My air conditioner is no longer cooling. When I try to change the setting on the panel to "cool" it does not light and the room remains the same temperature.
  • 224 Answers
Please check the temperature its set on, Please check if the compressor is working, if everything is perfect then lastly please get someone to check if your air conditioner contains the required minimum gas for cooling.
Posted on Sep 08, 2009
Our wall mounted air con is set at 16 degrees but it is not cooling the house at this temp. Could it be the thermostat
most wall mounted ac units are designed to only cool a room, not a house
close all the doors to the room along with all windows
generally a 3kw unit (32,000btu )will cool a room 12ft X 12 ft X 9 ft quickly but anything bigger, the time that is taken to bring the temp down gets longer and longer depending on the setting and 16 C is far too low
Dec 07, 2016 | Heating & Cooling
Tip
Air Conditioners Cooling Tips
  • Whole-house fans help cool your home by pulling cool air through the house and exhausting warm air through the attic.
  • Set your thermostat as high as comfortably possible in the summer. The smaller the difference between the indoor and outdoor temperatures, the lower your overall cooling bill will be.
  • Avoid setting your thermostat at a colder setting than normal when you turn on your air conditioner. It will not cool your home any faster and could result in excessive cooling and, therefore, unnecessary expense.
  • Consider using an interior fan in conjunction with your window air conditioner to spread the cooled air more effectively through your home without greatly increasing your power use.
  • Avoid placing lamps or TV sets near your air-conditioning thermostat. The thermostat senses heat from these appliances, which can cause the air conditioner to run longer than necessary.
  • Plant trees or shrubs to shade air conditioning units but not to block the airflow. Place your room air conditioner on the north side of the house. A unit operating in the shade uses as much as 10% less electricity than the same one operating in the sun.
  • on Sep 21, 2010 | Heating & Cooling
    Haier air conditioner won't cool the room anymore
    i bought the air conditionor new and it will not cool what can i do
    Jul 05, 2012 | Haier ESA406K 6,000 btu ECO-Friendly...
    Portable air conditioner not cooling
    Ensure your Portable Air Conditioner is sized properly for the room it is in.
    A good rule of thumb is 12,000 BTUs for 400 square feet. If the room you are attempting to cool is too large, then the cooling effectiveness will change.
    Also ensure that the air conditioner is properly vented outside of the room.
    May 21, 2011 | Heating & Cooling
    Kenmore 12,000 BTU Room Air Conditioner ENERGY STAR
    How many Square Feet is the ac rated for?How large of room are you trying to cool??
    May 27, 2010 | Heating & Cooling
    Motor and fan on exterior unit work once then do
    im not qiute sure about this but it sounds to me like you are getting a hard lockout from high or low pressuers on the out side unit
    Aug 27, 2009 | Heating & Cooling
    Thank you. there are some other signs i don't know about.
    The black triangle means AUTO, means the fan speed adjust by itself from high-mid-low speed depending in room temperature but the unit is cooling for this function the same COOL mode. Plasma is in the remote control but it never mention in the manual.
    If the unit dont cool check your temperature setting and mode setting it should be in cool mode and temperature setting should be 18C. But if still don't cool check some error code like blinking light at the indoor panel check how many blink appears to get the correct error code.. If the light is blinking 3 times it means that the room air or coil sensor is defective.
    abc4048.jpg.
    Apr 28, 2008 | LG LSC121PMA Split System Air Conditioner
    Sharp Air Conditioner. Model # AF-S85NX. Does this A.C. fan cycle on & off in the auto cool mode or does remain on continuously. I need a small A.C. that cycles off and on with the compressor.
    If you set you r AC to FAN mode the unit will not cool, it only runs in the indoor but the outdoor will off. If you set to AUTO the unit will cool but the indoor blower will automatically run slower when the room is cool or attain the room temp. setting. If you set it to COOL the fan speed is fix depending on your setting and it also operate in cool.
    Apr 19, 2008 | Heating & Cooling
    Not cooling
    1. check doors,windows,of room
    2.if there is leakage freash air came in.so temparature can not maintend
    Jan 30, 2008 | Haier HPAC99ER Air Conditioner
    Heating & Cooling Logo
    37 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Donni Steen
