Question about Thermador PG304BS Gas Kitchen Range
How to clean - what are the steps? - Thermador PG304BS Gas Kitchen Range
    Scholar:
  • 44 Answers
Hows the best way to clean the back part of the AC when its still in the window
the best way to clean your air-conditioning by using pressure washing
step 1: Turn off your power supply or remove plug.
step 2: Pullout unit
step 3: Remove electrical box or insulate the electrical box to prevent water enter the electrical box and fan motor.
step 4: Clean the evap. and condenser by use pressure washer.
step 5: Wait unit dry the unit
Step 6: Remove insulate electrical box and fan motor
step 7: Install the unit
step 8: Plug and turn on the power supply.
step 9: Turn the unit
Aug 08, 2012 | Haier HWR06XC6 Wall/Window Air Conditioner
Tip
How to CLEAN a Frigidaire Self-Cleaning Oven Step 1Use a plastic spoon to scrape...
Step 1Use a plastic spoon to scrape away any extra spillovers or burnt-on food from inside the oven. Remove as much of this as you can before running the self-cleaning cycle, because any spillovers left in the oven during the cleaning cycle may cause a lot of smoke.
  • Step 2Wipe off the inside of the oven with a rag dipped in soapy water. Be careful not to get any cleaning supplies on the oven door gasket or to disrupt the position of the gasket at all; having a good seal is critical to the success of the oven's self-cleaning cycle.
  • Step 3Clean any soil away from the oven frame and its door liner with a rag dipped in soapy water. Any soil left on these parts of the oven may become burned on during the self-cleaning cycle.
  • Step 4Pull the broiler pan and grid, any utensils, and any tin foil that may have been left in the oven out of it. They can't withstand the extreme temperatures the self-cleaning oven will reach. It's okay to leave the oven racks in the oven.
  • Step 5Make sure the oven door is completely closed.
  • Step 6Press the "CLEAN" button on the control pad. Use the up and down arrows to select the desired cleaning time; use 2 hours for a lightly soiled oven and 3 or 4 hours for a dirtier oven. The oven will lock itself and begin the cleaning cycle.
  • Step 7Wait for the cycle to end and the oven to cool; it will then unlock itself automatically. Don't try to open the oven door before it has unlocked itself.
  • on Apr 07, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    PRINTING COLOR PICTURES ARE ALOT ORANGE IN COLOR MP830 ???
    clean your nozzles cartridges.
    STEP 1: Printer Cartridge Removal
    You must remove the printer ink cartridges from the printer. You should then set down the cartridge on a plain and stable surface. The cartridge must be placed with the nozzle facing up.
    STEP 2: The Distilled Water Cleaning
    Take a Q-tip. Moisten it with distilled water. All excess water from the Q-tip should be removed or wrung out.
    STEP 3: Sweep across the surface of the nozzle tip with the Q-tip. This will help you wipe the surface.
    STEP 4: Sustain the Process
    You must keep continuing the process of cleaning till your Q-tip does not show any residue.
    STEP 5: Check if it Works
    For this, you need to put back the cartridge in the printer. The printer alignment function needs to be used for the alignment of the printer cartridge.
    STEP 6: The Clean 'Head' Option
    After you cleaning nozzles physically, you can give the cleaning process another go by selecting the cleaning option from the printer settings. Once cleaned, you can check whether the nozzle is print-worthy or not, by giving a print command.
    If the cleaning process has not been successful repeat the whole process again.
    Apr 17, 2011 | Canon PIXMA MP830 All-In-One InkJet...
    How do I clean oven
    Hi
    These are the things you will need to clean your oven.
    Oven Cleaner, Soft Rags, Sponges, Oven Cleaner and a Sponges.
    Remove oven racks and place them in soapy water to soak.
    Preheat oven to 200 degrees.
    Turn the oven off and spray the inside with oven cleaner.
    Allow to sit for 10 minutes.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7mMYimF
    Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
    Dry with a soft cloth.
    Thanks.
  • Step 4 Allow to sit for 10 minutes.
