Question about GE Profile WPSR3100W
Agitator is loose
GE profile washer WPSR3100WOWW, approx build date of 1998. The agitator will spin during the spin cycle, but it is loose and raises up and wobbles. I took the fabric softener cap off, bu there is no screw, just a round plastic cap that I can't seem to figure out how to remove. Please help?
  • Vince Brunette
    Vince Brunette Sep 08, 2009
    I will try, but I am not sure it unscrews. It is in storage, so I will let you know.THANKS!
    Brigadier General:
  • 4,088 Answers
Does the plastic cap unscrew (CCW)? If you get it off, there is a plastic block attached to the top of the shaft that should just pull off. Check it for cracking or splines that are torn out inside--replace it if damaged. Make sure the cap screws down tight.
Posted on Sep 08, 2009
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
GE Profile WPRE6100G Top Load Washer My washer is 2 yrs old and has started to make a loud metalic banging noise during the wash cycle. It does not during the spin cycle. Doesn't seem to matter whether...
Hi!!
The "Metallic banging/clicking" sound you hear is the Shifter mechanism engaging or disengaging.
The drive system will engage at the start of the Agitate Cycle and disengage when the Agitate Cycle is complete. This occurs multiple times during the wash. GE claims this is a normal sound and should not be concerned about it. Check page 10 of your Operating Manual, if you do not have a manual, click on this link to download one http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90323.PDF
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 03, 2010 | GE Profile WPRE6100G Top Load Washer
GE profile top loader, agitator and spin start and stop
Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
May 23, 2017 | GE Profile Prodigy WPSE4200A
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
My ge washer wpre6100g clicks during agitation part of cycle...
sounds like the agitater drive is stripped its a plastic piece under tha agitater you just grab the agitater work your fingers under the edges and **** up on it and it snaps off then remove the 5/16 screw put a new block on and snap the agitater back on
Jan 29, 2009 | GE Profile WPRE6100G Top Load Washer
Agitator not working during was cycle what would cause this probl
I'm experiencing the exact same issue with mine.
Can you hear the motor running during the agitation? If the motor is running, but the agitator isn't working, then that would point to something like the transmission, or some sort of obstruction that is preventing the agitator from working properly.
If the motor isn't running, then try running through different cycles. If it operates properly on one cycle, but not others, then I would tend to think that it's in the controller. If not, then it's likely in the motor. I also have seen a post somewhere instructing to check the vacuum connection to the water level control, as well. NOt sure how that plays into the equation, but it's easy enough to do & doesn't cost anything to try.
FYI: I just spent $10 for one of the "experts" here to tell me that the issue was "absolutely" in my motor. After spending $220 to replace a motor that I cannot return now since it's been installed, I find out that my original assessment is probably correct & my problem is in the controller.
If it comes down to a toss-up between the two, go with the cheapest first (likely the controller).
Hope this helps.
Jan 21, 2009 | GE WBSR3140DW Top Load Washer
During wash cycle the hub nut that is located under the agitator comes loose. It has to be tightened after each wash. GE Profile Top Load Washing Machine
replace the hub nut and the washers under the tubbe sure to tighten really tight if it comes loose again you will need to replace the transmition
Jan 15, 2009 | GE Profile WPRE6100G Top Load Washer
Washing Machines Logo
535 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
