Question about Kirby G5 Bagged Upright Vacuum
The drive on my Kirby G-5 is stuck in forward.
When I move the Neutral/Drive lever into Drive, the wheels rotate forward and won't stop like it's stuck in gear. The only way to stop it is to kick it back into neutral. Any ideas?
  • Anonymous Mar 20, 2014
    reset the forward torque on drive now the customer complains it has a burning smell and is supposed to disengage when in reverse???
  • 430 Answers
Motor housing will need to be removed and transmission a linkage adjusted. Take to a pro shop for this one.
Posted on Sep 08, 2009
How and where do find the switch to activate self propel unit in G4 series kirby
To place the kirby G4 into gear - out of Neutral - just press down with your foot, the Gray & Green lever that is labeled N on the left side of the lever, which is gray, and D on the Right side of the lever which is Green (probably for GO). It is located directly below the Power button.
Good Luck
See Pic...
Feb 03, 2014 | Kirby Generation 3 Bagged Upright Vacuum
Self propelled high speed
If by "lever" you mean the step on rocker pedal at the rear of the unit, then we're talking about the same thing. If not, then I have no idea what lever would move to "D" or "I". When the pedal is depressed on one side it puts the drive mechanism into gear, when it's depressed the other side it moves the drive mechanism out of gear. It's about that simple, unless the pedal is broken inside the drive box, then nothing happens either way, usually. The only way to tell if it's really broken is to try it in both directions, if there's no drive in either side then there's a problem in the box. You'll need to take it to a qualified repair shop, not everyone can repair these drive boxes.
Nov 11, 2013 | Kirby G4 Bagged Upright Vacuum
Kirby will not push forward, wheels are locked
Check the back side at the bottom to see if there is a lever (switch) that has an N on one side and D on the other. You press N to roll the vacuum when it is NOT ON. N is for nuetral. You press D when the vacuum is ON and you are using it. D is for drive.
Feb 14, 2011 | Kirby Ultimate G Bagged Upright Vacuum
My G7D kirby vac was accidently dropped and the D & N lever came out of the machine. When I put the lever back in the hole it belongs in it is very loose and it doesn't switch from D or N.
The drive/ neutral pedal assembly must be replaced. This part is pressed together and cannot be repaired. A new assembly is about $17-$20. The power drive unit must be removed from the machine.
Jan 23, 2011 | Kirby Ultimate G Bagged Upright Vacuum
KIRBY 5 PROBLEM
make sure the lever it the very back of the machine is in the on or drive position, make sure the height is up high enough ( the higher the better as long as it is still cleaning - lower is not better ) and change the belt even if it isn't broken they can stretch out in less then a year of use.
Sep 19, 2008 | Kirby G6 Bagged Upright Vacuum
Sweeper vibrates when pushed forward.
do u put it on drive or neutral? does the wheels spin when on drive? is the height adjuster on the right level?
Sep 09, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G5 - the Tech Drive does seem to have much power
you need either a new nutreal cam bracket assembly, that is what engages and disengages the tech drive.OR to adjust the handle pivot assy- diffucult . this is not for the faint of heart. it is possible to fix them as i used to repair kirbys, however, I remember how frustrating it was to figure out how to disassemble and reassemble them. it is very complicated to a novice. I would recomend having it repaired professionaly. it is possible for a professional to repair it in a very short period of time.
another thing to consider. look on the UNDERSIDE of your Kirby, between the two drive wheels. just in fronnt of the tech drive/nutreal switch. there should be a screw there, tighten that screw up. actually tighten all of them. on My generation 3 the center screw came loose and it would not go in to drive and it would make an aweful clatter. hope this was helpful
Jul 08, 2008 | Kirby G5 Bagged Upright Vacuum
Gear lever
here are a few links to repair proceedures for the kirby (pictures included)
Transmission:
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
On/Off switch
http://www.greatvacs.com/Kirby%20Powerswitch.shtml
Hope that helps!
Jan 02, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
329 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