  • Step 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • Step 6 Dry with a soft cloth.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7lkil29
  • Step 3 Turn the oven off and spray the inside with oven cleaner.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7lanRHk
    Jul 30, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    How to hook up tool to clean upholstery
    Keep your upholstered furniture looking fresh by vacuuming it regularly with the upholstery tool attached to your vacuum's hose. Prevent the fabric from fading (or at least delay this) by keeping your furniture out of direct sunlight -- close blinds, shades or curtains when the sun shines most directly through windows closest to the upholstery. And remove stains by blotting them with a dry cleaning solvent. Before steam cleaning your upholstered furniture, read the piece's cleaning code label to determine whether or not it is safe to do so. Then rent or buy a steam cleaner (also called an extractor) and follow the directions below.
    1. Rent a steam cleaner or purchase one; buy steam cleaner solution.
    2. Step 2 Vacuum the upholstery on the furniture you wish to steam clean; use the upholstery attachment to most effectively **** up loose debris.
    3. Step 3 Test the steam-cleaner solution on the upholstery in an inconspicuous place to ensure the color won't be steamed out or drastically altered.
    4. Step 4 Attempt to remove any stains with a stain removal or dry cleaning solution. Follow the directions that come with the product you choose for the best results, and allow the stain remover to dry before you begin steam cleaning.
    5. Step 5 Remove cushions and, if necessary, arm covers.
    6. Step 6 Gently apply the steaming water and cleaning solution in straight lines across the upholstery one section at a time.
    7. Step 7 Use the cleaning extension on the steam cleaner to **** up as much water as possible. The dirt will come out with the water.
    8. Step 8 Clean one side each cushion (then allow it to dry) before cleaning the other side. If the cushions are permanently attached to the furniture, clean them last.
    9. Step 9 Allow the furniture to dry completely before repeating the steam-cleaning process or replacing the cushions.
    Jun 19, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
    How to clean the Lexmark X83
    Instructions
    Things You'll Need:
    * Cleaning Solution For Plastic
    * Cleaning Cloths
    * Cleaning Cloths
    Cleaning the Outer Case
    1. Step 1
    Collect the supplies you need: a soft cloth and cleaning fluid made for plastic. (Water is fine in most cases.)
    2. Step 2
    Check the printer manual. If the manufacturer has provided specific instructions, follow them.
    3. Step 3
    Turn off the printer.
    4. Step 4
    Dampen the cloth with water or cleaning fluid.
    5. Step 5
    Wipe the outside of the printer, making sure that no fluid gets inside.
    Cleaning Cartridges or Ink Nozzles
    6. Step 1
    Use the cleaning buttons on your printer if it has them.
    7. Step 2
    Initiate cleaning through the printer software.
    8. Step 3
    Open the printer software by double-clicking on a printer icon or opening a document and then selecting Print from the File menu.
    9. Step 4
    Click a button labeled Options, Troubleshooting, Clean Print Cartridges, Toolbox, Printer Utilities or something similar. (This varies by manufacturer.)
    10. Step 5
    Click a button labeled Head Cleaning, Run Nozzle Check, Clean Print Cartridges or something similar to begin the process.
    11. Step 6
    Follow the instructions on your screen.
    12. Step 7
    Repeat the cleaning process if the results aren't satisfactory.
    13. Step 8
    Jan 27, 2010 | Lexmark X83 All-In-One InkJet Printer
    My prints are red with lines Why
    Cleaning an ink-jet printer can solve minor problems, maintain print quality, and prolong periods between professional cleanings. Thin white lines across printouts indicate that the ink nozzles need to be cleaned.
    1. p 1 Collect the supplies you need: a soft cloth and cleaning fluid made for plastic. (Water is fine in most cases.)
    2. Step 2 Check the printer manual. If the manufacturer has provided specific instructions, follow them.
    3. Step 3 Turn off the printer.
    4. Step 4 Dampen the cloth with water or cleaning fluid.
    5. Step 5 Wipe the outside of the printer, making sure that no fluid gets inside.
    6. Cleaning Cartridges or Ink Nozzles
    7. Step 1 Use the cleaning buttons on your printer if it has them.
    8. Step 2 Initiate cleaning through the printer software.
    9. Step 3 Open the printer software by double-clicking on a printer icon or opening a document and then selecting Print from the File menu.
    10. Step 4 Click a button labeled Options, Troubleshooting, Clean Print Cartridges, Toolbox, Printer Utilities or something similar. (This varies by manufacturer.)
    11. Step 5 Click a button labeled Head Cleaning, Run Nozzle Check, Clean Print Cartridges or something similar to begin the process.
    12. Step 6 Follow the instructions on your screen.
    13. Step 7 Repeat the cleaning process if the results aren't satisfactory.
    14. Step 8 Go to your printer manufacturer's Web site for detailed instructions on manual cartridge cleaning and interior cleaning.
