Question about Megatronix - PASSLOCK-SL2 - GM Passlock Data Bypass Kit - Self Learning Byp
Looking for install manual for "dei 457gw" module
Car dies when I use my remote start and press the lock or unlock button
This is most likely caused by the car's anti-theft system. Most newer cards require a separate module to be installed to override the anti-theft system while the remote start is in use. Otherwise, when the anti-theft system detects an anomaly, it will immobilize the vehicle.
DEI makes a 556H module for this purpose. The link shows the instrall manual for this device.
DEI 556H Module Info
Dec 12, 2013 | 2002 Honda Civic
Hey MECP guy, what a job you're doing; THANKS. I want to buy the Prostart CT-5472W for a 2004 Lincoln Navigator. I also want to get addt'l modules like DEI 504D shock sensor 506T audio sensor
Yes, I frequently use DEI modules with Audiovox( Prestige and Code) alarms and remote starters. I just have to hardwire them to work with the systems.
Oct 26, 2012 | Vehicle Parts & Accessories
I have a horn that sounds when my hay baler chamber is full. I am looking for a timer relay that will allow the horn to sound for 3 to 5 seconds and then disconect the circuit so it won't drive me...
DEI 528T appears to be 12Volt 'wait to start' or ON-delay timer.
528 receives electrical signal, and then delays the start-circuit by up to 60 seconds.
For example home alarm system. Door is opened and alarm sounds. Install DEI 528 and set for 60 seconds: Door is opened and alarm will not sound for 60 seconds.
You need 12-volt off-delay timer.
Off-delay timer receives electrical impulse, and then begins a countdown.
After countdown expires, then circuit turns off.
ELK-960 appears to have off-delay feature for 12V DC
http://www.homesecuritystore.com/p-423-elk-960-delay-timer-module.aspx
Use wiring diagram #7 for alarm cut-off:
http://download.homesecuritystore.com/downloadmanual.aspx?FileName=ELK-960_Install.pdf
Aug 25, 2011 | Directed Electronics Dei 528t Pulse Timer...
Hi what tupe of starter i should purches for my car i have santa fe 2002
It really depends on what features you are looking for. I installed Audiovox for 12 years and DEI for 8. I like the DEI much better. The Audiovox always had problems with their remotes and would break down. DEI remotes last much longer and all the options are better on it too. They are the leaders in the field.DEI is the makers of Viper and Python as well as automate.
Nov 12, 2010 | 2000RS-M Remote Starters Manual...
Dei automate remote starter 552 for manual gear installation
It can be installed, but is not recommended. If the car was left in gear and the auto start activated the car will lurch forward. A friend of mine, who is an installer, had his WRX jump a curb in a parking lot in land in a ditch. BTW, he "never left his car in gear". It only takes once.
Nov 08, 2009 | Directed Dei Valet 561r Remote...
How to install a DEI/BOA 555L GM Passlock 1 & 2 Immobilizer Bypass
goto www.bypasskit.com and click search by product, follow the instructions to download the instal manual, good luck
Sep 06, 2009 | DEI GM Immobilizer Bypass
What fuses does it take? Have it in my car but there are missing fuses also have other dei products in my car that are wired but missing fuses. Please help!
I'm still digging but I have some info for you. DEI- 530 is a Window automation system. DEi- 529 Is a window roll up module. DEi-520 is a battery back up.
May 04, 2009 | Honda Civic Cars & Trucks
Megatronix - PASSLOCK-SL2 - GM Passlock Data Bypass Kit - Self Learning Byp Logo
121 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
