Question about Dryers
My fisher and paykel dryer stops after about 10 minutes... I think its the thermostat safety but there are 3 different thermostat sensors in the dryer and I don't want to replace all 3.
  • 574 Answers
Unplug the dryer remove the wires to one at a time with a multimeter turn it to ohms and touch each side where the wires were connected and see if you get a reading if it reads OL on the display the fuse is no good or turn it to check continuity and touch leads together you should hear a low tone it will do the same if the thermal fuse or safey is good
Posted on Sep 08, 2009
My Fisher Paykel DEGX1 US dryer has no power after I reset the manual thermostat and vacuumed lint from inside the dryer and outlet pipe. It beeps when I plug it in so power is coming to the unit.
if the unit got backed up with lint and over heated then its a good chance that the Non resettable safety temperature switch has gone , you'll find it just by where the pipe exits the dryer , should have two wires on it and should be about the size of a nickel id bet its open .
Dec 16, 2016 | Fisher Dryers
Dryer moisture sensor not working
coolblueworld.com is fisher paykel wed sight
Mar 07, 2014 | Fisher and Paykel Dryers
Fisher paykel dryer ed56
Could be the door switch or temp sensor. To check the door switch put pressure against the door and see if it stops. Check the slot the door hits to see if there is anything loose in there.
Jul 20, 2013 | Dryers
Fisher Paykel DEGX1 no heat, therm tripping - used multimeter
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
May 31, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Fisher & Paykel Auto Sensor Dryer stops & beeps constantly
Hi emkboyce
my Fisher Paykel auto sensor dryer keeps stopping and beeping, i have to stop it and and re start.
I had the same problem. I took it off the wall and vacuumed up all the lint from everywhere including around the back and including taking off the back and vacuuming everything I could reach inside. I then used a damp cloth to get rid of the rest of the lint/dust.
I thought I was wasting my time but guess what, the problem has gone.
Sep 30, 2009 | Fisher and Paykel DEGX1 Electric Dryer
My fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Aug 11, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher Paykel degx1 electric clothes dryer
Thermostats, the dryer temperature control switches, are controlled by the temperature inside the dryer or by the heat of the motor. One or more thermostats on the panel can be adjusted to control the temperature in the dryer. Operating thermostats sometimes stick, causing control problems. These thermostats are usually positioned near the exhaust duct bulkhead or the fan housing of the dryer. Remove the back panel of the dryer to get at them.
Before you make any checks, try tapping the housing of the thermostats lightly with the handle of a screwdriver. This may jar the contacts loose. Temperature control switches are located behind the dryer control panel, and the panel must be removed for switch testing or replacement. Here's how to test and replace the thermostat:
Step 1: To check the control panel thermostat, make sure power is off to the dryer. Test the thermostat with a VOM set to the RX1 scale. Clip one probe of the VOM to each thermostat terminal. If the meter reads zero, the thermostat is working. If the needle jumps to a high reading, the thermostat is faulty and should be replaced.
Step 2:
 If necessary, replace the thermostat with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 3: To check an operating thermostat, first make absolutely certain that the power to the dryer has been turned off and the dryer is cool. Then disconnect the leads to one side of the thermostat. Test an operating thermostat with a VOM set to the RX1 scale; clip one probe to each terminal of the thermostat. Disconnect the leads to one side of the thermostat so that the meter won't give a false reading. If the meter reads zero, the thermostat is working. If the needle jumps to a high reading, the thermostat is faulty and should be replaced.
Oct 10, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Dryer Fisher paykel
the biggist problem with dryers and drying is the outside vent being plugged. next thing is it gas or electric. electric i would think cycling thermostat. gas would be coils or thermostat. this is asuming you do have heat
Jan 18, 2008 | Fisher and Paykel DEGX1 Electric Dryer
It wont heat at all. lint trap empty, good air flow
needs a heater rework kit probably. contact fisher paykel and they will pay for the repair.
Nov 02, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Dryers Logo
51 people viewed this question
Top Dryers Experts