    Nov 15, 2009 | Epson Stylus Photo R300 InkJet Printer
    Good morning, I need to clean inside of my Toshiba 50A60 model tv screen, I do you remove screen?
    Yes I Had The Same problem , if your handy with fixing things this will
    work.
    Step 1- unplug the TV from wall socket
    Step 2- disconnect all devices like VCR's DVD Players from the TV
    Step 3- remove the speaker covers from the TV
    Step 4 - There are 14 screws on front cover, remove these with a
    Philips driver, set cover aside
    clean with soft brush and wash with water
    Step 5- Gently raise the cover straight up to release it from its supports
    Once cleared from supports , remove the cover.
    Tips- Make sure you don't scratch any of the screens or CRTs
    You can clean the mirror with any glass cleaner, make sure to wipe it
    clean , water and vinegar does a good job to eliminate streaks.
    Use a soft duster to clean the dust from the circut boards
    Tip - Remember take it easy when cleaning
    When your finished cleaning, just reverse the steps
    It Worked for Me
    Sep 30, 2009 | Toshiba 50A60 50" Rear Projection...
    My game wont read on my xbox 360
    I believe you can use a DVD cleaner without voiding your warrenty. If you have a warrenty then call Xbox tech support to get it fixed. And if you don't buy an extended warrenty for $50 and then call them and tell them you need your Xbox fixed
    steps to be followed.
    1. step 1 Purchase a DVD lens cleaning disc.
    2. Step 2 Turn on your television and Xbox just like you normally would to play a video game.
    3. Step 3 Open your Xbox's disc drive, placing the lens cleaning disc in the drive face-up. A lens cleaning disc works by sweeping small brushes over the laser lens surface. These brushes are located on the bottom of the disc; be careful not to touch the brushes---the microfiber brushes are delicate and can become damaged easily.
    4. Step 4 Close the Xbox and let the machine power up; make sure your television's volume is turned on. Your Xbox should automatically take you to the system's standard CD player menu. If this does not happen, select the menu manually using your Xbox controller.
    5. Step 5 Begin playing the first track of the cleaning disc. Listen carefully, because audio directions will play indicating the steps necessary for properly using your cleaning disc. Each brand of lens cleaning disc will have different steps, but they are typically very simple, involving tasks like skipping ahead to different tracks or briefly putting the CD in fast forward mode. If you cannot hear the audio directions, consult the written instructions packaged with the disc.
    6. Step 6 Remove the cleaning CD after you've followed the audio directions---a typical cleaning cycle only takes a few minutes, and the audio directions will tell you when cleaning is complete.
    7. Step 7 Carefully place the lens cleaning disc back in its case, avoiding damaging the brushes on the bottom. Lens cleaners can be used multiple times, so plan on using the cleaning disc regularly to help avoid future problems with your Xbox console.
    Jun 13, 2009 | Microsoft Xbox 360 Console
    Printing Alignment
    hello!
    It may be one of the cartridges is defective. Try replacing the cartridges to see if the problem clears or the printer just need a little clean up. you may also try this
    Step 1: turn printer off.
    Step 2: unplug power brick.
    Step 3: MANUALLY move cartridge carriers towards the center.
    Step 4: take cartridges out.
    Step 5: move carriers to the RIGHT.
    Step 6: CLEAN the shiny silver bar that is connected to the carriers using a dry cloth, from left to right in one direction.
    Step 7: move carriers to the LEFT.
    Step 8: CLEAN the shiny silver bar that is connected to the carriers using a dry cloth, from left to right in one direction.
    Step 9: move carriers to the RIGHT.
    Step 10: CLEAN the see-thru tape that is connected to the carriers using a dry cloth, from left to right in one direction. (careful, it is delicate, clean both sides).
    Step 11: move carriers to the LEFT.
    Step 12: CLEAN the see-thru tape that is connected to the carriers using a dry cloth, from left to right in one direction. (careful, it is delicate, clean both sides).
    Step 13: put power brick back in. turn printer on.
    Step 14: put inks in.
    Step 15: press check to print alignment page.
    If the problem persists, possible that the printer is defective
    May 09, 2008 | Dell 926 All-In-One InkJet Printer
    Thermador PG304BS Gas Kitchen Range Logo
    Top Thermador Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    butch welch
    Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
