Coleman-MAch 8330B63. Unit starts and blows cold air for about 10 minutes. Then simply shuts down. Will not start up again until about 10 minutes later. Can hear compressor working, but no fan.
I built a 70W solar panel. The cells are housed in a wood frame and topped with plexiglass put down...
(More)
I built a 70W solar panel. The cells are housed in a wood frame and topped with plexiglass put down with a bead of silicone to seal all tight. One only 1/4" drain hole on back underside to drain moisture, and permit air to get in or out due to thermal expansion and contraction. On hot sunny day, the cells heat up as they work, and create a significant amount of condensate on the inside of the plexi. Perhaps I need a lesser amount of "air" indside the panel box, and I'm considering sandwiching the solar cells between 2 sheets of glass with no drain. Do solar cells need room to breathe?
appears to be condensation leaking from the roof A/C in 2009 Pleasure Way Plateau RV. Leaks on back...
(More)
appears to be condensation leaking from the roof A/C in 2009 Pleasure Way Plateau RV. Leaks on back bed and floor. Thanks, Richard
We just bought a 1996 motorhome that has the solar panel on top of the ac unit but someone has...
(More)
We just bought a 1996 motorhome that has the solar panel on top of the ac unit but someone has clipped the wires in air return and removed the Solar Monitor light assembly. I have good voltage coming from panel but need this unit to go between panel wires and battery wires. Where can I get this assembly or does anyone know where I can get a part number for it. Thanks
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
