Color on my dell monitor ,s1709wc, turned redish blue. Is it fixable? I would appreciate any help.
  • 62 Answers
Try replacing your monitor cable. Also make sure to tighten the screws that hold it to connector on the computetr and the monitor.:)
Posted on Sep 08, 2009
  • 4,234 Answers
Since you can read the monitor, the green signal is entering the monitor. It also contains the sync signal. I would first inspect the solder connections on the board that sits on the back of the tube. I would guess that there are poor solder connections there. Either that or the trasnsitor that controls the creen gun is defective. Please note that there are dangerous high voltages present inside these units even when unplugged. If you are not familiar with these types of repairs, please seek assistance from a service shop.
Dan
  • 99 Answers
No it's not fixable .. because the color scheme on the Monitor has gone bad. Have you had any magnets close to the monitor ?
Usually in this case the TUBE is bad and not producing the correct color scheme
Posted on Sep 07, 2009
My 2001FP shows the contrast cotrol greyed out and the screen has very low contrast, which I need to correct. I use it with a Dell Inspion 9300. The laptop screen has excellent contrast. The 2001FP...
I have four Dell 2001FP monitors. The unavailable contrast is standard for this monitor when used with digital input (DVI). Make sure your brightness is at 100%.If you want a better result of dynamic range and color, the only effective option is color calibration. I use the inexpensive Huey Pro, available
several places, including eBay. Retail is around $100. It something one uses maybe twice a year, takes five minutes to install and use, and the results are notable. I'm a designer, and need excellent color. This is the best solution. Calibrate your laptop as well, and the color should be almost exactly the same between them.
As an alternative, you can use the color settings, select User Preset, and start with something around 40 red 43 green and 37 blue. Adjust proportionately upward until you get what you want.
Another possibility is to use a different connector cable if your laptop has that option, since your monitor an take four different input formats.
Good luck.
Dec 07, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Screen is showing as blue color
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Apr 14, 2010 | Dell E173FP 17" LCD Monitor
My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again... (More) My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again during...
well that could be because the screen is going bad. you might want to get another one or take it in to get it fixed, no more than 100 to fix your screen.
Feb 13, 2010 | Dell E176FP 17" LCD Monitor
I am trying to connect my laptop to the TV and would appreciated if someone could share information about connection details My dell inspiron 501 laptop has only the VGA port. The lowest resolution that...
Your dell should pick the TV up as a monitor if you have the VGA cable connected. The vga cable has a blue color on the TV but on the laptop, the color of the port is usally brown or dark in color. Windows should pick up on the new device and enable it. The Dell has an Fn key combination to allow you to toggle through the integrated / external monitor choices that you would have with two monitors active, that being clone both desktops to both monitors, extend the desktop from the laptop to the TV, use only the tv and turn the integrated off, use just the integrated and leave the TV off. The key combination is: Fn + F8
Jan 12, 2010 | Dell Inspiron 1501 Notebook
My monitor turned off suddenly and wont turn back on. I've tried restarting the pc, unplugging the power cord and replugging it in, and unhooking and reconnecting the video cord. Its model is a dell...
It is probably the power supply in the monitor. Call Dell and see if they will replace it. If the cost exceeds half the price of the monitor, purchase a new one. I know you can get a 20" acer from best buy for around $99.
Dec 25, 2009 | Computers & Internet
E172FP DELL MONITOR, COMES ON AND THEN GOES OFF MOMENTARILY. HAS A LOW REDISH GLOW WHILE IT IS ON.
unplug the vga cable from the back of the monitor while the poewr to the monitor is on and look for the band of colors it will move around the screen it will give red, green,blue and white color if they are the proper colors all over the screen that means the monitor is fine the problem is with the video card or the cable and, if the monitor does not gives proper color replace the monitor... any queries revertt back
Sep 17, 2009 | Dell E173FP 17" LCD Monitor
My monitor will drop the colors
check wheather is there any land phones are there, or any sound speakers present beside the moniotr.
than also not working give the monitor to repair.yes it is fixable.
Jul 17, 2009 | HP Computers & Internet
My Dell w4200hd will not turn on. The color on the little light by the power on/off switch will change from what I think is standby color to a different color when I try and turn it on, and I hear...
i do have the power supply at my shop. but i don't think the power supply is the problem. i already replaced the power supply on this set with this symtom and no help. you can find parts at discountmerchants.com J.D.W.
Mar 08, 2009 | Dell W4200 42 in. HD-Ready Plasma...
CRT discoloured
If it's a deguass problem, you can glue some very small magnets to the sides of the crt tube itself, it could be the shadow mask, inside the monitor, and if it is then nothing will fix it, if you can get a deguass coil from somewhere that would tell the story real quickly
Nov 04, 2006 | LaCie Electron 22blue II 22" CRT Monitor
Computers & Internet Logo
199 people viewed this question
David Payne
David Payne
