM from here and insert it into the new phone and copy all contacts to the new phone's memory. The best and the fastest way to copy contacts from one phone to another where the data does not match.
Nov 30, 2009 | Motorola Mobility L7I Cellular Phone
Motorola L7i Keypad Stuck, Even Can't type security code to turno
I want to reset ma MOTOROLA L7i . So could u pls tell me the security code provided common
Jul 13, 2009 | Motorola Mobility L7I Cellular Phone
CALL RECORDING
yu can record yur conversation by pressing the black button on the right side of yur phone,,but during the process,yu cant be able to hear the person on the other line.
Apr 12, 2009 | Motorola Mobility L7I Cellular Phone
Motorola l7i problem
you will need to reprogram your phone with a compatible firmware..
what you need:
usb cable (comes with the phone package)
software and flashfiles.. (contact me personally for this)
YM: gieroquiazon
Aug 27, 2008 | Motorola Mobility L7I Cellular Phone
Motorola L7i
if u look  in the network settings, the 850 band is likely missing because u had a european destined phone dumped on you and you were misled or ripped off.
here is an easy fix, i just did it and im so much happier. went from no signal to 5 bars.
http://www.howardforums.com/archive/topic/808982-1.html
has the instructions, you will need a usb data cable to connect your phone to your computer.
Sep 05, 2007 | Cell Phones
Copying data from l7i through blue tooth
well you go to that file you want to send and press the options button which is the button with the line in and select move and then copy it over blue tooth
Jul 11, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility L7I Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
