Question about GE Washing Machines
GE ADORA WASHER IS NOT DRAINING AND IS STUCK IN PAUSE MODE
The washer has been stalling right after the rinse and refuses to drain. If I change washer cycle modes it will sometimes drain. Now it is not working at all. The pause light is flashing
    Sergeant:
    Champion:
  • 255 Answers
Bad pump/motor or bad belt going to pump
Posted on Sep 08, 2009
Why won't my washer drain
Check the belt that operates the pump. If that does not help, take out the pump und check for obstructions. Pins tend to get stuck in there and keep the impeller from turning. Does the impeller turn freely? If it does, the machine will drain.
May 17, 2014 | GE Adora Front Load Washing Machine Washer...
Adora washer has given several years of trouble-free service. Lately, water overflows the drain standpipe and flows on to the floor. Machine washes, spins and rinses just fine - the overflowing is the only...
  1. If the drain water is overflowing the standpipe then you have a problem with the house drain not the washer.You need to clean out the house drain or call aplumber to do it for you.
Jun 17, 2011 | GE WSXH208A Front Load Washer
My topload Roper washer cycles fine but stucks in rinse stage. It makes a noise on that stage. I manualy put it in spin mode (skipped the rinse) and it works from there. Please help.
Your timer is bad. There must be a pause in the timer for the neutral drain transmission to lock in.
No Pause.
No Spin.
To double check this,when the timer gets to the Spin cycle, open then close the lid.
If it starts to spin at that point the timer is bad.
Jan 09, 2011 | Roper Washing Machines
My GE Adora dishwasher is not cleaning well and the detergent isn't completely disolving. What could be the problem?
Mine has been doing the same thing for about 2 months now.. I tried Finnish brand diswasher cleaner, but to no avail. Try this:
1) Empty your dishwasher, then take out the lower rack.
2) Start a regular cycle. Wait until you hear the jets turning, then open the door. Make sure there is enough water in the bottom - It should be just UNDER the heating element.
3) If your dishwasher is getting enough water, Reset your washer and allow it to drain.
4) Go to the store and get a gallon jug of white vinegar. Start your dishwasher on a regular cycle.
5) Once you hear the jets turning, Open the door and add FOUR CUPS (liquid measure) of white vinegar to the water in the bottom. Let the wash cycle complete.
6) When the wash cycle drains, the rinse cycle will fill. Once the rinse cycle starts, add ANOTHER FOUR CUPS of white vinegar to the first rinse cycle.
7) Allow the first rinse cycle to drain. Let the second rinse cycle complete normally.
I know this sounds too good to be true, but it REALLY DID work for me, this evening as a matter of fact! I also bought some hard water/soap film detergent additive from the store. It was kind of expensive, but I'm using it for a while just in case.
I hope this helps. Like I said, I couldnt believe it when my dishes came out clear again! Also, I turned OFF the heated dry cycle, and just opened the door and pulled out the racks when it was done.
Good Luck!
Mar 30, 2010 | GE Adora GHDA654LBG Dishwasher
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Aug 11, 2009 | GE Energy Star WCVH6260F Front Load Washer
Washer won't drain
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Aug 05, 2008 | GE Energy Star WCVH6260F Front Load Washer
Ge adora top load washer won't spin,
the water in my washer will not empty, and it keeps pausing its self.
Jun 03, 2008 | Washing Machines
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
464 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
