Bush RF6694D TV (Service Mode Code)
Having read a few of the replies on here it seems that all I need is the "Service Mode Code" to be able to alter the horizontal and vertical screen settings for my TV.
  • Anonymous Apr 08, 2009
    my bush tv went blank and it makes a weird sound like an alarm and the power light is blinking could you please help me
2 Suggested Answers
chrispurs1
  • 372 Answers
SOURCE: Bush RF6694D TV (Service Mode)
Hi.
I may be able to help you but I need to know the chassis number of your tv set.
This will be on the back of the set on the same label as the model number or if not there it will be on the main pcb.
It could start with AK, or PT.
http://dysonmanuals.inc.io/
Chris..
Posted on Dec 14, 2007
Can not seem to fill my monitor screen 100%
Right click on empty space on desktop click propertises.
Choose the Display Settings.
Alter the resolution to a lower res.
If this doesn't fix it, adjust the vertical or horizontal hold on monitor
Jan 04, 2011 | Office Equipment & Supplies
One horizontal line center on the screen
The vertical deflection circuit has failed, or has been shut down by a service code entered from the remote control*. Usually you can get out of service mode by turning the set off and on again.
*Normally, you have to enter a special combination of front panel and remote control codes to get into service mode, then enter another code on the remote control to get the horizontal line. The horizontal line is used for adjusting the screen controls for each color so you get proper color in the dark areas of the picture.
Oct 27, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Horizontal lines in the top
CAUTION!!!!
you should never fix the inside of the tv unless you are a professionel tv repair man
there is High voltage and the only thing you should to is get a new tv set.
Nov 15, 2009 | Televison & Video
LCD screen purple and distorted in Shooting mode
There is recall on this model for this problem, Go to Canon USA web site, Look up Service advisory, CCD malfunction N/C to repair.
Feb 24, 2009 | Canon PowerShot A80 Digital Camera
Horizontal lines on picture
Can't advise on entering setup but the lines may be due to the maladjustment of the brightness control on the flyback. There will normally be two adjusters, one for focus the other for brightness.
Nov 26, 2008 | Televison & Video
Red Green Blue horizontal line at top of screen
Since both were replaced at one time, you now can't limit the problem properly. Should have been done one at a time.
Your vert height may be too short, causing you to be seeing things that should be off screen.
This can be remedied in the service mode.
Mr Bob
Feb 06, 2008 | Mitsubishi WS-65411 65" Rear Projection...
JVC 27" CRT TV AV-27BP3 display shows single horizontal line
I have a similar problem on my CRT computer monitor (AcerView 76c). It is an old screen and I think it is just at the end of its life, much like your TV. Having some background in physics, I would be pretty sure that the problem is with the cathode ray tube's vertical deflection system. The horizontal deflection electrodes are working while the vertical one is not. This results in a display of a single horizontal line (or in my case, a few superimposed) in the centre of the screen. Where both X and Y (horizontal and vertical) deflectors fail then the electron gun firing would result in a single bright spot in the dead-centre of the screen.
So really, we have no choice but to move on and buy a new set as repair is probably just as, if not more, expensive than replacement with a new device. Seeing as your post was in 2007, I hope you managed to solve the problem.
Best wishes,
SZ (Sydney, AUS)
Dec 24, 2007 | Televison & Video
Zenith Z27X22D Service Menu Codes needed
significant vertical overscan. It is such that it's impossible to read crawls and such at the bottom of the screen. I think this problem is a tv problem. it is due to vertical section. please change electrolytic capacitor in vertical output section. it will be ok. it is common problem can be fixed at home & very simple.
Oct 03, 2007 | Zenith Z27X22D 27" TV
Sylvania 6427FF TV displays wavy verticle lines at top of the screen.
I would suspect defective filter capacitors in the sweep circuits as well as the power supply source voltages.
Aug 07, 2007 | Sylvania 6427FF TV
RCA P46921 alignment issues
I am having the same problem. Just came across this information on another website. Hope it helps. (Both of us).... http://myweb.accessus.net/~090/how2adj.html#5.4 5.4 GE / RCA / PROSCAN Read the _ SERVICE MODE WARNING _ before proceeding. To enter service mode, push and hold the [Menu] button on the set. While holding, push and release the [Power] button, then the [Vol +] button. You will now have some information on the screen: "P0 V0" To actually be able to change these values, you must push [Vol +] on the remote so the information reads V76. Then pushing on the Channel +/- will change the "P" value. P1 - 3 are error codes. If there is a problem with the set that can be self-diagnosed, the "V" will report the code. These codes are available in the RCA repair manual. P4 - 7 control the horizontal size, shift, vertical size and shift. You may also find a summary leaflet for the service tech clipped somewhere inside the chassis. The procedures for getting into the service mode, as well as the service items of interest will be there. If you're attempting to adjust color or geometry errors, you'll need the Video Essentials DVD, Laser Disc or some other source of test material.
Jan 20, 2007 | RCA P46921 46" Rear Projection Television
Televison & Video Logo
269 people viewed this question
Top Televison & Video Experts
