Question about Weber Summit E-620 Gas Grill
Can't get a flame
I changed tanks on my weber gas grill and it isn't getting LP gsd to the burners. The new tank is full of gas.
  • 434 Answers
Unscrew the fitting off the tank and make sure there isn't an extra washer in there. Sometimes when you get a tank there will be a washer inside it that has slid of the last guys POL(screw in hickey) With this extra washer, the POL isn't going in far enough to open the tank valve.
Posted on Sep 08, 2009
Poor flame after changing tank on gas grille
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 05, 2014 | Weber Genesis E-310 Gas Grill
Model Q200, Propane model Get no flame on the burner. Apparently, getting no gas. Something seems to be stopped up. What to do?
Whether you're using a 20 Lb Propane Grill Tank or a screw in gas canister, the solution to the problem is the same .
1. Be sure you have enough gas in the tank or canister to maintain proper ignition.
2, If the above checks out OK. Turn the LP tank valve OFF or if you're using a screw-on canister
turn the gas valve OFF.
3. Disconnect the hose from the tank or unscrew and remove the gas canister.
4. Wait 5 minutes and reconnect the hose to the tank or reattach the canister to the gas valve.
5. Open the gas valve VERY, VERY SLOWLY (Slow Motion, slow). Once the valve is full open, light
the burner & turn it to HIGH. Did the burner light and does the flame height look correct?
If so, you solved the problem. Remember to always open the tank valve Very, Very Slowly.
if the above didn't solve the problem, you will either need to replace the Hose/Regulator Assembly or the Gas Valve/ Canister Holder. The Hose/Regulator Assembly you can pickup from any home center or hardware store that sell grills & accessories for about $30.00. If it's the Gas Valve/Canister Holder, you will have to purchase that from Weber or from Factory Appliance Parts http://www.appliancefactoryparts.com/gasgrillparts/brands/weber/q200.html Part # WEB4195 ($29.99) The adapter hose is also available there if you want to make it a one stop shop for $32.99
I hope ths helped you and thanks for choosing FixYa. Happy Grilling!!
Aug 26, 2011 | Weber Q Grill
Hi.. have a 300 series weber we bought only last year.. I cannot get the burners to come on together.. I can manually light the inner one but as soon as I try and manually light the outer one... it will...
More than likely, the grill's regulator is malfunctioning. To solve this, turn the LP Gas Tank Valve OFF and disconnect the hose. Turn the grill burners ON, wait 2 minutes and turn them OFF. Reconnect the hose to tank and open the tank valve VERY, VERY SLOWLY (Slow motion, slow) Once the valve is open all the way, light the inner burner first and turn it to the highest setting. Does the flame height look correct? If so, light the outer burner and turn to HIGH. Do both flame heights now look correct? If so, you solved the problem.
If you are using an insert-able gas canister, instead of a 20Lb LPG Gas tank, do the same thing as above, except remove the canister. Since there will be no hose/regulator assembly involved.
To provide further assistance, in case you have misplaced your Owners Manual, I have included a link to it that you can download and print for future reference, if you like.
http://help.weber.com/manuals/ducane/2009%20Manuals%20pdf/Affinity_3100_4100_LP_OwnersManual_27010331_101508.pdf
Hope this helped you to solve the problem. Please let me know and Happy Grilling!!
May 10, 2011 | Weber Q Grill
We have a spirit grill with 3 burners. I can light the grill, but burners 1 & 2 don't have a nice line of blue flame like burner 3. Burner 2 is especially bad with orange flames on the right and left...
Are you sure there's adequate gas in the tan? If so do the following:
Disconnect the LP tank from the grill hose. Wait 5 minutes and reconnect to the tank. Open the tank valve VERY,VERY SLOWLY, until it is full open. Light your burners individually and turn to highest flame setting, before lighting the next burner and so on.
If that solved your problem GREAT. Remember to turn the tank on that way in the future.
If it didn't you'll need to remove the burners and clean each one.
Hope this helped to get you back up and grilling again.
Feb 18, 2011 | Weber Spirit? E-310 Propane Grill
Low flame
close the air vents to the burners
Jul 05, 2010 | Weber Genesis Silver B Grill
Weber grill three burner. New tank of propane but
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Mar 29, 2010 | Weber Genesis Silver B Grill
Grill lights but flame is low and goes out if control is moved from high. Burner tube is clean, spider screen is clean, and I have a full tank of LP. Grill is Q series about 1 year old and has been working...
Hello. Are you frustrated because your gas grill doesn't get hot enough lately. The problem you are having indicates that you have to go through a procedure called "RESETTING THE REGULATOR". Follow these easy steps:
1. Turn the burners on for one full minute and then off.
2. Next, remove the regulator and the hose from the tank.
3. Then reconnect the tank to the regulator and hose.
4. And very slowly open the tank.
5. Last step is to fire up the burners and start cooking with you new hot flame.
The problem began the first time you opened the valve on the tank too quickly. In the future, always turn the tank valve on s-l-o-w-l-y to prevent this problem.. Joe
Mar 22, 2010 | Weber Q Grill
My grill does not exceed 300 degrees. The rear burner is barely lit, it sputters with a blue flame. The Front and middle burners run well, blue flame no yellow. I changed the regulator with one from home...
Bypass valve need reset. All grills made after 1996 have this valve.
  • Close the LP tank valve
  • Turn all burner control knobs to the OFF position
  • Open the grill lid
  • Turn the LP tank valve until it is completely open
  • Wait 90 seconds
  • Turn the front burner to the HI/Start position
  • Press the igniter until the burner is lit.
  • Turn remaining burners to High
  • Close the lid.
  • The grill should preheat to 500-550 degrees in 10-15 minutes
I called Weber and a rep walk me through it.
Jul 08, 2009 | Weber Genesis E-310 Gas Grill
Gas grill
Probably 1 of 3 things:
Check your LP tank valve at an LP filling station. Make sure both valve and tank are in working order.
Next check for webs or cocoons up around where knob valves go into burners. You may have to remove burners to see into back of valves. Then swab orifice holes with a torch tip cleaner.
Third, a Menards , LP outfitter/station, or grill shop should have a universal replacement rubber gas line and "regulator"(possibly plugged or stuck shut). Sometimes you end up with cheap/bad regulator out of the factory.
Good luck and hope one these helps or does the trick.
Mar 25, 2009 | Weber Genesis Silver B Grill
Weber Summit E-620 Gas Grill Logo
81 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
